Old 09-03-2014, 07:09 PM   #1079
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Originally Posted by conedodging View Post
I'd be impressed if there was a consensus, but interested about the topic as well.
Someone needs to tell me before I throw caution to the wind and boost mine and fuck myself right into SM/SSM...
BRZZZZZZZZZZ is offline   Reply With Quote
Old 09-05-2014, 08:08 PM   #1080
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
It seems that my driver side axle has developed the dreaded "click". What are my STX-legal options? Are the Drive Shaft Shop axles legal? Other than OEM, are they the only aftermarket option? How long are the OEM axles generally lasting? My car has 10k, and seen around 20 events (all with a co-driver). The problem has only recently surfaced after the installation of coilovers and a spirited drive through the hills of southern Ohio.
Feel free to chime in on any, or all of that somewhat redundant line of questions, lol.
Thrustin is offline   Reply With Quote
Old 09-05-2014, 08:49 PM   #1081
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Unfortunately until the Aftermarket manufacturers catch up with production (Cardon, Napa, O'Reilly's, etc) the ONLY option is factory... most of us get them on EBAY .. for about $150 or less. Both sides use the same axle.. there is no left/right.. its all one
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
Thrustin (09-05-2014)
Old 09-05-2014, 08:54 PM   #1082
Thrustin
Bill
Well, I guess that's good and bad news. I'm not going to spend $900 on axles, but I'll be replacing them every so often. Thanks Bill!
Old 09-05-2014, 09:15 PM   #1083
Thrustin
Axes for around $100. Hell yeah!
Old 09-06-2014, 12:13 AM   #1084
haison
Drives: 2014 Subaru BRZ
So I got wheels and tires sooner than expected since I got a good deal on the RPF1s 17x9 +35. I'm getting some fender rub and not sure what 'best practice' is for autocross. This is my first car that is not in stock class so I've never had aftermarket wheels either. I'm lowered on Feal 441 coilovers too. I've pre-registered for a test and tune event at the end of the month for Delta region so I have some time to play with different things.
haison is offline   Reply With Quote
Old 09-06-2014, 12:33 AM   #1085
toeout
How much negative front camber do you have? It should be tucked in much more than that. Almost looks like a positive camber.
toeout is offline   Reply With Quote
The Following User Says Thank You to toeout For This Useful Post:
fstlane (09-06-2014)
Old 09-06-2014, 02:29 AM   #1086
haison
It is 0 camber right now. I had gotten an alignment about two months ago when I had the coilovers installed. I just got the new wheels and tires last week. I do like the poke look though.
Old 09-06-2014, 03:00 AM   #1087
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Holy understeer Batman! At least that is what happened to me when I lowered my suspension without any camber adjustable parts.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 09-06-2014, 03:05 AM   #1088
Turkish
Serial Cone Killer
Turkish's Avatar
Originally Posted by BRZZZZZZZZZZ View Post
Whats the consensus on the best header+everything up to the midpipe in terms of NA gains/driveability. Would be combined with ECUTEK and a proper tune. I already have a Greddy SP Elite exhaust I got for super cheap.
I am planning for in the long term going with a catted UEL, 99% sure it will be the FT86 Speed Factory one. I also daily drive my car. Add on to that recent legislation that requires your car to pass inspection to be registered, thus paving the way for stricter rules regarding exhaust systems. I am not a fan of any of this Californication of Texas. I had originally planned on a catless header and keeping just the secondary cat in the front pipe.
... his name is...
C'THULHU
Old 09-06-2014, 12:24 PM   #1089
Scooby South
Conedancer
you need some negative camber... most of us are in the -1.6 to -2.4 range.. that will help with the rub.. How to achieve that is with Adj rear LCA... Whiteline or some other NON Spherical Bearing brand. .. that will also help with balance.
Bill
The Following 2 Users Say Thank You to Scooby South For This Useful Post:
haison (09-06-2014), Turkish (09-07-2014)
Old 09-06-2014, 01:34 PM   #1090
xwd
From what I read I think he's fine in the rear, with the car lowered some he should be getting some negative camber already and the rear has a ton of room generally.
I think he's running 0 camber in the front which isn't going to work and that's why with +35 it's rubbing on the fenders. Stock the car doesn't even run 0 camber in the front, it's more like -1...
Old 09-06-2014, 01:43 PM   #1091
haison
Bill
Thanks Bill.
I wasn't planning to autocross the car until when next season starts but I wanted to get a feel for the setup. I should have clarified that the front camber was 0 and the rear is about 2.4 after dropping. Would it be alright to add negative camber via camber plates before the event?
Old 09-06-2014, 04:53 PM   #1092
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Thanks Bill.
More than alright, DO IT NOW. Get yourself at least 2, and better 3 degrees up front.
neurokinetik is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
