Old 07-12-2022, 01:50 PM   #99
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
In my experience either they’re already in STR with the parts from their old STX cars or they’re going to ride out DS until they’re not competitive anymore. Locally I think there’s 5x new cars, three in DS and two in STR, both STR builds are using their mk1 parts for the most part.
There’s less then 10k mk2s on the road at this point vs 100k mk1 cars, seems like a dumb argument to outclass the old cars based on the handful of autoxers who jumped on the new hotness. That’s what nerfed STR participation but what do I know.
Two of those in DS will eventually make their way to ST, either after this year or in another year once this whole ST issue is better figured out.
It made sense for the two of us that went straight to ST. We already had the parts...and we enjoy having front camber.
G_Ride is offline   Reply With Quote
The Following User Says Thank You to G_Ride For This Useful Post:
strat61caster (07-12-2022)
Old 07-12-2022, 01:51 PM   #100
otter
Drives: 22 BRZ
Originally Posted by foshjowler View Post
Miata is should have its own spec class, STMiata.
I've thought for a while that this seems like the next logical step after the success of SSC. Not sure what the class letters should be, though, since SSR and SSM are both taken. SND for Spec ND?
Also, in a year or two it'd be great to see SSC updated to allow all 1st gens and to get an SSC2 for the 2nd gens...........I'd be down for going that route instead of ST*.
otter is offline   Reply With Quote
Old 07-12-2022, 01:53 PM   #101
otter
Drives: 22 BRZ
I intend to go to ST* regardless of where the car sits, likely in 2024. I just need a bit more time for people who are smarter than me to develop the car while I build up the budget.
Old 07-12-2022, 01:58 PM   #102
foshjowler
Drives: 2022 BRZ; 2014 BRZ
I'd be very interested in seeing an SSC2. It's still probably a couple of years out, but I'd order the kit immediately if they do. To me, it's a great balance of being that little bit more aggressive, still being very dailiable, and not breaking the bank on $5k coilovers.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
foshjowler is offline   Reply With Quote
The Following User Says Thank You to foshjowler For This Useful Post:
otter (07-12-2022)
Old 07-12-2022, 02:35 PM   #103
steverife
Drives: 2016 Scion FRS
You definitely don't need $5k coilovers in ST.
steverife is offline   Reply With Quote
The Following 3 Users Say Thank You to steverife For This Useful Post:
DocWalt (07-12-2022), G_Ride (07-12-2022), strat61caster (07-12-2022)
Old 07-12-2022, 03:11 PM   #104
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I have $2100 coilovers on mine. Totally happy with them.
I also wrote a proposal for an SSC 2.0... Fixing the weaknesses of the first gen SSC (like the stupid and pointless SPC rear arms and toe bushings, the soft lowering springs, etc) and I'd gladly go run SSC 2.0 instead of STR, getting beaten by the ND a lot is dumb. Sure we can trophy at nats, but winning is out of the question.
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
Old 07-12-2022, 03:44 PM   #105
G_Ride
G_Ride's Avatar
I don't expect setup to be too different from the first gens.
Old 07-12-2022, 04:26 PM   #106
strat61caster
strat61caster's Avatar
I don’t even know what coilovers I would buy if you gave me $5k to spend on coilovers. I guess call up mcs and buy knobs I don’t need?
ineedyourdiddly
Old 07-12-2022, 04:50 PM   #107
G_Ride
G_Ride's Avatar
Buy something cheaper, pocket what's left of the $5k
Old 07-12-2022, 04:52 PM   #108
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I had MCS 2W on my CS/STR ND, I don't miss them. Yes they're built really well and all but I'm happier with my Shaftworks valving. I do kinda want to get them converted to doubles at some point, but meh. Not spending money on something that won't add much/any pace.
Old 07-12-2022, 04:52 PM   #109
foshjowler
$5k was an exaggeration, but if I was to get coilovers for ST* I'd likely go with Xidas. Those and MCS are in the $4k price range. Buy once, cry once sort of thing. Even at $2k for coilovers, you could probably get the complete SSC kit, other than tires, for that.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
Old 07-12-2022, 07:08 PM   #110
strat61caster
Complete SSC kit is around $4k last I checked, budget stx is a bit over $5k, less if you find good deals, for instance my first header, coils, oft, and second set of wheels I got bargain prices, at one point I had a competent stx car with all the below for ~$4k.
Coils $2k
Front sway $300 with end links
Rear lca $300
Wheels $1,000
Tires $1k
Uel header $600
Oft $400
$5.6k
SSC suspension kit from tirerack: $2.5k
Wheels $600
Tires $700
$3.8k
Spend it on an OsGiken
ineedyourdiddly
Old 07-12-2022, 07:49 PM   #111
steverife
I don't care about most of the stuff people talking about here, but...
Originally Posted by DocWalt View Post
Would be funny for the Zs to go back to STR, haha. Considering the SCCA scales are always such broken garbage, not sure I'd want to use a weight split for wheel size, but it would be really interesting.
Oddly, the STS folks I've talked to seem to be like "well, meh, ok." I suspect the Hondas would still be quite competitive with a diff, NA Miatas maybe less so because the VLSD does sorta work?
I think the NB would be a blast in STX, the ECU issues with that limit it a lot which is both nice and annoying.
...but I'd have a super tough decision if the Spyder went to current STX.
Old 07-12-2022, 11:03 PM   #112
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
There’s too many vocal people in STS to make changes to STS IMO.
I think STS would be great with diffs in general honestly, VLSD’s are getting very hard to find.
ST* could use a re-org but one thing at a time SP needs more help first.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
2022 Twin to STR Simmons BRZ Second-Gen (2022+) — General Topics 11 03-01-2022 11:03 AM
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-13-2022 12:44 AM
2022 BRZ Limited Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku BRZ Second-Gen (2022+) — General Topics 20 02-10-2022 12:44 PM
2022 Toyota Land Cruiser Revealed With New Platform, Twin-Turbo V6 vh_supra26 Other Vehicles & General Automotive Discussions 24 07-07-2021 02:44 PM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
