07-19-2014, 06:26 PM | #1093 |
Drives: 2014 Scion FR-S
Anyone have any advice for USB OBD adapters and torque? Send like same problem I fad with Bluetooth before where the pins weren't all making contact. I tried bending pins all different ways but no luck. Torque sees it but can connect to ecu
Sent from my GT-N5110 using Tapatalk |
07-19-2014, 06:34 PM | #1094 |
Drives: 86 GTS
I just set mine up with dashcommand
Wired usb to obdii. Elm 327 eBay knockoff I had lying around. |
07-19-2014, 08:40 PM | #1095 | |
Sent from my SM-N900T using Tapatalk |
07-19-2014, 08:46 PM | #1096 |
Drives: 86 GTS
Nah possibly selected usb instead of bt but I think it auto detected anyway.
07-20-2014, 07:02 AM | #1097 |
Drives: 86 GTS
Is it fine to leave these things with the 2 day standby option on? I have no idea how much battery they would drain?
07-20-2014, 08:04 AM | #1098 |
Drives: Subaru BRZ Limited
07-20-2014, 10:32 AM | #1099 |
Drives: 2013 WR Blue Limited Manual BRZ
The Following User Says Thank You to Deathalo For This Useful Post: | 86•BRZ (07-20-2014) |
07-20-2014, 11:39 AM | #1101 |
Drives: 2013 GBS BRZ Limited
Thanks Still need to do the gauge cluster though.
07-20-2014, 04:59 PM | #1102 |
super frustrated. running Rom with CarHome disabled and rooted. using hotspot for wifi. cant get pandora to run without skipping songs nonstop(never starts playing). i try using bluetooth streaming Pandora from my phone but as soon as phone connects to car Pandora app goes full retard and stops responding. i have already factory reset.
07-21-2014, 02:50 AM | #1103 | |
Drives: Scion FR-S Ultramarine
for anyone that cares about how things sound and haven't already figured this out themselves: the stock eq sucks, the viper eq is way better, but the eq in poweramp is even better at least for noobs like me. if you can use poweramp for everything then you're good to go. for anyone that is like me and uses itunes for your music needs but don't want to stream from your phone then the next best thing is to plug in a usb or load up a microsd with your music. this free app works really well and poweramp reads it fine after setting it to read the usb. http://www.ericdaugherty.com/dev/itunesexport/ has anyone experienced a buzzing or hissing? like it's there constantly no matter what audio is playing. like no matter what app or if it's audio or video or even if nothing is being played. no buzz/hiss when it's muted though. i rooted pretty quickly after receiving and did the viper install pretty soon after too so i can't remember if i had it before that or not. i know previously i used a ground loop isolator to resolve this when i had a tablet install, but i don't think that would help in this instance. |
The Following User Says Thank You to phanguy For This Useful Post: | Pwolf (07-21-2014) |
07-21-2014, 02:57 AM | #1104 |
Drives: 86 GTS
In poweramp
Settings > Audio Engine > Advanced Tweaks > Direct Volume Control DESELECTED This puts volume back to the level it should be. |
The Following User Says Thank You to 86•BRZ For This Useful Post: | phanguy (07-21-2014) |
07-21-2014, 11:27 AM | #1105 |
07-21-2014, 12:37 PM | #1106 | |
Drives: gray
Like you said, it is there for any program that uses the audio. |
Similar Threads | ||||
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo | SHIFTER | Electronics | Audio | NAV | Infotainment | 16 | 06-13-2017 06:23 PM |
Android, bluetooth, Music, and the FR-S stock pioneer stereo | JayNutter | Electronics | Audio | NAV | Infotainment | 27 | 12-18-2014 03:54 AM |
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 | SHIFTER | Electronics | Audio | NAV | Infotainment | 29 | 04-07-2014 04:58 AM |
