Old 04-20-2014, 02:47 PM   #1079
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Got my OFT!!!! Still only have 600 miles on the car, really hard to not go ahead and flash...Now just waiting on OFH
Cockatoo is offline   Reply With Quote
Old 04-20-2014, 02:50 PM   #1080
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Originally Posted by robwbright View Post
My question is: Does the OFT flash make any change to the idle stability issue? Whether it does or not, it seems pointless to go get the reflash at the dealer if I'm just going to be flashing again with the OFT.
If it's based off the B01C reflash, which I believe it is, then no - the fix is already incorporated. I check out the rom in comparison to the previous revisions, there are changes to various areas of the idle logic (most of which is also not defined in any of the current solutions).
Td-d is offline   Reply With Quote
Old 04-20-2014, 02:51 PM   #1081
TmP
TmP's Avatar
Drives: A bunch of 'em...
I haven't read up well enough on this amazing product, I'll admit that right now.
But what I saw, was awesome!
To me tuning with a Diablosport Predator and a laptop was already amazing (although super clumsy by comparison). This thing looks just plain great.
I assume this will take care of header caused CELs?
Also, does it allow no lift shift and 2 step functionality?
Thanks
TmP is offline   Reply With Quote
Old 04-20-2014, 02:53 PM   #1082
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Go ahead and flash a Stage 1 map. What are you waiting for?
Old 04-20-2014, 03:10 PM   #1083
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
I'm not sure I understood that in the context of my question. Are you saying that I should go get the dealer flash even if I use OFT?
Obviously, I'd flash back to stock first.
Thanks!
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 04-20-2014, 03:11 PM   #1084
Gilwith1l
Gilwith1l's Avatar
Drives: stock brz. saving my money for ls1
Which ots tune should I use . I have k/n filter, Crawford bpb,stock header and cat back, catless frontpipe,93 octane?
Gilwith1l is offline   Reply With Quote
Old 04-20-2014, 03:35 PM   #1085
Td-d
Thanks!
No - no need to - I'm saying the latest OFT maps are based off the last revision, so you would be getting it in any case.
Old 04-20-2014, 03:40 PM   #1086
robwbright
Sweet. Thanks. Now all I need to do is have the GPS TSB taken care of and decide whether or not I want the cricket issue dealt with.
2006 Saab 9-3 2.0t
Old 04-21-2014, 12:26 PM   #1087
TmP
TmP's Avatar
Thanks
I'm just gonna gently bump this to see what happens
Old 04-21-2014, 12:45 PM   #1088
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Catless header CEL is taken care of with the stage 2 maps. "No Lift Shift" also no as FFS (Flat Foot Shifting) is a capable function that is set to off by default. Launch Control is also an available function. I'm not sure what you mean by two step functionality.
Luckrider is offline   Reply With Quote
Old 04-21-2014, 12:51 PM   #1089
TmP
TmP's Avatar
So:
No lift shift - YES
CEL kill - YES
2 step - YES
2 step is a 2nd rev limiter for when you are on the clutch waiting to launch.
So being you say it does have launch control, I take that as a yes.
How is the no lift shift implemented? Via ignition cut or fuel cut or both?
Is it possible to run just ignition cut, no fuel cut? That's just too much fun
Old 04-21-2014, 01:11 PM   #1090
Luckrider
Luckrider's Avatar
The "2 Step" and the "NLS" work on fuel cut the same way the revised rev limit is. This means that there are 3 functional rev limits controlled by different scenarios:
1. Normal Rev Limit: Max RPM no matter what. Cuts fuel when RPM is greater than a certain value and turns it back on under a certain limit.
2. LC: When the vehicle is below a specific speed (default is 6mph), a new rev limit is established defined as a delta (the difference from the standard rev limit).
3. FFS: When the clutch is activated (sets off the sensor as being pushed in), a new rev limit is established until the clutch is let out. This is sometimes activated accidentally by resting your foot on the clutch.
Old 04-21-2014, 01:37 PM   #1091
robwbright
Got my OFT this morning and flashed the Stage 1 map. I'll try to post my logs in a little while, but my initial take on it is:
I didn't notice much of a difference at first. A little smoother perhaps, but didn't seem like a big deal.
Later on, the change was more noticeable. Maybe I'm imagining things (I don't think so) but the thing that seemed the most different was that the VVT seems to come on about 750 rpm sooner. That's what it felt and sounded like, anyway. On the stock tune, it seemed that the noticeable VVT "boost" occurred right around 5000 rpm+/-. Now it happens at about 4,250 rpm +/-.
That makes for a significant difference in drivability. There's more margin for error when shifting at redline. Whereas before, a shift up at redline resulted in being right at the start of the VVT boost, now you're further up into the boost.
The torque dip is obviously lessened, as well.
Again, maybe I'm just imagining all that, but it sure seems different to me.
2006 Saab 9-3 2.0t
Old 04-21-2014, 02:19 PM   #1092
robwbright
Log attached in csv and prolog. Does everything look ok?
http://www.2shared.com/file/yPtoCpD2/042114_log.html
http://www.2shared.com/file/VN-ZlMgI/42114_log.html
BTW, click on the 2nd, smaller download button... I couldn't attach those file types here.
2006 Saab 9-3 2.0t
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
