Old 10-25-2016, 06:19 PM   #1037
tomaszjanczak
Drives: Silver Subaru BRZ
A/350 shouldn't have any fitment issues at all.
Double check to make sure all your bolts are torqued properly, and also check your other exhaust components.
I have checked everything 3 times
It really doesn't look like any exhaust component could be vibrating against something, but I can't think of anything else it could be because it started right after installing the Ace header.
tomaszjanczak is offline   Reply With Quote
Old 10-25-2016, 06:33 PM   #1038
bhmax
Drives: 13 BRZ, 17 Focus RS
Originally Posted by tomaszjanczak View Post
I'm having a "rattling" or metal "buzzing" sound, like metal vibrating against metal (above ~4K RPM). I have hammered the skid plate to oblivion, there's now about 3/4" gap with the skid plate and the header, so there's no way that's the problem.
The only other spot I could see being the problem is the over pipe against the frame but that also has a fairly large gap between them and the pipes barely move even when I push on them so I see no way it would move enough to touch the frame during driving.
Has anyone else had this problem? I can't figure out what's causing it.
Is it definitely not the clutch pedal rattle that a lot of people seem to have? I get it on occasion. Press lightly on clutch pedal when it happens to see if it stops.
bhmax is offline   Reply With Quote
Old 10-25-2016, 06:37 PM   #1039
Reamer
Drives: 2015 FRS
ACE FP too or just the header? Stock cat-back? If it is the 350+FP with a stock cat-back it just has a super "tinny" sound but nothing on mine was touching. If CSG+ACE can have an exhaust using their FP that isn't obnoxious and not "tinny" **mother of god**
Sent from my HTC 10 using Tapatalk
Reamer is offline   Reply With Quote
Old 10-25-2016, 06:40 PM   #1040
tomaszjanczak
I don't think so, this really sounds like metal buzzing against each other. I'll try it out though.
Old 10-25-2016, 06:41 PM   #1041
tomaszjanczak
I have the Ace 350 header+over pipe. Stock front pipe and Invidia Q300 cat-back
The Following User Says Thank You to tomaszjanczak For This Useful Post:
Reamer (10-25-2016)
Old 10-25-2016, 06:59 PM   #1042
It's a pity you're not here to hear it in person...
The car is boosted, but that adds to the noise, not subtract.
Old 10-25-2016, 07:13 PM   #1043
Reamer
Drives: 2015 FRS
This guy ^^ just rubbing it in. Lol.
The Following User Says Thank You to Reamer For This Useful Post:
funwheeldrive (02-27-2017)
Old 10-25-2016, 07:35 PM   #1044
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Your name is Reamer. Who is reaming who?
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
Jmk91 (10-25-2016)
Old 10-25-2016, 07:44 PM   #1045
Reamer
Drives: 2015 FRS
Touché.
Old 10-25-2016, 07:53 PM   #1046
CounterSpace Garage
Touché.
Reamer (10-25-2016)
Old 10-25-2016, 09:35 PM   #1047
Devilz
Drives: GT86
How much louder would my exhaust be if get CS400 with overpipe, stock fp and already I have a tomei 60r installed?
Devilz is offline   Reply With Quote
Old 10-25-2016, 09:41 PM   #1048
As long as you keep that stock FP, a few decibels. Not too much.
Devilz (10-25-2016)
Old 10-25-2016, 09:46 PM   #1049
Devilz
Drives: GT86
oh sweet thats not too bad, makes me feel a bit better haha been wanting a set for awhile but was unsure if it would be too loud.
Old 10-31-2016, 07:25 PM   #1050
X Factor
Drives: 2013 Red BRZ Limited
ACE A/350, GrimmSpeed intake, stock front and mid pipe, 93 octane. Tuned at PRT Performance made 175 on their Mustang dyno, torque dip gone, car pulls nice and smooth now.
Dyno chart.
X Factor is offline   Reply With Quote
The Following 4 Users Say Thank You to X Factor For This Useful Post:
AceHeader-MT (10-31-2016), armstrom (10-31-2016), CSG Mike (11-01-2016), Reamer (10-31-2016)
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
