#1065 | |
your 92 must be pretty good quality looks much better than i thought it would :-) |
#1066 |
Drives: Subaru BRZ
I have updated my OFT template to allow logging of throttle position, brake pressure, steering angle, gear selection etc, and have exported the csv file. If I use HLT/Racechrono as a laptimer to record the GPS value and export this to another csv file, how can I integrate both datalogs to dashware to compile a video? How do I sync both datalog csv files?
#1067 |
Drives: 2013 FRS
So things have gotten a little interesting... I ended up with a drop in K&N filter and a Perrin unresonated 2.5" exhaust. Here is a 1st to 2nd pull at WOT. Still have to get some time to learn about all this data but figured I'd share and hear your thoughts.
#1068 | |
looks ok from what you can see try a 3rd gear pull also load up the logs to www.datazap.me and just post link, heaps easier to read |
#1069 |
Drives: Scion FRS
3rd gear pull , High LTFT aswell as knocks at -5
could someone read this upload and let me know if you see anything that i should be worried about? i am new here and still need some learning
My FLKC shows -5 most of the time and when i opened it on OFM it said -100? |
#1070 |
Drives: Scion FRS
#1071 |
#1072 |
IG thomas50shades
Drives: ISO: BRZ
Really don't want to put a header on it, but it's good to know that it won't really do much for me. Maybe I'll put it back up on here for sale. Thanks!
#1073 |
Somewhere there is a plot of stock vs stage 1 vs stage 2 on here. Have a look for that.
EDIT: Found it. http://www.ft86club.com/forums/showp...&postcount=189 |
#1074 | |
IG thomas50shades
Drives: ISO: BRZ
$400 isn't bad for the gains, in my opinion, without having to swap any physical parts. Seemed like a reasonable deal. Edit: Is my method correct, though? In regards to the launch control settings. |
#1075 | |
IG thomas50shades
Drives: ISO: BRZ
So, it would seem that I need to go back and edit the "Stg1 A01C.bin" files instead of using the "Stg 1 D00C.bin" files. Does that sound correct? |
#1076 |
Yes. You need to connect the OFT to the car first to get the correct ROM version.
#1077 |
IG thomas50shades
Drives: ISO: BRZ
#1078 |
IG thomas50shades
Drives: ISO: BRZ
Okay, so I am sure I have done some minor mistake, but I cannot quite figure out what it is. I took a bunch of screenshots of the software as I was going along, so hopefully this helps explain things.
I connected the OFT to the PC and ran it through all the updates. Thereafter, I connected it to the car, read the car's stock ECU, and now I am back on the PC. I want to send a few launch control based files to the OFT, but I need to of course modify the files. I will only use Stage 1, 91 octane files for my tune(s) with varying launch control RPMs. Otherwise, all other settings will remain as-is. First step was to connect the OFT to the software, and on the side I would run the RomRaider. I know that I need to add the appropriate Definition file to RomRaider, but this is where I am a little confused as to which of the two files I should use? So, I started with the first one as it matched the naming in the CAL box. ![]() I then navigated to the appropriate Stage 1, 91 octane folder, and proceeded to select the matching file that populated in the OFT software. When doing so, I got this error in RomRaider. ![]() Okay, then I figured I should use the other file (see the first picture), so I first removed the first file and then added the second file. ![]() ![]() Back to the Stage 1 folder, selected that file again, and I was hit with some Checksum errors. Per the FAQ this is not a major concern, so onward we go. ![]() I then went in to Launch Control setting and set the parameters to what I want. In this case I want the max RPM set to 2000 thus entered in 5600. ![]() Thereafter, I went to save the file and was again prompted by two errors. ![]() Back to the Openflash Manager software. I clicked the Upload Data button, deleted one of the storage spots. ![]() After that I added in the tune that I just created from RomRaider, but I was immediately hit by this error and could not proceed. ![]() I repeated these steps several times, and I always get hit with that error at the end which prevents me from doing anything. Any suggestions would be greatly appreciated. |
| WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 08:13 PM |
| Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 09:27 PM |
| FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 03:08 PM |
| FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 03:49 PM |
| Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 08:14 PM |
