Old 08-02-2017, 01:30 PM   #99
strat61caster
strat61caster's Avatar
Originally Posted by radroach View Post
@strat61caster kinda scaring me for a minute about the plugs. I had NGK plugs put in, not sure which specific part but they've worked well.
I've been googling since that post, good info in this post:
http://www.ft86club.com/forums/showthread.php?t=8267
Which leads me to believe if you have a set of NGK's that are heat range 9, looks like the same as what's spec'd for the Nissan GTR you're probably in the ballpark (but not saving any money from what I can see).
The worst case I can think of is if you have plugs that are too hot you might get some knock and the car might pull a bit of timing. If they're too cold (unlikely as that's what makes them so expensive for OE in the first place) they would foul and lose performance prematurely.
https://www.ngksparkplugs.com/about-...rk-plug-basics
And here's some people suggesting alternate parts from NGK and Denso (which is where you posted nearly the exact same statement a year ago):
http://www.ft86club.com/forums/showthread.php?t=105658
Can you save money on spark plugs and be a happy car owner? Probably. But the cheapest NGK heat range 9 plug I can find is still ~$10, I'll pay the extra $10 to get what the OE spec is.
Edit: I've just realized what your profile pic is...
ineedyourdiddly
Old 08-02-2017, 01:42 PM   #100
radroach
Drives: car
@strat61caster
So far so good for 25k miles, but I do wish I had documented exactly what part number went in.
Thanks! I love Twin Peaks but I thought it was a cool pic because, well the different varieties of donuts represent the different styles / taste each owner applies to their own car making them different. Also I pulled the pic from this mixtape album: https://soundcloud.com/thephantomsrevenge/sets/mixtapes
Old 08-02-2017, 01:44 PM   #101
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
100,000 miles and not one issue. Maintenance costs are lower than many cars and are going to exist no matter what you buy. If left stock or properly modded it should not cost much to maintain at all.
im half way there lol. but 95% of my driving is highway so it doesnt gotta work much, just put her in cruise and coast to work
ImAdopted is offline   Reply With Quote
Old 08-02-2017, 01:58 PM   #102
Yep. I am about 98% highway with about another 98% of that on cruise.
Old 08-02-2017, 01:58 PM   #103
WNDSRFR
Drives: FR-S,GTI
Originally Posted by sunami88 View Post
...No one will ever convince me that 4-6 does any appreciable damage. Besides, by the time you're all the way into 5th it's exactly time to go to 6th give or take two seconds... Why bother fussing with the pedal at all? That's a lot more work on the throwout bearing because synchros.
Before it even happens I'll just ask if I should just make my own thread about this lol.
I agree completely. I've been driving manual transmission cars for 45 years and I ALWAYS skip gears. The only time I don't is when I'm driving a motorcycle with a sequential gearbox. The only cars I can think of with sequential gearboxes are F1 cars. And I've never had one of those.
Old 08-02-2017, 02:03 PM   #104
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
In my dad's old C5 Vette there was a dash light that told him to shift straight to 4th in order to save gas whenever he floored it in 1st gear lol.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 08-02-2017, 05:02 PM   #105
LudwigMiles
Drives: '13 BRZ
Agreed. If these are high compression plugs (whatever that means), $10 vs $20 is not worth treading weird internet rumor territory. Not a corner worth cutting, but still hard to fathom people are paying $20 for a plug. Talk about nickled and dimed.
LudwigMiles is offline   Reply With Quote
Old 08-02-2017, 05:39 PM   #106
strat61caster
It really isn't "nickled and dimed"
Combustion is not a simple science, engine design even less so. This is a ridiculously strung-out engine for the price point and there's zero economies of scale bringing the price point down, and that's been true from day 1. It was well known this sucker would be a unique bird with crazy high compression ratio and an oddball injection system and only a glimmer of hope that this engine would get re-used in another chassis like a base Impreza.
This car is incredibly economical for most of it's consumables, tires, brake rotors, oil filters, cabin filters, 25mpg average, hell for awhile my insurance was <$90/month.
