#99 |
umm can some one link me ??!
#100 |
Walkin' on sunshine
Drives: Ford BA MKII XR6 ute
Gutsy question. You're a shark. Sharks are winners, and they don't look back because they have no necks. Necks are for sheep.
#101 | |
#102 | |
Drives: 2013 Black FR-S
Don@AP made 32% increase in HP and 17% increase in torque at 3 - 4 psi. It is obvious from Bullet's numbers that this size positive displacement supercharger makes its power in the low-mid range, while Don's turbo kit keeps that torque running all the way to redline (hence his huge HP increase). |
#103 | |
Enjoy it, destroy it.
Drives: Datsun Racing Hen
A2W IC and smaller pulley and this thing will fly! |
#104 |
#105 |
LXXXVI
Drives: Dahlia (Raven FR-S)
subbed....I want some toyota emblems
#106 | |
As far as proportionate gains are concerned, dont put too much stock in the "at 4000 rpm it made ___% increase" as this is just the factory tune's DIP region. Look at Don's turbo kit at 4000 rpm (which makes ~30-35% more torque thank stock, but only makes 17% more peak torque : ![]() #'s without graphs can be misleading! The 4000 rpm range is not a fair comparison point because that can be tuned out as seen above. It has an A2W already. |
#107 | |
Walkin' on sunshine
Another post on their wall says water to air intercooler.
#108 | |
Drives: '06 AM V8V Coupe
Power increase looks a little on the low side because they say it's a 1.4 pressure ratio design, and it's intercooled, whereas the power is only going up ~20%. Somehow I suspect they used a larger pulley first to try to be safe, instead of going up to the supercharger's optimal boost level. EDIT: Okay oops just saw the 5psi thing. Supercharger can efficiently put out a little bit more boost than that. Last edited by serialk11r; 08-13-2012 at 02:25 AM. |
#109 |
Drives: 2006 Subaru Liberty EZ30 S/charged
Yes its 5psi and WTA intercooled
The results shown a few posts back are correct indeed. I was speaking to the manufacturer themselves just this morning Available in 2 months as a complete system
Toyota 86 test driver
#110 |
Pegasus White
Drives: 86
With this system, does boost start from idle?
Is there any graphs?
Driving: Pegasus White Manual GTS 86.
#111 |
Drives: Black 2013 FRS
| Our Silver Bullet - FT-86 SpeedFactory | FT-86 SpeedFactory | Member's Car Journals | 151 | 10-06-2016 11:57 PM |
