Old 06-20-2013, 12:30 PM   #1079
buditjoenawan
Drives: Very very slowly
Originally Posted by Sportsguy83 View Post
Remember the 260 was on E85 which helps a bit.
I understand e85 helps, but this is waaaaay beyond the scope of published specs. 300hp at the engine at 1 bar is the published spec. So at less than half the boost pressure, you are making as much as the max at 1 bar? Does e85 compensate 100%? And all this is non intercooled! I'm sorry that I am skeptical, but the numbers do not add up in a major way. I would love to be proven wrong, and I will even put away my flame suit if it turns out I'm completely off-base. But so far, this is not passing the basic sniff test.
budi
buditjoenawan is offline   Reply With Quote
Old 06-20-2013, 12:34 PM   #1080
sw20kosh
Drives: 2013 Black FR-S
budi
put on your flame suit.
I think you forget what E85 did on the vortech kit... 245 whp on pump -------> to 365 whp E85 no knock.
Old 06-20-2013, 12:40 PM   #1081
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
budi
I have no dog in this fight. I'm skeptical too (not because I think there is something being covered, but because I am always skeptical until I see independent review). I can't wait till this kit makes it hand to a customer (third party) and he dynos it with consistent before and after dynos to see the gains. Its all good.
Old 06-20-2013, 12:42 PM   #1082
Sportsguy83
Drives: Limited BRZ
That's not completely true. It was done at a different PSI, so the difference was not ONLY E85 it was more variables.
Old 06-20-2013, 12:45 PM   #1083
sw20kosh
My point is E85 allows for a ton more timing and more boost.
I am surprised no one has produced an E85 dyno on the base vortech kit. With the timing advance you can run with E85 I'd speculate a bump up from 245 to 280-290 ish whp.
Old 06-20-2013, 12:45 PM   #1084
buditjoenawan
Naw sw20kosh, I am an adult capable of taking criticisms. I would love a realistic discussion. And if I'm wrong, I will freely admit it. But your respond neither moves the discussion along, nor really refutes any of my assertions.
budi
Old 06-20-2013, 12:47 PM   #1085
Sportsguy83
Drives: Limited BRZ
Yes.... I believe a good amount of people know that here already. That does not change the fact Robi is at 7 psi, and there is a ceiling to how much timing you can run, its not endless.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
buditjoenawan (06-20-2013)
Old 06-20-2013, 12:49 PM   #1086
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
budi
Perhaps the "published specs" are taking into account a small, low compression, 92 octane, normally injected engine. I think the thing you are forgetting is our 12.5:1 CR, direct injection effects and the effects e85 has on knock.
industrial is offline   Reply With Quote
Old 06-20-2013, 12:50 PM   #1087
Sportsguy83
Drives: Limited BRZ
Originally Posted by industrial View Post
Perhaps the "published specs" are taking into account a small, low compression engine. I think the thing you are forgetting is our 12.5:1 CR, direct injection effects and the effects e85 has on knock.
This is true too. There are so much variables to consider.
Whenever the kit is released we will all see what the fuss is about
Old 06-20-2013, 12:53 PM   #1088
sw20kosh
budi
I was using your words buddy (or budi). You brought up the flame suit...
Sorry you didn't find it comical...
Anyways, as someone who saw the car in question get dyno'd, I am gently telling you that your "assertions" are incorrect.
Old 06-20-2013, 12:53 PM   #1089
buditjoenawan
No, the published specs are for the supercharger unit. It can *ONLY* supply a certain amount of air flow. Anything over that is magical. Like Unicorns magical.
budi
Old 06-20-2013, 12:55 PM   #1090
buditjoenawan
sw20kosh, so your assertion is that e85 alone can make up for the more than 100% volumetric efficiency gap that the supercharger isn't providing? Since at 260whp, it's just about max of what the supercharger is rated for at 14.7psi. I can't make the math work....
budi
Old 06-20-2013, 12:56 PM   #1091
buditjoenawan
Budi is my real name. I have nothing really to hide. I'm not saying that anything is incorrect. But, BUT, if the supercharger unit is the same 300hp@1bar unit that I linked to, it's amazing that the car makes that much power with that little boost.
budi
Old 06-20-2013, 12:59 PM   #1092
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
budi
How do you measure the HP just the supercharger makes? All cars will make the same power with the same PSI from this supercharger?
Are you kidding me?
Bullet/Sprintex/Innovate on the bullet website JoeBoxer Forced Induction 333 04-18-2013 10:07 AM
Still searching for an FR-S? 2 available in Little Rock Moshpit37 Southwest 9 01-02-2013 10:32 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 01:39 AM
Searching Inventory in the SE Erroneous Southeast 40 07-23-2012 04:40 PM