But $20 for a spark plug and the world is ending. imo don't hold your breath for cheaper plugs to show up specific to the 86, like I said there's no economies of scale helping it out so there's little incentive for NGK or someone else to build a plug to this spec. People will figure out an alternative that's sufficient I'm sure, but I'll be surprised if a "standard off the shelf" plug is found.
If Denso was building >1 million per month of these plugs like they do for spark plugs that go into Camry's and Civics, yeah <$10 spark plugs all day long. As it stands they're likely barely making 1/2 million of these things per year.
If you want to know more about why they are expensive click on the NGK article I linked earlier about heat ranges, it covers the basics pretty well.
ineedyourdiddly
Old 08-02-2017, 11:10 PM   #107
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by paulca View Post
It's why I hated the sticky 2nd gear issue when my first 86 was cold. I would go for 2nd and the car would say "NO!" I always had a moment of conflict. I need 2nd, like now, but the car won't accept it. My choices are to force it or avoid it. Of course then I would return to neutral and ask again for 2nd. If it still didn't give it to me I would declutch in neutral and the try again. Usually this worked.
Thick gear lube drags the the innards to a halt as soon as it's disengaged from both ends. This happens in the middle of the shift while passing through neutral. There isn't enough purchase at the second gear syncro to easily overcome that drag.
If the gearshift is flicked quickly through neutral before the gears have a chance to stall, the second gear syncro doesn't have to drive the input side through the thick lube. That's the trick.
If the window of opportunity is missed, a quick double-clutch can spool up the input side for a second try.
The new 86 Pro gear box has been much nicer, but I have a minor issue with 1st. Sometimes it goes partly into first, but you can feel it hasn't completely mated. If I have time I neutral, declutch, clutch and retry which works most times, but I have taken the chance it's actually in gear enough and raised the clutch to feel that final little notch as it clicks fully in.
I'm sure it will settle ... only 230 miles on the clock so far.
What's the "Pro" gearbox? I'm quite familiar with your technique for encouraging first gear engagement. One of many old school tricks that, sadly, are on their way out.
Old 08-02-2017, 11:28 PM   #108
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Do you really think so? I'd bet against that. Not a big bet but still a bet. There's an awful lot of angular momentum in the spinning gear set and shaft(s). And once the gear box oil is warmed up it's not really like molasses.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 08-02-2017, 11:57 PM   #109
Ultramaroon
not playing cards
100% positive. Not after it's warm, though.
Been preaching and proving this to skeptics for a couple winters now. Try it.
Old 08-03-2017, 01:27 AM   #110
e_lunatic
Drives: 2015 Scion FR-S
I'm totally with you on this.
guys will spend however much on FI and other random bits but $100 for plugs and some people lose it haha
e_lunatic is offline   Reply With Quote
Old 08-03-2017, 01:38 AM   #111
LudwigMiles
Drives: '13 BRZ
No one is "losing it", and I'm not spending a dime on useless mods, either.
I've just never heard of spark plugs that cost more than $3.
Ever spend $105 on a hamburger? I didn't think so.
That is all. Carry on.
Old 08-03-2017, 02:35 AM   #112
strat61caster
So for giggles I looked up spark plugs on a couple random vehicles on Rock Auto, in the process I found out that they list a Champion REA6MC plug that is ~$7 ea.
I was clicking through to see what spark plugs cost on other vehicles, most have <$5 plugs with a few $5-$8 for the laser iridium platinum double gold, but worth mentioning these three:
2007 F150, 5.4L V8: $6-$12
RX-8, $14-$24
Current Ferrari 6.3L V12: $2.90
Edit: I've spent over $50 on a steak and plan on spending near or over $100 on one in the future, is that close enough?
ineedyourdiddly
Just can not do this anymore rskdsk Other Vehicles & General Automotive Discussions 79 02-27-2014 06:13 PM
not for sale anymore whitefrs Engine, Exhaust, Bolt-Ons 44 10-28-2013 03:34 PM
not for sale anymore whitefrs Engine, Exhaust, Bolt-Ons 7 10-23-2013 10:31 PM
I can't take it anymore Terrapin77 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 09-02-2013 08:32 PM
Does anybody use their blinker anymore? Shagaliscious Off-Topic Lounge [WARNING: NO POLITICS] 51 11-20-2012 03:14 PM
