Old 08-17-2013, 09:46 AM   #1023
regal
Originally Posted by sw20kosh View Post
I see tip in knock on all my tunes. If you take a ecutek log you will see it as Knock Correction right when you go to WOT. It isn't audible on mine (from inside the cabin at least)
ol/cl delay , the '86 Achilles heel. Sounds like Mike has it figured out which is great.
Originally Posted by evo4g63 View Post
I see that as well on mine. The audible part scares me a lot though.
The non audible part isn't good either. Don't assume that all tuners have have put in the time to figured out how to shorten the delay.
It is explained here:
http://www.romraider.com/forum/viewt...hp?f=25&t=1603
But that was from when things were easier.
Note the post in this thread where a WRX owner recommends against stomping on the throttle:
http://www.iwsti.com/forums/ecu-tuni...oop-delay.html
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
The Following User Says Thank You to regal For This Useful Post:
ill86 (08-22-2013)
Old 08-17-2013, 09:57 AM   #1024
mad_sb
Drives: 2013 Asphalt FR-S
I think it is more tip in enrichment than closed to open delay. I always set my timers to zero and transition based only on load (from the fuel map) and i still get the tip in knock, often after hitting open loop. BRZedit does not have all the tip in tables defined yet and i can see the lean spike on tip in. I'm not boosted yet so it's not as big of a worry for me. Not sure if ecutek has the tip in tables defined or re codded or not.
Old 08-17-2013, 11:39 AM   #1025
phloozy
phloozy's Avatar
Drives: Scion FR-S
Originally Posted by moto-mike View Post
spent about 12 hours and nearly 30 revisions to have it go away on pump. Still can see some on the datalogs, but no more audible noise on the last beta tune. The audible portion is what counts.
No easy task IMO....the blower pushes that air in there awfully quick if you stomp on it.
As someone looking to purchase the innovate SC, is this something to worry about? I plan to get everything done at RT Tuning which i hear you work with a lot. Is this something that I should point them to before going forward?
phloozy is offline   Reply With Quote
Old 08-17-2013, 12:26 PM   #1026
xjohnx
Grip>Slip
xjohnx's Avatar
If you need to point them to it, they may not be the right person to tune the car for you. I can recommend both @moto-mike and @DeliciousTuning - William @DeliciousTuning is likely closer to you if you're on the west coast.
The Following User Says Thank You to xjohnx For This Useful Post:
mines13 (08-19-2013)
Old 08-17-2013, 01:14 PM   #1027
phloozy
phloozy's Avatar
Drives: Scion FR-S
I doubt I would have to, Moto-mike tunes at their shop a lot and they are very reputable. Its a new system on a new car so I thought it was good to ask.
Old 08-17-2013, 01:17 PM   #1028
xjohnx
Grip>Slip
xjohnx's Avatar
Yep, mike's great. I wasn't sure if you were having him tune it remotely at RT, or having RT tune it.
Old 08-17-2013, 01:34 PM   #1029
phloozy
phloozy's Avatar
Drives: Scion FR-S
Havent decided on how I want to go about tuning it yet. I would like a dyno tune but remote tunes are slightly more cost effective
Old 08-17-2013, 08:30 PM   #1030
sw20kosh
Drives: 2013 Black FR-S
Remote dyno tune. You can pay a shop to use their dyno and set up a remote tuning session with your tuner.
The Following User Says Thank You to sw20kosh For This Useful Post:
Xero-Limit (08-17-2013)
Old 08-17-2013, 09:06 PM   #1031
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
You can go either route. We're not too far in Nazareth but we work closely with the R/T folks on this platform (and others). If you go there we'll make sure they have our latest to start, and Vince and Andy will get you taken care of no problem; I just don't have the time to get them all in (we only have one dyno and the remote stuff keeps me busy) so I send the base maps to them at times and they are more than capable of doing the rest.
Xero-Limit is offline   Reply With Quote
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
mines13 (08-19-2013), Toyota86.ir (03-03-2016)
Old 08-18-2013, 04:10 AM   #1032
regal
Thanks,
Can Mike or any Ecutek tuners comment on this, do you have access to all the tip in tables to fix the issue ?
Mods:
Old 08-18-2013, 09:17 AM   #1033
Xero-Limit
Xero-Limit's Avatar
Thanks,
we do and a whole lot more, but I can tell from dozens of hours in the car and on the dyno that it ain't that simple.
Old 08-18-2013, 03:33 PM   #1034
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Can the OP be update with fuel type/additives used? Thinking about buying but don't wanna do e85 or water injection with it... Yet
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 08-18-2013, 04:59 PM   #1035
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
It's enough work to maintain the list with links and dyno numbers. You'll have to do your own research through the links provided to determine more info on each particular install.
The Following 2 Users Say Thank You to DarrenDriven For This Useful Post:
NickFRS (08-22-2013), OmarGC (08-18-2013)
Old 08-18-2013, 08:15 PM   #1036
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Word... Think you may need to add me to the list soon
Omar GC
Instagram: 2jzus
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
