Old 08-14-2014, 10:42 AM   #1051
Wepeel
Drives: '13 BRZ Ltd
Originally Posted by dwx View Post
The lower end is usually 92dB and you might be close depending where they stick the sound meter. How many other resonators are in the system? If you don't have other resonators it won't just be loud but it will also sound terrible and people will hate it and laugh at you.
Everything else about the exhaust is stock except for the header. I have a turndown from my '08 STI that I think will probably work, just been to lazy to try it out.
Wepeel is offline   Reply With Quote
Old 08-20-2014, 04:22 AM   #1052
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
This is my first year auto-xing my car. What is the purpose of spraying the tires between heats? Does the Cusco front strut bar w/ master cylinder brace meet the STX requirements? ( http://www.rallysportdirect.com/Cusc...Cylinder-Brace )
Thunderleg is offline   Reply With Quote
Old 08-20-2014, 07:17 AM   #1053
EN2_Squirrel
EN2_Squirrel's Avatar
Master cylinder brace not legal. Spraying the tires is for cooling. As i have heard and @Scooby South and can some tires like the federal 595 rs-r do not work when they get above certain temps.
STREET MOD. My wallet now hates me....
EN2_Squirrel is offline   Reply With Quote
The Following User Says Thank You to EN2_Squirrel For This Useful Post:
Thunderleg (08-21-2014)
Old 08-20-2014, 07:33 AM   #1054
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Every tire compound has an optimal operating range. So tires have lower temperature range (Z2), some higher (RS3, especially RS3v1). Lower heat range tires need to be cooled as they exceed that range quickly and then do not grip well.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
Old 08-21-2014, 02:54 AM   #1055
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
I am running the Michelin PSS currently. Any suggestions on them? I currently only play with pressure during events, haven't sprayed them.
Old 08-21-2014, 05:03 PM   #1056
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Tire sprayers are necessary if you run Z2s in my experience. Not once did I have to spray my RS-3 V1s though.
BRZZZZZZZZZZ is offline   Reply With Quote
The Following User Says Thank You to BRZZZZZZZZZZ For This Useful Post:
fstlane (08-21-2014)
Old 08-22-2014, 07:02 AM   #1057
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
I have yet to need to spray my RS3 V2s, either. Single driver car, though. Hottest event I've run this year was mid 80's. Grip only got better as it got hotter.
neurokinetik is offline   Reply With Quote
Old 08-22-2014, 08:31 AM   #1058
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I got the V2 RS3's to the 150/170 range on concrete a few weeks ago and they were still grippy. Anything more than that I think would have been to much. You would really have to hot lap them for that to happen.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 08-22-2014, 09:09 AM   #1059
Kido1986
Dodging cones
Kido1986's Avatar
It's that at 8am here hahaha. Even when I ran RS3s, I had to spray as a single driver.
Old 08-22-2014, 07:14 PM   #1060
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I had to spray my v2 RS3 on concrete with two drivers. We cooked em. Fine with 1 driver though.
Old 08-22-2014, 07:24 PM   #1061
vroom4
Im jealous of not having 100 degree autocross events where you are spraying constantly....not jealous of those same places having rain though.
vroom4 is offline   Reply With Quote
Old 08-22-2014, 07:25 PM   #1062
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
It was so hot during our event at CotA, when I went out for the 4th heat I had to bleed 5 psi off of the tires after they had sat parked for 6 hours. Double driver in that heat on fresh black asphalt mandated spraying the R-S3s.
bimmer635csi is offline   Reply With Quote
Old 08-24-2014, 10:21 PM   #1063
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
Originally Posted by Scooby South View Post
I can understand your confusion... A few Years ago, 'Real' Aero(Wings, Splitters,) was allowed in ST. it was then ruled Illegal for the BIG wings and splitters.. the new rule for allowed 'Factory' Additions of lips and wings, OEM type that comes on US models
Bill
Bill- I am still thinking about this. Since the cars are twins would it be legal to put a front splitter on an FRS? Could it be interpreted as different styling package in the same model year? Thanks for anyone's thoughts on this. My initial interpretation is no, yet the two cars would in the same class with different option packages available.
MTCRX is offline   Reply With Quote
Old 08-25-2014, 02:19 PM   #1064
mrazny
Drives: BMW 135i, soon to BRZ
without clarification, to the letter it's not allowed. Technically it's not allowed for the BRZ until the official clarification comes in. It philosophically follows the e36 clarification, but there is no clarification yet. You can mount a pretty good defense and possibly win your protest with a brz, but you'd still be better served by an official clarification by writing to the SEB.
mrazny is offline   Reply With Quote
The Following 2 Users Say Thank You to mrazny For This Useful Post:
MTCRX (08-25-2014), Scooby South (08-26-2014)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
