Old 08-26-2013, 08:04 AM   #99
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Originally Posted by Suberman View Post
I don't do DYI on a car under warranty.
<Shrugs>
Whatever. When I compare ten minutes of my time spent doing that versus endless loops of taking it to a dealer and never getting it fixed to suit...I think the economics are pretty clear.
Admiral Ballsy is offline   Reply With Quote
Old 08-26-2013, 08:13 AM   #100
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Admiral Ballsy View Post
<Shrugs>
There are no endless loops with the new part number. It just works.
Old 08-26-2013, 08:23 AM   #101
Admiral Ballsy
Shorter of breath
I don't doubt that it holds the mirror adaptor to the shoe rigidly. If they redesigned the spring, that could be better too.
But it can't fix the issue with the flexible mounting of the base to the glass. I guarantee there's less vibration in the mirror on my car than on any with nothing done in that regard. Whether the stock arrangement is 'good enough', though, is in the eye of the individual.
Old 08-26-2013, 08:44 AM   #102
xjohnx
Grip>Slip
xjohnx's Avatar
If you say so.
Then again, I actually have the functioning part in my possession, installed on my car, and have tested it rather than commenting based on speculation. So there's that.
Old 08-26-2013, 08:53 AM   #103
Admiral Ballsy
Shorter of breath
If you say so.
Then again, I actually have the rigidly attached part in my possession, installed on my car, and have tested it - in comparison to the stock mounting method - rather than commenting based on speculation. So there's that!
Old 08-26-2013, 09:07 AM   #104
xjohnx
Grip>Slip
xjohnx's Avatar
To each his own. I'd rather not have JB weld anywhere near my car. It screams half-assed hackery to me.
Old 08-26-2013, 09:47 AM   #105
Admiral Ballsy
Shorter of breath
I can respect that.
The Following User Says Thank You to Admiral Ballsy For This Useful Post:
xjohnx (08-26-2013)
Old 08-26-2013, 09:59 AM   #106
Admiral Ballsy
Shorter of breath
By the way, is there any verification/documentation of the proposition that the mirror mounts the way it does for regulatory reasons?
The notion makes sense, but there are five cars in my household - all 2012 or 2013 - and only two of them have mirrors that mount like this - the other three have the old-style shoe-glued-to-glass setup. Seems as though if it really was a regulatory requirement, they'd all be the same or similar.
I found this - http://www.nhtsa.gov/DOT/NHTSA/Vehic...TP-111-V00.pdf
Pertinent text seems to be:
(1) REQUIREMENTS (S5.1.2)
If the mirror is in the head impact area, the mounting shall deflect, collapse, or break away without leaving sharp edges when the reflective surface of the mirror is subjected to a force of 400 N (90 lb) in any forward direction that is not more than 45 degrees from the longitudinal direction.
So it seems as though breakaway is an option but not a requirement - collapse works too, and that seems to be how most cars are made; the link connecting the base to the mirror pivots downward and allows the assembly to collapse toward the glass.
Old 08-27-2013, 02:37 PM   #107
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
My freaking home link mirror just fell off! Dang it was very embarrassing driving down loop 410 with a hanging home link mirror! Wtf this is a brand new car? Took it to the dealership Gilman Subaru! They seem to know this is a known problem and they are fixing me up fast and good! Hopefully they use the new parts! I tried fixing it myself buy those screws were stripped in that plate! This is definitely a defect! Subaru needs to fix this.
tripjammer is offline   Reply With Quote
Old 08-27-2013, 06:15 PM   #108
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
The new part is working great so far.
Mine fell off too.
Yes, added blue loctite, no more wobble, for now.
kiichiro is offline   Reply With Quote
Old 08-27-2013, 09:54 PM   #109
tripjammer
tripjammer's Avatar
Dealership fixed it good. Took them an hour!
Old 08-27-2013, 10:01 PM   #110
tracerit
Drives: '13 SSM BRZ Limited 6MT
how much wobble should i accept before it's gonna fall off? when i'm driving, it shakes just a bit to make the image blurrier than the side mirrors. there's no noise and there's no play when i'm shaking it with my hands though.
tracerit is offline   Reply With Quote
Old 08-28-2013, 12:20 PM   #111
bloop
Drives: brz weee
Do what I did. U see any vibration at all even minor. Take it in and they'll replace it under warranty. 10 min job. Seems like a common issue.
bloop is offline   Reply With Quote
Old 08-28-2013, 12:25 PM   #112
choi0706
Drives: t
they wouldnt cover mine even after purchasing two adapters that rattled.. they said it was a installer error and that I should of used blue loctite.. I dont remember the instructions stating to use blue loctite..
I'm not really that confident the new one will fix it though.. Picked it up yesterday, and I'll see if this one holds.. If not I'm certainly not going to purchase another.. I may try the JB weld route and use different hardware.. or I might try and repair the threads with a timesert kit
choi0706 is offline   Reply With Quote
Yen to Dollar conversion link whataboutbob Scion FR-S / Toyota 86 GT86 General Forum 2 08-31-2012 12:51 PM
Gearbox: Cable Link or Mechanical Link? Marrk BRZ First-Gen (2012+) — General Topics 42 07-02-2012 12:45 AM
Saw a car, fell in love, deposit down.... Did I do alright?? Chewie4299 Scion FR-S / Toyota 86 GT86 General Forum 13 06-22-2012 12:52 AM
