Old 04-17-2014, 10:43 AM   #1023
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Originally Posted by SeanRTR View Post
Someone would probably shit their pants, even at the local level. I wouldn't go that route in C-Street.
Lmao good to know.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 04-17-2014, 10:52 AM   #1024
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
a half an inch opens so many new tire options and grip.
Thats why wheels are a big deal.
Old 04-17-2014, 10:53 AM   #1025
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Originally Posted by Kido1986 View Post
They don't want a relatively rare car (1500 units) to be an overdog, I can appreciate that. Though we're so far down on the 370Z, I don't think it matters.
What could happen is the RS 1.0 becomes classified as CS and the regular FRS and BRZ move down to ES due to the 370Z.
G_Ride is offline   Reply With Quote
Old 04-17-2014, 10:58 AM   #1026
vroom4
CS will die and ES will be huge.
vroom4 is offline   Reply With Quote
Old 04-17-2014, 11:21 AM   #1027
renfield90
The Stig's German cousin
I almost like this. They need to do something about ES eventually, and the twins are a popular car looking for a good place to play. Might make sense to move the NC Miata as well. I imagine that crowd is more upset at having to run against the 370 than we are.
The problem is that CS becomes spec 370 unless you're lucky enough to get a rare RS 1.0, or you throw money at a clone conversion. And if this spec class is now approaching BS speeds...then the classing starts looking really stupid.
Old 04-17-2014, 11:37 AM   #1028
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I'm thinking this isn't a BAD option, not because of the RS 1.0 but because we're starting to see results/actual A-B comparisons suggesting it's not as CS competitive as initially expected. The move was already proposed once, but not enough data to make an informed decision. If CS continues to be well subscribed all year, we may see some consistent evidence a move needs to be made.
At the Wilmington Match Tour, the ES winning MR-S would have been in a podium spot, well off Fenter's pace, but less than a tenth from Mark Andy... so there is at least one singular supporting data point.
Regardless of all that... Wilmington reminded me this sport is all about seat time and I haven't had any in a LONG LONG time
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 04-17-2014, 04:00 PM   #1029
TrqlessWonder
Drives: 2014 FR-S
Originally Posted by simpleisbest View Post
Are you saying SCCA would need to class the RS 1.0 as a particular trim? I think its the opposite actually. If the SCCA does NOT classify the FR-S RS1.0 as a different trim, it would be legal for CS, no?
I don't think so. It, with the different springs, would be considered a different trim, I would think. The 10 series/monogram are just comfort-convenience dress-up things. I expect it will get treated as an FR-S the same way the ZOK is treated as a Solstice.
I wouldn't expect it to be allowed to run at all nationally until specifically classed. I think the only real way to sneak it in would be if the line said "FR-S, All" or "FR-S, NOC." Won't be a problem for this year anyway. I think this will be the same with the tS BRZ.
What will be interesting is how long the SAC/SEB takes to class it once requested. Lately, they've shown a preference for having meaningful, at least mostly reliable to data to base new classing like these cars on. What to do with the new Camry? They'll just wing that one. Not with these, though. And there is still the obligatory 12-month rule.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 04-17-2014, 04:07 PM   #1030
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Originally Posted by dwx View Post
The SCCA is scared of special edition cars, it will end up in BS where it won't be competitive.
We are? Or do we think it might be best to not put limited availability models in the same class with their cheaper more common regular models?
Just follow the logic that makes sense in this case. What is to gain by putting this model in CS? What would be the changed if this limited model was in BS? How would it affect the established base in either case? Guess what the likely outcome in with those factors in mind.
- SAC member
TomR
ABQautoxer is offline   Reply With Quote
Old 04-17-2014, 04:28 PM   #1031
TrqlessWonder
Drives: 2014 FR-S
- SAC member
Thanks. I deleted that part of my post. Kind of tripping over myself to find a way to not put words in anyone's mouth, and still relay the message to others that the sky isn't falling.
I like either separate classing ideas, really. I'm not sure how well-received it would be to take the NA (and maybe NB) miata out behind the shed and put down, though. Which I think would be one of the net effects of that move.
-A guy who's going to try to make it work in Street pretty much without regard for SAC/SEB actions.
-Mike
#24 CS/CSR
Old 04-17-2014, 04:31 PM   #1032
ABQautoxer
ABQautoxer's Avatar
The ES question is one that remains to be answered. It was a split decision then and now about it's future. Really the answer is run what you want to support, otherwise leave it to a small few to "predict" what to do next.
There is a lot of time between now and Nationals. Answers will likely be in the November Fastrack by my math.
TomR
Old 04-17-2014, 07:03 PM   #1033
mrazny
Drives: BMW 135i, soon to BRZ
Best way to affect change is with actual participation, not "if you did this then I'd play" type stuff. Thankfully most are participating.
If you guys decide to not go to tours or nats because of the 370Z, you'll likely bury your own car because it's not perceptibly popular in Street.
mrazny is offline   Reply With Quote
Old 04-17-2014, 07:39 PM   #1034
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I'm still doing 2 tours + nats this year, but hoping that the showings will make them realized that the Z is too quick. Problem is, not as many people run it due to the high cost of massive tires that chew up sidewalls really quickly.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 04-17-2014, 08:12 PM   #1035
TrqlessWonder
Drives: 2014 FR-S
Another thing to keep in mind with the z. While there's some debate about the effectiveness of the torsen in our cars, the z cars have a much flimsier viscous diff. Street tires may make that considerably worse, or at least more maintenance-intensive to keep it working.
And a +1 on the running away thing. It was covered a few pages back and sort of echoed by our resident SAC member. If no one tries, what reason (other than the mental masturbation of bench racing) would anyone have for making a change? Particularly when a strong signal tends to be necessary to push a change through. I say next person to see Daddio tosses him the keys.
-Mike
#24 CS/CSR
Old 04-18-2014, 06:23 PM   #1036
travisb
travisb's Avatar
Drives: N/A
I did my first autox in the BRZ last weekend. I'm not new to autox, but my budget is very small this year. The only thing I will probably be able to do is tires and maybe something else not too expensive. I might be able to get dedicated wheels/tires next year.
The tires will be for DD and autox. I live in Virginia and we have plenty of rain and cold days. I won't be driving much in snow, if any at all.
My goal is not to win class. I just want to be more competitive than I was with the stock tires.
1) I am looking at Michelin Pilot Super Sport in either 215/45R17 or 225/45R17 on the stock wheels. With only 10MM difference is it worth going to 225?
2) Also, is it worth getting spacers to widen the stance and if so, how much could I do on the stock wheels. The spaces would have new studs.
3) While I am at it, it would be good to get camber bolts since they are cheap. What kind of alignment should I be looking at given everything I mentioned?
travisb is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
