Old 09-17-2017, 07:49 PM   #1093
BuffDriver
Drives: 2016 Subaru BRZ
Once again Steve99 should be thanked by the great number of people who have benefited from his time and trouble to advise and help us learn. It goes well beyond just clicking on the 'thanks' button on one of his posts.
I wonder how many thousands of people have Googled an issue about their cars and visited this forum and found better understanding because of the years of patience and knowledge Steve99 displays time after time helping people learn. He answers the questions of the newbie which have been answered before because I think he knows just being told 'do a search' will drive them off. By taking the time to re-answer he enriches us because the newbie stays and learn and eventually contributes. I Have read thousands of pages on this forum on every subject and I have found his presence on so many threads, always helping and not scorning their ignorance, just mentoring time after time. That's pretty rare and special in this world.
Thanks Steve
Edelbrock SC kit w/ ECUtek tune, Oil Cooler, UEL catted header, Perrin 2.5 Overpipe n Catted midpipe, 3.0 Catback resonated (all exhst ceramic coated), TRD short shifter, MTEC clutch n trans springs, Trans: Pentosin MTF2, Diff: Motul 75W90, Whiteline trans bushing, 3/4" clutch slave cyl., Ferodo DS2500 pads w/Motul 600 fluid, 17x8 wheels n 235/45ZR-17 tires
BuffDriver is offline   Reply With Quote
The Following 4 Users Say Thank You to BuffDriver For This Useful Post:
DarkSunrise (09-17-2017), Gums (09-17-2017), Teseo (09-18-2017), tmichel (09-21-2017)
Old 09-18-2017, 04:18 AM   #1094
pym19109
WRBLUE BRZ
pym19109's Avatar
Dose changing differential ratio require specific tune ? (Like for 4.5 or 4.8)
pym19109 is offline   Reply With Quote
Old 09-18-2017, 06:53 AM   #1095
churchx
churchx's Avatar
Drives: 2014 GT86
No.
The Following User Says Thank You to churchx For This Useful Post:
pym19109 (09-18-2017)
Old 09-18-2017, 08:39 AM   #1096
steve99
No ,as above, it doesn't require engine retune
However with manual cars the gear indicator in dash display will dispaly incorrect gears unless you change the gear determination threshold tables in the ecu (tune). As thes determine gear by relating engine rpm to speed.
The spedometer will be fine as its worked out off the wheel speed sensors.
Old 09-18-2017, 09:37 PM   #1097
bzdont
Drives: 2014 BRZ Limited SWP
Whenever I open Openflash Manager, it's almost always very slow to search for and download updates -- many times it never finishes and just hangs, and I have to close it and re-open, then it does it again. This is with the latest version, 1.28.0.
Is there any way to skip the update check?
bzdont is offline   Reply With Quote
Old 09-18-2017, 10:57 PM   #1098
Vin
Vin's Avatar
Drives: 2012 GT86 EU-spec
I always disconnect from the internet before starting the open flash software. You should also be able to block the address in the Windows host file, but I didnt try that (yet)
Vin is offline   Reply With Quote
Old 09-20-2017, 11:40 PM   #1099
Freerider
Drives: 2015 f150 crew cab 4x4 '13 FRSraven
hey guys! got my OFT today.I watched some youtube videos and read about installing it. It seemed to read the file just fine but when it was done it said to unplug the OFT. However, i thought i knew better and just turned key off (all the way i think?hope). I clicked "tune" and both read and write are greyed out. I did a lil reading on this thread and tried to hook my OFT to my laptop and i had the same tiny useless OFT tablet graphic. My next move is to call sometime tomorrow, but i'll sleep better knowing my tablet isnt ruined....or my car for that matter. i tried unplugging/plugging in several times and its always the same.."read" & "write" are grey and wont do anything. Any help will be appreciated.
BTW Ive tuned my last two trucks so im not a total noob but i feel ive f'd up here
Freerider is offline   Reply With Quote
Old 09-20-2017, 11:59 PM   #1100
Jasonb
Drives: 17 Series Yellow BRZ
Are you sure there is a tune loaded onto the oft? I asked for mine to be preloaded and assumed it was. After reading my stock rom, I thought I was all ready to write a tune to the car, but write was also greyed out on mine. Called shiv and he emailed me the right tunes, loaded them on and then was able to write a tune to my car.
Jasonb is offline   Reply With Quote
The Following User Says Thank You to Jasonb For This Useful Post:
Freerider (09-21-2017)
Old 09-21-2017, 01:12 AM   #1101
steve99
A. Don't Panic :-)
B. Go to oft web site download latests tunes upload to oft and you will be good. See oft tips link below.
Read is greyed out as your stock tune read into tablet successfully
Write is grey as tablet did not have your tune calid onboard will need to be manually downloaded
If its a 2017 you will need to talk to oft guys for tunes otherwise just download
Old 09-21-2017, 06:10 PM   #1102
Freerider
It's blank. Which sux BC I got OFT so I wouldn't have to do this. Btw, I bought new from ft86 speed factory...might be why it's blank.
Old 09-21-2017, 06:12 PM   #1103
Freerider
A. Don't Panic :-)
When I hook my tablet up to laptop its just the tiny oft graphic....is that a problem? Haven't yet called anyone btw.
Old 09-21-2017, 07:21 PM   #1104
Jasonb
Have you installed the open flash manager program on your computer?
Old 09-21-2017, 07:57 PM   #1105
sandy s
Drives: 86 gt
Would the unit from the U S be the same as one from Australia?? Cheers Sandy
sandy s is offline   Reply With Quote
Old 09-21-2017, 08:03 PM   #1106
sandy s
Drives: 86 gt
Thanks Steve Dont know how I missed it.Cheers Sandy
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
