Old 02-19-2020, 12:00 AM   #99
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Originally Posted by M0nk3y View Post
Ride Height - Front Wheels 25" from floor to center of fender above wheel. Rear set for 1/8" Rake
Just curious, what made you decide on that ride height? I've gone back and forth between 24.75" and 25" up front with the same amount of rake. Having trouble deciding which to stick with for good though.
smg1138 is offline   Reply With Quote
Old 02-19-2020, 10:35 AM   #100
M0nk3y
Lower you go you start putting more stress on rear axles. TBH I just used finger measurements to determine stuff and used some SWAG to get me there
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
smg1138 (02-19-2020)
Old 02-19-2020, 01:01 PM   #101
SON1C
SON1C's Avatar
Drives: 2015 Series Blue BRZ WRB
Here I copied and pasted my setup and updated some items:
2016 Scion FRS:
Suspension:
MCS 2W Remotes - Custom Revalve & Coated Piston
400/350# Rates
Raceseng Camber Plates/Raceseng 1" Top Hats in Rear
Front: -4.2* Camber, 0 Toe
Rear: -2.5* Camber, 1/16" Total In
Karwan FSB
Mann Rear Bar set of Stiff (I adjust all the time though). RacerX Endlinks
RacerX LCA
Whiteline Subframe Insert Bushings
STi Engine Mounts
Whiteline Rear Transmission Bushing Insert
Engine:
aFe Momentum Intake
JDL 4-2-1 Header
JDL Ultra Quiet FP/OP Combo w/Cat
Perrin 2.5" Exhaust
MotoEast/XeroLimit Custom Dyno Tune
Perrin Oil Cooler
Wheels/Tires/Misc
AP Racing BBK w/Ferodo DS2500s
RPF1s 17x9 +35 with 245/40/17 RivalS 1.5s + Yokohama AO52s
Antigravity 680CA Battery w/PFTuning Tray
Grimmspeed Master Cylinder Brace
I don't know if I'm forgetting something, I probably am
Thanks for sharing this, aside from tires coils and driver mods, what else do you think has the most impact/benefit?
SON1C is offline   Reply With Quote
Old 02-19-2020, 03:26 PM   #102
strat61caster
strat61caster's Avatar
3. Setup (alignment, spring rates, bar, ride height, pressures, damper settings etc.)
4. Power
ineedyourdiddly
Old 02-19-2020, 09:48 PM   #103
racingfool
racingfool's Avatar
Drives: Miata
Originally Posted by skylinekin View Post
Are the JDM underbody panels legal for STX?
I think they are now OEM equipment on the 2017+ 86/BRZ's
I don't think update/backdate is legal in STX.
Originally Posted by MX-5RACER View Post
Tuesday/Thursday, Weds/Friday run order.
I would like that. Study and run one course and then have a day to study the other course.
racingfool is offline   Reply With Quote
Old 02-20-2020, 08:49 PM   #104
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
If the 2017+ MY car is legal why wouldn’t the parts from it be legal for updating 13-16 MY? All I am interested in are the under panels and 4.3 Differential.
skylinekin is offline   Reply With Quote
Old 02-20-2020, 10:54 PM   #105
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
No update or backdate is allowed. You can only use parts or accessories available for same model year.
Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 02-20-2020, 11:43 PM   #106
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
This would move you to SP.
Sent from my Pixel 3 using Tapatalk
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 02-20-2020, 11:57 PM   #107
strat61caster
Update/backdate is much more complicated and expensive on other chassis, I'm glad it's not allowed in Street Touring.
Shorter final drive is seen as a disadvantage of the newer cars, there's enough high speed elements on the national stage (~60 mph) that the extra mph in 2nd can be worth a tenth or more unless you're brilliant at shifting. But if you're on small lots that rarely see 55+ then the shorter FD might be a bit useful assuming you get pinched elements that don't have you traction limited on corner exit.
ineedyourdiddly
Old 02-21-2020, 08:17 AM   #108
skylinekin
skylinekin's Avatar
Understood, thanks guys
Old 02-24-2020, 09:56 AM   #109
steverife
For those of you with the Mann rear bar, how far does it sit from your muffler?
I planned on getting the Perrin catback, but ended up with the Invidia Q300 due to availability. I have maybe 1/8" to 1/4" clearance between the bar and the muffler.
I don't think that would hurt anything, but I'm sure that will make for an annoying sound. Trimming a bit off the washers (for the bolt that goes into the bushing bracket) would let me mount the bar a bit higher and possibly double my clearance.
Anybody deal with this and/or ditch the reinforcement blocks?
steverife is offline   Reply With Quote
Old 02-24-2020, 12:32 PM   #110
M0nk3y
Reinforcement blocks is just proper shimming to put the bar in ideal location relative to the endlinks. It's not really much to reinforce (especially since the bar is softer than OE rate).
I'll take a picture, but the way the perrin muffler comes up into the central muffler it basically Us right there, so I'm pretty sure it's far away from any contact
Kyle H. - #89 STX
steverife (02-24-2020)
Old 02-24-2020, 02:12 PM   #111
ein86
I hit cones.
Drives: 2015 FRS
I have at most 1/8" between my bar and muffler, got poly exhaust hangers and haven't had any issues with it hitting.
ein86 is offline   Reply With Quote
The Following User Says Thank You to ein86 For This Useful Post:
Old 02-25-2020, 08:22 AM   #112
steverife
So only had about 1mm clearance between bar and the piping to the muffler. Trimmed one side of the washer flat which let us mount the bushing bracket a little higher, giving about 9mm clearance. I think that's good, I hope.
My header came in last night, so hoping to get that in and get the car on the ground tonight. That'll give me about 2 weeks to deal with alignment and tune and getting tires mounted and whatnot before I leave for Dixie. May even get to hit the local at Bristol the week before, if work isn't looking too crazy.
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 03:21 PM
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 12:27 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 12:30 PM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 11:05 PM
