Old 08-13-2012, 12:03 AM   #99
Visconti
Drives: 05 STi
umm can some one link me ??!
Visconti is offline
Old 08-13-2012, 12:08 AM   #100
speed3
Walkin' on sunshine
speed3's Avatar
Drives: Ford BA MKII XR6 ute
https://www.facebook.com/Bulletcars
says they ran those numbers at 5psi boost.
Gutsy question. You're a shark. Sharks are winners, and they don't look back because they have no necks. Necks are for sheep.
speed3 is offline
Old 08-13-2012, 12:19 AM   #101
Visconti
Drives: 05 STi
I dont see a dynosheet anywhere....
Visconti is offline
Old 08-13-2012, 12:20 AM   #102
sw20kosh
Drives: 2013 Black FR-S
Their baseline HP # is quite low so their results are a bit understated I guess.
Don@AP made 32% increase in HP and 17% increase in torque at 3 - 4 psi.
It is obvious from Bullet's numbers that this size positive displacement supercharger makes its power in the low-mid range, while Don's turbo kit keeps that torque running all the way to redline (hence his huge HP increase).
sw20kosh is offline
Old 08-13-2012, 12:20 AM   #103
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
Originally Posted by sw20kosh View Post
They just updated facebook with a teaser of information:
This is what you have been waiting for, FTZ 86 Power figures
Initial Tune For Brisbane to Sydney Road Test / WTAC
Torque at 4000rpm up 31% from 136nm to 178nm
Peak Torque at 5750rpm up 25% from 160nm t0 200nm
Power at 4000rpm up 31% from 56kw to 73.5kw
Peak Power at 6750rpm up 21% from 106.8kw to 128.7kw
MORE TO COME
Peak power went from 143 hp to 172.5 (21% increase)
They dont provide boost #'s so it is really hard to say yet. I wasn't expecting much peak power from a supercharger like this but let's see what boost they are on
The proportionate gains are a good start tho'. Is this non-intercooled?
A2W IC and smaller pulley and this thing will fly!
Jordo! is offline
Old 08-13-2012, 12:21 AM   #104
sw20kosh
They haven't posted one yet. They just got done with that event. Prolly need a day or two to post all the info.
sw20kosh is offline
Old 08-13-2012, 12:21 AM   #105
Style
LXXXVI
Style's Avatar
Drives: Dahlia (Raven FR-S)
subbed....I want some toyota emblems
Style is offline
Old 08-13-2012, 12:22 AM   #106
sw20kosh
As far as proportionate gains are concerned, dont put too much stock in the "at 4000 rpm it made ___% increase" as this is just the factory tune's DIP region. Look at Don's turbo kit at 4000 rpm (which makes ~30-35% more torque thank stock, but only makes 17% more peak torque :
#'s without graphs can be misleading! The 4000 rpm range is not a fair comparison point because that can be tuned out as seen above.
It has an A2W already.
sw20kosh is offline
Old 08-13-2012, 12:30 AM   #107
speed3
Walkin' on sunshine
speed3's Avatar
Another post on their wall says water to air intercooler.
speed3 is offline
Old 08-13-2012, 02:02 AM   #108
serialk11r
Drives: '06 AM V8V Coupe
Yup, with a positive displacement SC you will see higher gains where volumetric efficiency was poor stock.
Power increase looks a little on the low side because they say it's a 1.4 pressure ratio design, and it's intercooled, whereas the power is only going up ~20%. Somehow I suspect they used a larger pulley first to try to be safe, instead of going up to the supercharger's optimal boost level.
EDIT: Okay oops just saw the 5psi thing. Supercharger can efficiently put out a little bit more boost than that.
serialk11r is offline
Old 08-13-2012, 03:52 AM   #109
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Yes its 5psi and WTA intercooled
The results shown a few posts back are correct indeed.
I was speaking to the manufacturer themselves just this morning
Available in 2 months as a complete system
Toyota 86 test driver
Tradewind is offline
Old 08-13-2012, 06:42 AM   #110
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
With this system, does boost start from idle?
Is there any graphs?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline
Old 08-13-2012, 07:03 AM   #111
d1ck
Drives: Black 2013 FRS
There are no graphs yet. They will be released soon I think.
d1ck is offline
Old 08-13-2012, 08:21 AM   #112
Visconti
Drives: 05 STi
Dynosheet or it didn't happen!
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
Sall (08-14-2012)
Our Silver Bullet - FT-86 SpeedFactory FT-86 SpeedFactory Member's Car Journals 151 10-06-2016 11:57 PM
