#1023 |
Drives: 2017 BRZ PP
#1024 |
Drives: 2017 Subaru BRZ
Anyone that have this kit running 5 PSI ? is that even possible with this kit and a tune?
#1025 |
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
You'd have to get the 5PSI spring for the wastegate since it comes with a 7PSI spring. I have the spring, just haven't decided if I want to turn down the boost haha
#1026 |
Drives: None
Can anybody help me figure out where to tap the bov hose line? I own an avo kit and asked people there but the thread has been somewhat dead. Here's a picture of work. You can see on the left where i spliced the t valve. Its blue.
![]() Sent from my LG-H871 using Tapatalk |
#1027 |
Drives: 2017 BRZ PP
JDL turbo kit owners thread
I believe JDL’s instructions tell you to tap it into the brake booster line below the check valve. I also had a JRSC and they also recommended tapping it from there also.
Here’s a picture of my engine bay during installation. The brake booster line is circled in red. Sent from my iPhone using Tapatalk
#1028 | |
Drives: None
#1029 |
Drives: 2017 BRZ PP
The brake booster line is in the circled area. The line is an upside down U that connects directly to the right intake manifold port.
#1030 |
#1031 |
Then don't boost it.
You will break something eventually if you boost it.
#1032 |
Drives: 2013 Subaru BRZ
Why is it so difficult to communicate with them. Never reply to emails until I call in and ask them to reply. Order was placed a while ago but they tell me a different story about some stuff. I hear it's one of the best turbo kit out there but why so unorganized to the point they can't communicate properly or even keep note of specific details with the sale.
나의 SM-G955U 의 Tapatalk에서 보냄 Last edited by dkstylezz; 06-12-2018 at 05:27 PM. |
#1033 |
Drives: 2013 frs
anybody knows the bolt sizes for this kit? one of my dowpipe to turbo bolts went missing..
Sent from my VTR-L09 using Tapatalk |
#1034 |
Take one of the others out, go to a hardware store and match the threads.... for sure they will have something
#1035 |
Drives: 2017 BRZ PP
Does anyone with the Garrett GT/GTX series have any problems with the turbo blowing oil into the exhaust?
I first noticed smoke after I removed the cat. The smoke would begin only after the car was warm during idle and higher load. After doing some troubleshooting, I noticed a pool of oil in the turbine housing when I removed the downpipe. So after reading a ton of articles on what makes a turbo smoke, I concluded that my turbo was improperly clocked and having problems with oil drainage. I removed the turbo, got it rebuilt, and reinstalled the turbo. I reclocked the turbo to as much of a vertical angle I could, limited only by the T3 exhaust flange. When measuring the angle of the oil fittings on the turbo after everything was installed, it came out to about 20 degrees. I drove the car for about 50 miles and I was still having some smoke when warm and at idle. I was hoping that reclocking the turbo would fix the issue but it apparently did not so the next problem that I thought was the issue was the placement of the oil drain fitting at the oil pan. When disconnecting the oil drain hose from the oil pan, oil poured out of the bung telling me that the drain is placed below the level of the oil in the sump, preventing the oil from draining freely into the oil pan from the turbo. So I installed an oil scavenge pump that essentially sucks oil out of the turbo CHRA and pushes it into the oil pan. Installing the scavenge pump helped a little with the smoking issue but my exhaust is still slightly smoking whenever starting from a stop. I've been checking my oil level everytime I get home and haven't noticed any loss after driving for about 180ish miles since I installed the scavenge pump. I just wanted to know if anyone else has had/have the turbo blowing oil. Also, is 20 degrees too extreme of an angle for the oil to drain properly? I'm really at a loss for anything else I could do to stop this problem if it is a problem.. |
#1036 | |
나의 SM-G955U 의 Tapatalk에서 보냄 |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 01:18 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
| To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? | xuimod | Forced Induction | 106 | 09-01-2016 07:33 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
| P&L Turbo Owners Topic Thread | GTB/ZR-1 | Forced Induction | 4 | 09-01-2013 06:27 PM |
