#1023 |
Drives: Whiteout FR-S
Lmao good to know.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#1024 |
So elite I'm 1338
Drives: WRB Subaru BRZ
a half an inch opens so many new tire options and grip.
Thats why wheels are a big deal. |
#1025 |
Drives: Some kind of Subaru
What could happen is the RS 1.0 becomes classified as CS and the regular FRS and BRZ move down to ES due to the 370Z.
#1026 |
CS will die and ES will be huge.
#1027 | |
The Stig's German cousin
The problem is that CS becomes spec 370 unless you're lucky enough to get a rare RS 1.0, or you throw money at a clone conversion. And if this spec class is now approaching BS speeds...then the classing starts looking really stupid. |
#1028 | |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
At the Wilmington Match Tour, the ES winning MR-S would have been in a podium spot, well off Fenter's pace, but less than a tenth from Mark Andy... so there is at least one singular supporting data point. Regardless of all that... Wilmington reminded me this sport is all about seat time and I haven't had any in a LONG LONG time
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
#1029 | |
Drives: 2014 FR-S
I wouldn't expect it to be allowed to run at all nationally until specifically classed. I think the only real way to sneak it in would be if the line said "FR-S, All" or "FR-S, NOC." Won't be a problem for this year anyway. I think this will be the same with the tS BRZ. What will be interesting is how long the SAC/SEB takes to class it once requested. Lately, they've shown a preference for having meaningful, at least mostly reliable to data to base new classing like these cars on. What to do with the new Camry? They'll just wing that one. Not with these, though. And there is still the obligatory 12-month rule.
-Mike
#24 CS/CSR |
#1030 | ||
Drives: 2021 Supra / 2022 Tundra
- SAC member
TomR
| The Following User Says Thank You to ABQautoxer For This Useful Post: | TrqlessWonder (04-17-2014) |
#1031 | |
Drives: 2014 FR-S
I like either separate classing ideas, really. I'm not sure how well-received it would be to take the NA (and maybe NB) miata out behind the shed and put down, though. Which I think would be one of the net effects of that move. -A guy who's going to try to make it work in Street pretty much without regard for SAC/SEB actions.
-Mike
#24 CS/CSR |
#1032 |
The ES question is one that remains to be answered. It was a split decision then and now about it's future. Really the answer is run what you want to support, otherwise leave it to a small few to "predict" what to do next.
There is a lot of time between now and Nationals. Answers will likely be in the November Fastrack by my math.
TomR
| The Following User Says Thank You to ABQautoxer For This Useful Post: | AustinTX (04-17-2014) |
#1033 |
Drives: BMW 135i, soon to BRZ
Best way to affect change is with actual participation, not "if you did this then I'd play" type stuff. Thankfully most are participating.
If you guys decide to not go to tours or nats because of the 370Z, you'll likely bury your own car because it's not perceptibly popular in Street. |
| The Following User Says Thank You to mrazny For This Useful Post: | TrqlessWonder (04-17-2014) |
#1034 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
I'm still doing 2 tours + nats this year, but hoping that the showings will make them realized that the Z is too quick. Problem is, not as many people run it due to the high cost of massive tires that chew up sidewalls really quickly.
#1035 |
Drives: 2014 FR-S
Another thing to keep in mind with the z. While there's some debate about the effectiveness of the torsen in our cars, the z cars have a much flimsier viscous diff. Street tires may make that considerably worse, or at least more maintenance-intensive to keep it working.
And a +1 on the running away thing. It was covered a few pages back and sort of echoed by our resident SAC member. If no one tries, what reason (other than the mental masturbation of bench racing) would anyone have for making a change? Particularly when a strong signal tends to be necessary to push a change through. I say next person to see Daddio tosses him the keys.
-Mike
#24 CS/CSR |
#1036 |
Drives: N/A
I did my first autox in the BRZ last weekend. I'm not new to autox, but my budget is very small this year. The only thing I will probably be able to do is tires and maybe something else not too expensive. I might be able to get dedicated wheels/tires next year.
The tires will be for DD and autox. I live in Virginia and we have plenty of rain and cold days. I won't be driving much in snow, if any at all. My goal is not to win class. I just want to be more competitive than I was with the stock tires. 1) I am looking at Michelin Pilot Super Sport in either 215/45R17 or 225/45R17 on the stock wheels. With only 10MM difference is it worth going to 225? 2) Also, is it worth getting spacers to widen the stance and if so, how much could I do on the stock wheels. The spaces would have new studs. 3) While I am at it, it would be good to get camber bolts since they are cheap. What kind of alignment should I be looking at given everything I mentioned? |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
