Old 08-08-2020, 02:16 PM   #10907
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by BlOody_BoOger View Post
Oh nice how much boost you pushing, lol imagine sticking a phantom on with your srpintex. Damn the low end tq you'd make.
Yeah that would be insane. I think pairing with a centrifugal charger though would give you the nice peak top end of a CC but the ESC give you the low end of a PD best of both worlds.
An ESC and PD would be nuts but probably just spin tires and bend rods.
Old 08-08-2020, 02:46 PM   #10908
86TOYO2k17
You might have space to run this instead of the 90degree elbow after the Y pipe before MAF housing.
http://www.frozenboost.com/air_water...ers-p-214.html
Get a water pump wired to a tap a fuse in cabin fusebox lots of ign on ootions.
A small reservoir you can mount anywhere as long as its the highest point
And a water to air radiator in place of your air to air intercooler would be oretty easy to setup and provide good cooling even when cruising ad it sill have both air sources going through it.
Old 08-08-2020, 05:10 PM   #10909
BlOody_BoOger
BlOody_BoOger's Avatar
Did a quick boost comparison between my last data log when I had single ESC and now with twin ESC
Rpm. Single. Twin
3k. 3.2psi. 4.3psi
Peak boost 4.2psi. @3200 7.1psi @3400
4k. 3.7psi. 5.9psi
5k. 3.2psi. 4.6psi
6k. 2.3psi. 3.4psi
7k. 1.3psi. 1.6psi
7.5k. 1.1psi. 1.3psi
BlOody_BoOger is offline   Reply With Quote
Old 08-08-2020, 05:45 PM   #10910
86TOYO2k17
Rpm. Single. Twin
3k. 3.2psi. 4.3psi
4k. 3.7psi. 5.9psi
5k. 3.2psi. 4.6psi
6k. 2.3psi. 3.4psi
7k. 1.3psi. 1.6psi
Have a battery voltage at those rpm/psi lvls before/after?
Old 08-08-2020, 05:50 PM   #10911
BlOody_BoOger
What do you mean? Like phantom meter voltage?
Old 08-08-2020, 06:30 PM   #10912
86TOYO2k17
Yeah, just curious if boost is falling off faster because of double draw. Or if you start WOT at 5500rpm instead of 3500rpm do you make more boost at 6000rpm?
Old 08-08-2020, 06:37 PM   #10913
BlOody_BoOger
Each charger has its own set of batteries. And i started with wot both at the same time. But boost kinda fell the same for both roughly 1psi by each 1000rpm up till 7k when it was almost the same but I think that doe to the engine sucking much more air. Either way on a single phantom peak boost was at 3200rpm 4.2psi on the twin set up I was still hitting 4.6psi at 5000rpm
Old 08-08-2020, 06:41 PM   #10914
jflogerzi
jflogerzi's Avatar
Seems like a cool project but you seem to have the skills to install a more standard FI kit. SBD kits come to mind.
2013 Series 10 FRS #553
Old 08-08-2020, 06:50 PM   #10915
BlOody_BoOger
Lol yes I probably could've just installed an actual kit myself. Especially if it came with instructions. I pretty much built this whole setup from scratch aside from the phantoms kits themselves. But everything else I pretty much had to analyze every step beforehand everything seeing if a 4in filter would fit in the bumper to figuring out how mount the 2nd set of batteries.
Old 08-10-2020, 10:44 AM   #10916
BlOody_BoOger
So as we get closer to finalizing the tune on the twin phantoms I thought I'd post these Vdyno runs.
So here is a quick comparison (first image) between the 6th and 7th revisions of the tune. @steve99 is pretty happy with the tune. He thinks he can squeez out another another 5 ponies we just gotta make sure fuel trims are pretty stable when the turbskies are off, this way the tune is happy with and without boost. Anyways I'm pretty happy with it. I was really hoping to hit 250whp but how it is I love it cuz the tq feels amazing. This runs were done in 90-95 degree weather. So compared to my last vdyno from when I only had one phantom (second image) makes me believe I'll hit 250whp once winter comes around.
Old 08-10-2020, 10:54 AM   #10917
jflogerzi
jflogerzi's Avatar
What were you making with just the single? Looks pretty damn good and a pretty cool setup
Old 08-10-2020, 10:55 AM   #10918
BlOody_BoOger
Single is the second image 229whp/206wtq but that run was done in 60 degree weather. That's why It doesn't seem like a huge bump in hp. But I'm sure if I do runs how the car is right now in 60 degree weather I think I'll see another 10hp
Old 08-10-2020, 11:31 AM   #10919
WNDSRFR
Drives: FR-S,GTI
Yeah
I noticed with just the single ESC there is a major power increase with cooler temps. The difference between running at 90F and 50F is like the difference between 91 octane and E85.
Old 08-10-2020, 11:51 AM   #10920
86TOYO2k17
Originally Posted by WNDSRFR View Post
Yeah
are you talking difference in ambient temps pre blower, like stock MAF location on traditional ESC setup? or have you relocated the MAF to post blower and compared dyno runs or pull times between post 90F and 50F post blower temps?
ambient temps going into the blower will be much more of an impact to power compared to post blower temps.
Every 5.4F is about 1% less air density. but this would only apply to pre blower.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
