#1093 |
Drives: Subaru BRZ 2019 A/T JDM
Hello, I'm trying to flash OFT stage2 on my 2019 JDM BRZ AT with CALID : ZA1JU00B00G. Any substitute ROM available?
#1094 | |
Drives: 86 GT
Or if you need help you can PM me - where are you located? Am located in MY as well.
DIY stuff at Compelica Works
#1095 |
Drives: 2019 Subaru BRZ
A kind user on another forum sent me their stock ZA1JN00J for the archives:
ZA1JN00J AM6 H4NA KS MT (2017) BSW_12CYH4N_DI_MC5 Ver 1.00r1 |
#1096 | |
Final_Fueling_Base for A01G, K00G, V00C (and why not to use it)
Code:
paramname = Final_Fueling_Base paramid = 0xfff8a090 ; V00C isfloat = 1 scalingrpn = x,14.7,* Code:
; volumetric efficiency from VGE mafscaling WOT Best VVT tab ; variant: IAT celsius (no scalingrpn), MAP kilopascals (scalingrpn=x,0.133322368,*) type = calc paramname = VE scalingrpn = MAF,MAP,1000,*,IAT,273.15,+,287.05,*,/,1000,*,/,121.9254,RPM,*,3456,/,0.0283,*,60,/,/,100,* Code:
fVar1 = (ENGINE_final_fueling_base - ENGINE_dipi_ect_ratio) - FLOAT_fff8aaf8;
if (BOOL_fff8a16e) {
/* BRZ path, uses Injector_Flow_Scaling_BRZ=263.1 */
_port_ipw = ENGINE_fueling_port * 263.1;
_direct_ipw = (ENGINE_fueling_direct +
ENGINE_Low_Pulse_Width_Fuel_Injector_Comp * ENGINE_low_fueling_comp *
ENGINE_fueling_port) * 263.1;
_ipwA = (CALC_fueling_cylA_a100 + CALC_fueling_per_cyl_a0e0[0]) * 263.1;
_ipwB = (CALC_fueling_cylB_a104 + CALC_fueling_per_cyl_a0e0[1]) * 263.1;
_ipwC = (CALC_fueling_cylC_a108 + CALC_fueling_per_cyl_a0e0[2]) * 263.1;
_ipwD = (CALC_fueling_cylD_a10c + CALC_fueling_per_cyl_a0e0[3]) * 263.1;
fVar1 = fVar1 * ENGINE_load_multiplied;
fVar1 = ((1.0 - ENGINE_fueling_port_ratio_a12c) * fVar1 +
ENGINE_fueling_port_ratio_a12c * fVar1) * 263.1;
else {
/* non-BRZ path, so to speak. */
/* ENGINE_final_fueling_total = Injector_Flow_Scaling=12176.6 * [long messy codepath]; */
_total_ipw = (ENGINE_stft_raw + ENGINE_ltft_raw + ENGINE_fueling_adj_ab88) *
ENGINE_final_fueling_total;
_port_ipw = _total_ipw * ENGINE_final_fueling_base;
_direct_ipw = (ENGINE_low_fueling_comp * _port_ipw + 0.0) *
ENGINE_Low_Pulse_Width_Fuel_Injector_Comp;
_ipw_base = ENGINE_low_fueling_comp * _total_ipw;
_ipwA = (ENGINE_ipw_A * CALC_DiPi_Fueling_clftu_iarlael_cylA * _ipw_base + 0.0) *
_ipwB = (ENGINE_ipw_B * CALC_DiPi_Fueling_clftu_iarlael_cylB * _ipw_base + 0.0) *
_ipwC = (ENGINE_ipw_C * CALC_DiPi_Fueling_clftu_iarlael_cylC * _ipw_base + 0.0) *
_ipwD = (ENGINE_ipw_D * CALC_DiPi_Fueling_clftu_iarlael_cylD * _ipw_base + 0.0) *
fVar1 = (fVar1 * ENGINE_final_fueling_total * ENGINE_low_fueling_comp + 0.0) *
_port_ipw_with_low = _port_ipw * ENGINE_Low_Pulse_Width_Fuel_Injector_Comp;
upper_bound = 262136.0;
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
