Old 11-18-2021, 08:37 AM   #99
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by nikitopo View Post
If you really had coolant temps above 220F, you wouldn't have an engine anymore
220F and higher is quite normal in other cars under track usage or even hot weather in-town usage with A/C on. Is the FA20 *really* gonna fall apart at that temp? "Red" zone for most cars us up around 250F. Not that you'd want to keep it there...
Old 11-22-2021, 07:33 PM   #100
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
How am I just now seeing this thread!?! Can’t wait to get your thoughts buddy!
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 11-22-2021, 08:16 PM   #101
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by ZDan View Post
Went back and looked at data logs, one day I saw 199F max, another 202F max coolant temp. Kinda surprised to see they're that low!
Memory is a little dodgy on this as sometimes I have the temp gauge at "normal" setting with no numbers for *F, and sometimes I have it in the alternate setting where it shows tickmarks at 150F/190F/230F/270F, and they're different scales. In any case I'd see it go up and hold in a "normal" part of the range so didn't think about it much, more keeping eye on oil temp...
The stock setup is pretty good considering I have been peaking at about 199f with a larger koyorad.
Old 11-22-2021, 08:42 PM   #102
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yeah, stock setup *is* pretty good!
Kinda reminds me of 240Z days, in my local Z club a guy would go on and on about the 4-row aluminum radiator he got for his mild 240Z build, maybe 150rwhp, *never* overheated! Meanwhile my 3.1 liter with sirrius headwork and 3x2 45mm carbs making 255rwhp never overheated either, with a factory 260Z radiator...
CSG Mike (11-23-2021)
Old 11-23-2021, 02:51 PM   #103
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
How did I miss this thread....
By my reckoning, you turned about 1:28 at Streets of Willow stock with a passenger! Very nice indeed.
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 11-23-2021, 11:47 PM   #104
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Mike, is the front fender liner's vent section a riveted on part or moulded into the liner itself?
Old 11-30-2021, 01:18 AM   #105
jflogerzi
jflogerzi's Avatar
Pedal dance still valid/needed?
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
Old 12-02-2021, 10:53 PM   #106
molded in!
Kiske (12-02-2021), Lonewolf (12-03-2021)
Old 12-02-2021, 10:54 PM   #107
Doesn't work. Don't think it's needed.... can't tell for sure as I'm not using suspension with high spring rates at this time, and no data to verify with.
jflogerzi (12-03-2021)
Old 12-02-2021, 10:54 PM   #108
One more valving change on the prototype CSG FLA, validate on old chassis, and then the new FLA may be ready to go....
Old 12-02-2021, 11:00 PM   #109
dreamwonder
Drives: GR86 2022
Will the stem on the rear be shorten? Assuming they are teins.
dreamwonder is offline   Reply With Quote
Old 12-02-2021, 11:39 PM   #110
They could be but a lot of folks would have a hard time reaching the adjuster.... no happy medium
Old 12-09-2021, 04:39 PM   #111
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Mike, what do you think about the traction control modes on the new car?
dragoontwo is offline   Reply With Quote
Old 12-12-2021, 06:26 PM   #112
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Any chance you guys can test-fit whether a 1st gen intake manifold can physically bolt to the 2nd gen FA24D motor? I'm sure Harrop and Edelbrock know already but they're not sharing at the moment...
Tatsu333 is offline   Reply With Quote
nowforitbs
Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. CSG Mike BRZ Second-Gen (2022+) — General Topics 25 11-04-2021 11:22 PM
Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. CSG Mike Tracking / Autocross / HPDE / Drifting 5 11-02-2021 05:57 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
Mike @ LSD Motorsports JDMenrique User/Vendor/Sponsor Reviews, Feedback, Comments 0 04-06-2013 07:13 PM
Mike at Czp _F-R-S_ User/Vendor/Sponsor Reviews, Feedback, Comments 0 12-01-2012 09:01 PM
