Old 07-19-2014, 06:26 PM   #1093
DC2R
Drives: 2014 Scion FR-S
Anyone have any advice for USB OBD adapters and torque? Send like same problem I fad with Bluetooth before where the pins weren't all making contact. I tried bending pins all different ways but no luck. Torque sees it but can connect to ecu
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
Old 07-19-2014, 06:34 PM   #1094
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
I just set mine up with dashcommand
Wired usb to obdii. Elm 327 eBay knockoff I had lying around. Name:  ImageUploadedByTapatalk1405809252.486024.jpg
86•BRZ is offline   Reply With Quote
Old 07-19-2014, 08:40 PM   #1095
DC2R
Wired usb to obdii. Elm 327 eBay knockoff I had lying around. Attachment 85551
Any special settings?
Sent from my SM-N900T using Tapatalk
Old 07-19-2014, 08:46 PM   #1096
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Nah possibly selected usb instead of bt but I think it auto detected anyway.
Old 07-20-2014, 07:02 AM   #1097
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Is it fine to leave these things with the 2 day standby option on? I have no idea how much battery they would drain?
Old 07-20-2014, 08:04 AM   #1098
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Originally Posted by Pwolf View Post
HU installed:
Those blue LEDs look great!!
ericmpena is offline   Reply With Quote
Old 07-20-2014, 10:32 AM   #1099
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Completely ok, will definitely not drain your battery.
Deathalo is offline   Reply With Quote
The Following User Says Thank You to Deathalo For This Useful Post:
86•BRZ (07-20-2014)
Old 07-20-2014, 10:47 AM   #1100
DC2R
Yeah think about how much power a tablet uses in standby.you could probably leave it on for months just fine.
The Following User Says Thank You to DC2R For This Useful Post:
86•BRZ (07-20-2014)
Old 07-20-2014, 11:39 AM   #1101
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
Thanks Still need to do the gauge cluster though.
Pwolf is offline   Reply With Quote
Old 07-20-2014, 04:59 PM   #1102
DC2R
super frustrated. running Rom with CarHome disabled and rooted. using hotspot for wifi. cant get pandora to run without skipping songs nonstop(never starts playing). i try using bluetooth streaming Pandora from my phone but as soon as phone connects to car Pandora app goes full retard and stops responding. i have already factory reset.
Old 07-21-2014, 02:50 AM   #1103
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
i just tested pandora from my nexus 5 streaming to the dashlinq and it worked fine. i'm also rooted and did the viper install.
for anyone that cares about how things sound and haven't already figured this out themselves: the stock eq sucks, the viper eq is way better, but the eq in poweramp is even better at least for noobs like me. if you can use poweramp for everything then you're good to go.
for anyone that is like me and uses itunes for your music needs but don't want to stream from your phone then the next best thing is to plug in a usb or load up a microsd with your music. this free app works really well and poweramp reads it fine after setting it to read the usb.
http://www.ericdaugherty.com/dev/itunesexport/
has anyone experienced a buzzing or hissing? like it's there constantly no matter what audio is playing. like no matter what app or if it's audio or video or even if nothing is being played. no buzz/hiss when it's muted though. i rooted pretty quickly after receiving and did the viper install pretty soon after too so i can't remember if i had it before that or not. i know previously i used a ground loop isolator to resolve this when i had a tablet install, but i don't think that would help in this instance.
phanguy is offline   Reply With Quote
The Following User Says Thank You to phanguy For This Useful Post:
Pwolf (07-21-2014)
Old 07-21-2014, 02:57 AM   #1104
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
In poweramp
Settings > Audio Engine > Advanced Tweaks > Direct Volume Control DESELECTED
This puts volume back to the level it should be.
The Following User Says Thank You to 86•BRZ For This Useful Post:
phanguy (07-21-2014)
Old 07-21-2014, 11:27 AM   #1105
phanguy
phanguy's Avatar
In poweramp
Worked. thanks!
now if we can get the insufficient space thing worked out then i can try installing tablet talk again...
Old 07-21-2014, 12:37 PM   #1106
bwthor
Drives: gray
Yeah, that hiss is driving me crazy. Open up a music player, and turn the volume up. Hit pause, and the hiss is there for a couple seconds, then silence. Hit play and it starts back up again.
Like you said, it is there for any program that uses the audio.
bwthor is offline   Reply With Quote
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
