Old 07-10-2014, 04:54 PM   #1023
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
Originally Posted by Wepeel View Post
Definitely post up your impressions of the RS3 compared to the Dunlop.
I switched from 235 Z2's to 245 RS3V2's for C Street (yup, 7" wheels), and I definitely noticed an improvement in performance. I was not able to do AB testing due to a single set of wheels, but results of the last 2 events are backing up my thoughts. It's been in the mid-high 90's here for months, so both were getting sprayed each run.
Autocross nut
AustinTX is offline   Reply With Quote
Old 07-10-2014, 04:57 PM   #1024
Wepeel
Drives: '13 BRZ Ltd
Originally Posted by AustinTX View Post
I switched from 235 Z2's to 245 RS3V2's for C Street (yup, 7" wheels), and I definitely noticed an improvement in performance. I was not able to do AB testing due to a single set of wheels, but results of the last 2 events are backing up my thoughts. It's in the mid-high 90's here, so both were getting sprayed each run.
Good to know. So timewise they are better (what really matters)... but do the RS3 feel much different?
Wepeel is offline   Reply With Quote
Old 07-10-2014, 05:48 PM   #1025
AustinTX
AustinTX's Avatar
I feel that the Z2's have a distinct grip limit, and that tended to cause lots of low speed understeer on my CS car (and on my STU STI in the past as well). The RS3's have a bit more wide/vague grip limit, which seems to balance my car out better. My driving style tends to explore the limits very aggressively, so I like the feel of the RS3's a bit better. I'm not the best judge of feel though - I just wanna go fast
Autocross nut
Old 07-11-2014, 02:53 PM   #1026
conedodging
conedodging's Avatar
Drives: '14 BRZ
Any reason to get one trim level over the others for STX? Weight differences seem marginal enough between the FR-S and the BRZ limited. Just a matter of driver preference?
conedodging is offline   Reply With Quote
Old 07-11-2014, 03:11 PM   #1027
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Get what you want. I got the BRZ Limited.. with all the goodies on it.. Fogs/rear wing/Alcantara/Auto ac.. it added 14lbs to the base car.. so its not that much.. and it is driver preference.
Bill
Scooby South is offline   Reply With Quote
Old 07-11-2014, 03:59 PM   #1028
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Is anyone running Hipermax IV SP coilovers?
How do they perform on a course?
Old 07-11-2014, 08:34 PM   #1029
Scooby South
Conedancer
here is a good reference to see what the differences are and the weight..
http://www.cars101.com/subaru/brz/brz2015.html
Bill
Old 07-14-2014, 12:00 PM   #1030
Wepeel
Drives: '13 BRZ Ltd
So more pressure and a few events to scrub them in make the Hankooks much better (ran 36/33 yesterday, up from 32/30 I was running before). I now think they are faster than the Rivals by a noticeable amount. Car had good balance yesterday on low-grip fedex, if not a little stable... I bet the car will push on the grippier surfaces. I picked up a WRX rear swaybar that I might try, or maybe I'll just up the rear pressures a little more for the grippier lots.
Old 07-16-2014, 02:45 PM   #1031
vroom4
What do you guys think about the HKS Hipermax IV SP coilovers? 8K kg spring rates and they come with camber plates.
I just worry about a rebuild when the time comes. Someone should bite the bullet and try these out for me! (Ill even hook you up with my source of getting them for ~1300).
vroom4 is offline   Reply With Quote
Old 07-16-2014, 02:52 PM   #1032
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
I'll gladly try them out for you. You can have them sent to my house. Thanks!
bimmer635csi is offline   Reply With Quote
Old 07-23-2014, 12:08 PM   #1033
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Apologize if this has been asked before....would this Header/front pipe setup be STX legal?
HKS eliminates the header cat, and maintains a high flow front pipe cat...but is this within 6 inches of the OEM front pipe cat? Any help is appreciated...
http://www.hks-power.co.jp/en/produc...haust/db/15165
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 07-23-2014, 12:12 PM   #1034
Scooby South
Conedancer
Yes...Legal.. Most of us have a catless header... only to have the cat in the over/mid pipe.. Perfectly legal
Bill
Old 07-23-2014, 01:13 PM   #1035
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
For you guys not taking to the Rs3s after Rivals. You have to drive on them differently. Also you have to get them into there heat range. 115 degrees up until 140 then start spraying. The rivals are better on the first run. Rs3s first runs are always a throw away run.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 07-23-2014, 03:44 PM   #1036
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
RS3 V2's are perfectly fine on the 1st run. I have run my fastest run on the first run.
2superblus is offline   Reply With Quote
The Following User Says Thank You to 2superblus For This Useful Post:
fstlane (07-24-2014)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
