#1009 | |
Conedancer
Drives: 2013 Subaru BRZ SWP
Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#1010 | |
Drives:
I might try some toe in. We're headed to pro-solo in a few days so if rather not be experimenting there haha
My STX build thread
http://www.ft86club.com/forums/showthread.php?t=55616 |
#1011 |
A little toe in for the rear goes a long way.
A little front compression damping could help as well. - Andy |
#1012 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
Does the Perrin Transmission Mount Support fall under the allowance jurisdiction for bushings or for mounts? I am trying to determine whether or not to even consider this mod.
http://www.ft86speedfactory.com/perr...mount-484.html
#1013 | |||
Conedancer
#1014 |
Drives: 2013 Cayenne turbo
Ok, I'm dumb. How do the K or W versions limit movement more than the P version?
Chris
Track, Autocross & Daily Driver build thread - SOLD Another A&DD for my VW GTI - SOLD And finally, my YouTube channel |
#1015 | |
Conedancer
Bill
#1016 |
Drives: '13 BRZ Ltd
So I started the season on Rivals, have about 180 runs on them between me and my codriver. A few weeks ago I got a set of RS3v2's and have put a couple of events on them. Same wheel (RPF-1 17x9), same size (245/40-17). Thought I'd share some observations:
I feel like I'm in the minority preferring the Rivals - not sure if it's my setup or driving style but my codriver agrees and we drive very differently. Running KW V3, camber plates, front bar. ~-3.0 deg camber. I will have some more events on the RS3 pretty soon, I'll try more pressure and maybe more camber to see if that improves things a bit. Anyone else compared these 2? |
| The Following User Says Thank You to Wepeel For This Useful Post: | jprice130 (07-10-2014) |
#1017 |
Gosh, if the Rival communicates better than an RS3, Im never leaving Dunlops. The Rival feels like a snow tire compared to the z2. (adapting driving style led to about the same times for me, however I really had to have faith the Rivals would stick.)
Also, Ive heard the RS3 needs a lot more camber, so you may have some time to be squeezed out of the RS3 if you do some car adjustments to suit them. |
#1018 |
So elite I'm 1338
Drives: WRB Subaru BRZ
I'm looking for tires for next season. Rivals, RS3 v2 and the new star specs are my top choices.
Although I hear some good things about the Yoko's too. |
#1019 |
180 treadware...no care.
#1020 | |
Drives: '13 BRZ Ltd
I know a lot of the S2k drivers have gone from Dunlop to RS3 but I haven't seen much comparison on the internet. And both the Rival and RS3 are very forgiving tires. They seem to both be able to operate at high slip angles without completely giving it up. |
#1021 | |
AutoX Nut
Drives: 2020 Toyota Supra
I've been running Dunlop ZIIs all season and just picked up a set of V2 RS3s this week (haven't competed with them yet). The ZIIs have been pretty good, but I'm getting tired of spraying them down so much now that summer is in full swing here in NC. Even with spraying them down, I'm still finding that the ZIIs start to give up at the end of my final runs. I'm really hoping the heat tolerance of the RS3s will help me continue to improve throughout all my runs AND I won't have to bother with the water sprayer. Sounds like the biggest adjustment will be driving around the soft sidewalls of the RS3s. The ZIIs are definitely razor sharp in slaloms and initial turn-in. |
#1022 | |
Drives: '13 BRZ Ltd
The 2 events I did on the RS3v2 were on slick asphalt (crappy fedex) and decently grippy asphalt (Hershey). Most likely will be running again at Fedex this weekend. Definitely post up your impressions of the RS3 compared to the Dunlop. |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 07:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 02:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 12:02 PM |
