#10697 |
Drives: 2015 limited brz
is he still making/selling kits?
im looking for a phantom supercharger and was curious if he still made/sold these or if anyone has one.
#10698 |
Drives: 2014 GT86
No. He stopped making those. Only way to get one now, is buying from someone parting from it.
#10699 |
Drives: 2003 Honda Element
Anyone considering selling their electric supercharger/setup?
#10700 |
Torqamp makes a very similar set up. Only thing you would need a custom tune, idk if shiv from oft would be able to help with a custom tune. I don't see how it would be any much different than a custom phantom tune. Anyways check out their videos on youtube they actually claim to make more boost than the phantom
Sent from my SM-G935T using Tapatalk |
#10701 |
| The Following User Says Thank You to BlOody_BoOger For This Useful Post: | WNDSRFR (03-14-2019) |
#10702 |
Drives: FR-S,GTI
Here's the whole Phantom story if you don't like reading. Start at the 20:00 minute mark if you want to skip everything you already know.
[ame]https://www.youtube.com/watch?v=VBiHg5feKIU[/ame] |
#10703 |
Drives: Raven FR-S
I was one of the first adopters of the phantom ESC system and did a few beta test for Rob a few years ago. Today I am going to begin the process of parting out the ESC before selling my FRS in the coming months. I have approximately 45,000 miles on the unit. Parts include the control unit, auxiliary charger with cooling fans. If you have any interest in purchasing the system send me a direct message.
#10704 |
Just a random thought. What do you guys think would happen if we put two phantom superchargers together?
![]() Sent from my SM-G935T using Tapatalk |
#10705 | |
Drives: 2017 toyota 86
Either way you would probably want 4+ batteries in the trunk to pull it off. Not sure how the recharge time would be effected either with twice as many batteries in the setup. |
#10706 | |
#10707 | |
Not sure the max output of the alternator could try smaller pulley to overdrive it. Not sure if having them both blow in tandem to the same pipe if they would be fighting each other trying to push air out the other blower or if they would end up flowing together perfectly for about 10psi. Would really make this system feel like a true alternative to nos without having to refill and heat up bottles if you got two working together though. Cool idea. |
#10708 | |
#10709 | |
Drives: 2013 Asphalt 6spd
I don't know how the rest would work out, but I have been running 4 of the original powersonic batteries in the engine compartment (starter battery relocated to trunk), powering just one phantom charger since July 2014, for about 17,000 miles. Still running the original batteries, and I haven't had any issues. It may have helped longevity due to demanding only half the charge/discharge load per use of the phantom of the single battery set. I never ran just the single setup so I don't know how it compares, but I just assume they drain at half speed due to having twice the capacity. And charging should take close to the same amount of time. The Phantom is demanding the same amount of current in either case, but is able to utilize slightly more current than the single pack could produce, which is why he developed the 1.5 pack. If you power each of the two chargers with their own 24v pack. It would use twice the current, and require twice the charging, that "may" be too much for the alternator, but since Rob developed the alternate charger that also ran off the alternator to charge up the batteries twice as fast, it may not be an issue
#10710 | |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
