#99 |
Drives: Scion FRS Firestorm
Just an FYI for folks, they came out with a revised safety clip for some additional piece of mind for those worried about it opening unexpectedly. Looks stronger than the little metal clip it used to have.
http://www.qwikvalve.com/Fumoto-Leve...mall-HC10.html |
#100 | |
Some of the consistent resistance part could also be the gasket compressing (or OEM crush washer with the OEM bolt). |
#101 | |||
Drives: CBS Subaru BRZ Limited
It seems to be leaking around the gasket that came with the valve so I suspect it's because it's not tight enough. |
#102 | |
Drives: Neptune GR86
If you don't have a crow foot attachment for a torque wrench, then just use whatever wrench you have that fits properly. Just don't crank it on super tight and you should be good.
#103 | |
#104 |
"Hand tightening" was a little vague, we were referring to simply not using a torque wrench, in other words, using your own hands to measure torque on a plain wrench.
Using a wrench, you should be able to feel the resistance suddenly get firmer as you approach good torque. If you're concerned, Harbor Freight has some very inexpensive torque wrenches and crow foot adapters. I'd recommend having one anyway. |
#105 | |
#106 | |
Drives: Yes
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#107 | |
What may explain the inconsistent leaks? Sometimes I find oil, other times I don't see any, I remember I hand tightened it as much as I could then used a wrench to tighten it about a quarter more as others have done and it seemed fine. |
#108 | |
You could swing by a local Harbor Freight and pick up a torque wrench ($22) and crows foot set ($9). Or see if anyone in the area has a torque wrench and crows foot, or call a local garage and ask if you could throw them $20 or a 12-pack to get your car on a jack/lift and have them check the torque, it'd take them about 5 minutes. |
#109 | |
#110 | |
Drives: Yes
Is oil coming out from the nozzle of the valve, or from around the washer where it seals with the oil pan? Also, did you tighten the valve body itself with a crescent wrench, or that little hex head with a socket? The former is the proper way. If you did the latter, then you may have broken the Loctite on the threads inside, which could allow oil to seep through.
#111 |
Drives: 2013 BRZ Limited SWP
I have a concern about the valve. How much old oil is left in after a drain? It appears the threading extends in to the pan a few mm not allowing a total drain? Has anyone measured the oil pan drain threading the the plug threading?
#112 |
Drives: Yes
Not enough to lose sleep over
| Installed Perrin shifter bushing & Fumoto oil drain valve | zooki | Engine, Exhaust, Transmission | 23 | 03-31-2013 05:18 PM |
| FS: Fumoto quick valve | Laika | Engine, Exhaust, Bolt-Ons | 1 | 01-08-2013 01:51 PM |
| Quick Question??? | soontobrz | BRZ First-Gen (2012+) — General Topics | 12 | 12-16-2012 11:02 AM |
| Quick question.... | be6sti | Engine, Exhaust, Transmission | 8 | 11-04-2012 09:53 PM |
| quick question about the height.. | VenomRush | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 12-22-2009 10:42 PM |
