Old 08-01-2014, 10:40 AM   #99
bluesubie
Mike - I'm surprised the viscosity for this oil took such a hit since 300V is such a robust oil. Is this before you added the oil cooler? TBN was high so the oil had plenty of life left in it.
It should be the newest formulation as that came out at the end of 2012 (Ester Core).
-Dennis
bluesubie is offline   Reply With Quote
Old 08-01-2014, 11:23 AM   #100
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
-Dennis
No oil cooler yet. We wanted to baseline everything before making those changes.
We will report back after the next oil change which will have 70/30 split using no cooler and the 2015 DIT cooler.
Mike
AZP Installs is offline   Reply With Quote
Old 03-13-2019, 08:37 PM   #101
Speedy Nick
Drives: Stock
Really depends on how often you want to overhaul... assuming ethter / pao or paraffin oils with right additives (my understanding is that it really is the additives if you have constant operating environment)...;
1) 0W-16 if you can overhaul anytime
2) 40 grade, if you intend to run for couple of years, maybe like 10,000km/year, with intervals (i.e. HPDE or multiple race weekends / tests)
3) 60 grade, if you are doing 24hr endurance
I've used 0W-40 Mobil1, run 95℃ - 105℃, changed every weekend of racing / tests, and run 12,000km this year on track. I expect to overhaul next year, based on how other cars failed with similar use profile. Expensive hobby indeed.
Speedy Nick is offline   Reply With Quote
"Come Race Me Bro" Encounters GH05T FR-S / BRZ vs.... 2565 02-28-2023 09:34 AM
New 4-2-1 Long Tube Header Anorexic 86 Engine, Exhaust, Transmission 28 08-25-2013 03:28 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
