Old 07-19-2015, 02:54 PM   #99
AllStar0419
AllStar0419's Avatar
Drives: 2013 FR-S Asphalt
Originally Posted by Necric View Post
I got the catless resonated pipe, however I'm getting an exhaust leak between front and mid pipe. Do they make a gasket I can order for this?
Did you reuse the OEM donut gasket and spring bolts for that connection?
AllStar0419 is offline
Old 07-20-2015, 02:21 PM   #100
Necric
I dont think the donut gasket fit the new pipe, I used the supplied gasket on the overpipe to frontpipe connection and the new bolts also supplied instead of the spring.
2013 6MT Firestom FR-S. invidia Q300, OpenFlash Tablet and Header, Eibach Sportline Springs, SPC LCA, Shift springs and bushings. Dashlinq4 Radio.
Necric is offline
Old 07-20-2015, 09:47 PM   #101
AllStar0419
I have the same catless resonated pipe from invidia and on the rear end of it the pipe extends past the flange, the donut gasket from the OEM pipe will fit on it and you can reuse the spring bolts with low torque since the springs are very strong. The midpipe portion of the cat back has a slight widening near the flange to accept the donut gasket and seal.
Old 07-21-2015, 10:20 AM   #102
Necric
Hopefully I've still got that gasket laying around...
Necric is offline
Old 07-22-2015, 05:28 PM   #103
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
To the Top!
FT-86 SpeedFactory is offline
Old 03-28-2016, 07:45 PM   #104
Kolenda18
Drives: Scion FR-S
Which is louder invidia catted or catless?
Kolenda18 is offline
Old 03-28-2016, 08:36 PM   #105
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Catless.
Muaddib is offline
Old 03-28-2016, 09:35 PM   #106
Songha
Songha's Avatar
Installed the catless frontpipe over the weekend and the change was noticeable for me. Sounds less restricted, more raw. Can't help but to step on the accelerator more and shift higher.
Mated with my Invidia N1.
Songha is offline
Old 03-29-2016, 10:22 AM   #107
Kolenda18
Drives: Scion FR-S
Does Catless Invidia set off the CEL?
Old 03-29-2016, 10:48 AM   #108
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
No, that only occurs once you replace the Header.
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline
Invidia N1 - VIDEOS and Installed Photos ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 200 05-16-2017 06:07 AM
***Invidia N1 FRS / BRZ SALE*** Videos and Photos - FT-86 SpeedFactory does it again! FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 33 10-24-2012 10:11 PM
Invidia N1 - Group Buy **FT-86 SpeedFactory** FT-86 SpeedFactory Groupbuys 65 10-23-2012 12:25 PM
Track pipe + catless front pipe diss7 Engine, Exhaust, Transmission 21 10-09-2012 01:10 AM
Invidia N1 - Sneak Peak **FT-86 SpeedFactory** FT-86 SpeedFactory Engine, Exhaust, Transmission 54 10-02-2012 10:48 PM
