#99 |
Drives: BRZ, STI, GT350R, Supra, 987.2
Installed a new product of ours over the weekend. Another part someone asked us to come up with that we were able to help with.
It has been done multiple times before on other chassis, nothing ground breaking here. Our units are 100% high-temp carbon, no fiberglass. Instead of typical gel coat being used, which yellows over time with heat, these units are polished for a finish that won't degrade over time. Looks very motorsport-esque, very neat. ![]() ![]() ![]() ![]() ![]() ![]() Thanks, Eric Last edited by VerusEric; 09-04-2017 at 10:47 PM. |
#100 |
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
#101 |
Drives: 2015 CWP Limited BRZ
What tuning options did you go with?
addictedcollectibles.r/My IG
'86 E30 (Project) 'VARIS Widebody http://www.ft86club.com/forums/showthread.php?t=103676 |
#102 |
Drives: GT86
Welp, I guess I know what I'm buying in the near future! - Guys you really need to find a distributor for Asia so I can give you more money, more often :P
#103 | |
EcuTek for right now. It's doing what we need it to; it, of course, has its shortcomings but the price point is quite appealing compared to stand alones.
We did some more testing on our rear diffuser *without diff covers* and *installed at the lowest setting* to fit the Tomei Type 80 I'm currently running. This time with flow visualization fluid. Few neat findings: -The air does indeed follow the curve up on the rear upturn lip, which proves it functions. -We can assume most of the diffuser surface has clean attached flow from the test section. -We found a vortice coming off the exhaust cutout location. Pretty neat to capture it in our opinion. Something to keep in mind, the faster you go, the more air will want to stay attached. This isn't intuitive as you'd think air would be less likely to curve around objects at faster speeds. [ame="https://www.youtube.com/watch?v=7kspqMyrKpM"]Velox Motorsports FRS / BRZ Diffuser Flow Visualization Testing - YouTube[/ame] Thanks, Eric |
#104 |
The clear question then is when is the product coming out that addresses the exhaust disturbance???
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
#105 | |
![]() Here's a pretty well-executed underbody for a production car using production pieces we offer, IMO. Thanks, Eric |
#106 |
Drives: 15 BRZ LTD, 05 FXT
In your opinion, which parts make the biggest difference on their own?
What order do you see parts making the biggest to smallest difference with regards to aero? And which parts really need item A and item B to shine? Thanks!
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
#107 | |
I was thinking more along the lines of a new exhaust system and diffuser designed to work together, which I think you may have also daydreamed about back when initially designing this system.
#108 | ||
If you're looking for a reduction in lift, the front splitter will net the largest gains there. If you're looking for a reduction in drag, the diffuser certainly does that, even with the stock exhaust (without stock exhaust, the gains are even larger). The interesting thing is that splitters and diffusers do work with one another. The diffuser influences the splitter and the splitter influences the diffuser, they work together to actually help each other. Not saying it's a night and day difference but each one becomes more efficient when used together. This information is what we observed through our CFD analysis. Quote:
.Thanks, Eric |
#109 |
Awesome responses. Thanks for your Time @VeloxEric that really helps to understand that it's engineered as a system, and the two big components are the big wins.
#110 |
So we are having a cold spell in Arizona currently with ambients in the high 90s and low 100's. Figured I'd share radiator temps again with the slightly lower ambient temps.
Water temps are down about 2 degrees Celsius. Instead of 91, it typically sits right around 89 now at speeds. At low air speeds, it climbs up to 91ish. With the tune getting dialed in every outing I'm able to do a bit more spirited driving as well and temps are unaffected thus far. Oil does get a bit more warm when driving harder, 110-115 is the highest I've seen so far. The dual port internal wastegate is currently hooked up as a standard single port wastegate using the 3-port solenoid. It appears I can no hit somewhere between 8 and 14 PSI to redline. We will likely be trying out the 4-port for even more control. Still currently dialing in the 1300s but it's getting closer for sure !Thanks, Eric |
#111 |
@VeloxEric do you know if the the brake duct kit clears the IC pipes on the JR kit?
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#112 | |
Started a thread on the radiator for anyone potentially interested in it: http://www.ft86club.com/forums/showthread.php?t=109230 We are finally getting close to releasing our AOS that has been in development for a long time. It's been proven on NA and moderate turbo'd cars now over 3 years. Below are some preliminary pictures of CAD and raw billet. ![]() ![]() ![]() ![]() ![]() Thanks, Eric Last edited by VerusEric; 09-04-2017 at 10:49 PM. |
| Verus Engineering Rear Wing Development | VerusEric | Tracking / Autocross / HPDE / Drifting | 203 | 07-05-2021 09:15 AM |
| FRS / BRZ Intake Manifold - Development Thread - FT-86SpeedFactory by Velox | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 712 | 12-11-2018 10:13 PM |
| Hancha BRZ/FR-S/GT86 Aero Parts Development Thread | Hancha Group | Cosmetic Modification (Interior/Exterior/Lighting) | 57 | 03-24-2014 05:40 PM |
| Raceseng | Development FT86 | Build Thread | Raceseng | Member's Car Journals | 17 | 06-06-2013 09:22 AM |
