Old 04-21-2014, 03:52 PM   #1093
DC2R
Drives: 2014 Scion FR-S
Originally Posted by TmP View Post
So:
No lift shift - YES
CEL kill - YES
2 step - YES
2 step is a 2nd rev limiter for when you are on the clutch waiting to launch.
So being you say it does have launch control, I take that as a yes.
How is the no lift shift implemented? Via ignition cut or fuel cut or both?
Is it possible to run just ignition cut, no fuel cut? That's just too much fun
Thought this not implemented on B01C bin yet
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
Old 04-21-2014, 05:05 PM   #1094
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Definitely a different sound - especially in the mid-range... and noticeably more torque there, as well.
This is the first time I've ever done anything like this. Pretty impressed with the results so far - nice job, Shiv. I'm guessing the addition of the ESC and related tune here in a month (hopefully) is going to be a revelation.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 04-21-2014, 05:25 PM   #1095
robwbright
Graphs from Log 2.
BTW, in Vishnu Analysis, how do I get it to view only one set of data? If I select Throttle as View 1, then I can't seem to remove Throttle as View 1... and if I select something else as View 1, then it simply overlays it - and it stays there even after closing and reopening the log file. The only way I can seem to start from scratch is by renaming the log file. I'd like to be able to remove a graph that I was looking at without renaming the log file...
2006 Saab 9-3 2.0t
Old 04-22-2014, 04:46 PM   #1096
robwbright
After a couple days, the seat of the pants test tells me the car is definitely more powerful/quicker. Again, the biggest difference to me is in the midrange.
2006 Saab 9-3 2.0t
The Following User Says Thank You to robwbright For This Useful Post:
Blu-by-U (04-22-2014)
Old 04-23-2014, 01:47 AM   #1097
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Wait until you try E85 you will never go back to 93.
Old 04-23-2014, 02:04 AM   #1098
Daesondei
Daesondei
Drives: Scion FRS
:beer: cheers to that! Im in so cal and gas stations that carry E85 are scarce. E85 is a 25minute drive away. But well worth it. Torque dip gone. Rolled the GMR and there was a noticeable difference! Didn't find myself down shifting as much as I usually do, searching for more power.
Sent from my SAMSUNG-SGH-I577 using Tapatalk 2
"No greater love is this, than a man laying down his life for his friends... I call you friends."
Daesondei is offline   Reply With Quote
The Following User Says Thank You to Daesondei For This Useful Post:
NyC Zn6 (04-23-2014)
Old 04-23-2014, 02:42 AM   #1099
luuser75
luuser75's Avatar
Drives: M/T Raven FR-S
by any chance is e85 bad for the longevity for this car?
luuser75 is offline   Reply With Quote
Old 04-23-2014, 03:33 AM   #1100
steve99
To early to tell.
Some people have maybe 20k+ on E85 , have not heard of any specific E85 blowups problems yet on these forums. Not really a lot of miles or time though.
Cars are E10 compatible so fuel system components "should" be ok but lot more ethanol in E85.
E85 can absorb water which may cause corrosion problems
E85=more power = more stress so that alone will cause more wear & tear, as would any other power increasing mod.
Consensus seems to be change oil twice as often (oil dilution), make sure your oil is E85 compatible
Run a tank of petrol (gass) every 6 or so tanks of E85 apparently to clean off deposits on injectors, must be the additives as I presume as ethanol burns very clean.
luuser75 (04-23-2014)
Old 04-23-2014, 04:33 AM   #1101
robwbright
I'm sure it's great, but I'll almost certainly never will go E85. The closest station is an hour from here and if I wanted gas mileage that bad I'd buy an F250. LOL.
I do plan, however, to go Phantom ESC.
2006 Saab 9-3 2.0t
Old 04-26-2014, 03:10 PM   #1102
robwbright
I have a bit of a problem here. I updated the OFT last night and then hooked it up to the car this morning and took off driving with the live readings on the screen (AFR, fuel trim, etc...).
After a couple minutes, all of the text disappeared from the left side of the screen. I unplugged it and plugged it in again, restarted the car, etc... still no text.
Any ideas?
2006 Saab 9-3 2.0t
Old 04-26-2014, 03:14 PM   #1103
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Any ideas?
You need to use use OpenFlash Manager 1.07.1 to update the Template. I'm guessing you are still using 1.07?
Old 04-26-2014, 03:18 PM   #1104
robwbright
I was. Just noticed there was another update. Uninstalled old version of OFM and updated OFT again with the SLT file. Going to test it again.
2006 Saab 9-3 2.0t
Old 04-26-2014, 03:25 PM   #1105
robwbright
Problem solved. New OFM+Updated OFT=text is back. Thanks!
2006 Saab 9-3 2.0t
Shiv@Openflash (04-26-2014)
Old 04-26-2014, 03:50 PM   #1106
Shiv@Openflash
Drives: 2013 FRS
Fantastic Can you update your post in the other thread with the solution?
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 04:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 04:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 09:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
