Old 04-27-2016, 10:45 AM   #9983
WNDSRFR
Drives: FR-S,GTI
Originally Posted by Sojhinn View Post
But it's wailing and angry... So tesla would be happy.
Good point!
Old 04-27-2016, 11:38 AM   #9984
LBC Por Siempre
LBC Por Siempre's Avatar
Drives: 2008 Toyota Prius, 2012 911 Turbo
Wish I had the highest model of the Tesla S! Sub 3 second 0 to 60 and two electric motors powering the front and back wheels. Don't need an entire transmission... Just 2 gearboxes!
Tesla was also the Gran Daddy of how the world makes and distributes electricity. Yet he was into wireless electricity. He worked on Experiments in Colorado back in the teens and twenties and was lighting light bulbs a mile or more from where the electricity was distributed.
He also worked on a lot of other ideas for which later that science would prove correct.
LBC Por Siempre is offline   Reply With Quote
Old 04-27-2016, 12:32 PM   #9985
DAEMANO
Time Traveller
Originally Posted by WNDSRFR View Post
DC?
You mean Thomas Edison.
Haha correct! Rule#1. Never post and spreadsheet at the same time.
Old 04-27-2016, 04:55 PM   #9986
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Originally Posted by LBC Por Siempre View Post
The Build doesn't have a way of letting go of Excess Forced Induction?
nope, it just bleeds back through the compressor. But it doesn't have much excess boost to bleed off because the compressor has a brake on it that slows it down quickly when you disengage it.
Old 04-27-2016, 11:47 PM   #9987
Gums
Drives: SWP BRZ
Originally Posted by Shinobu's Smile View Post
It's not so much a woosh as it is more of a high pitched DC motor whine. Kind of like turning on a disassembled vacuum cleaner. But either way, the sound puts a smile on my face.
Fitted compressor support bracket from Keen As. Have rubber washers on mine, ESC still resonates through the radiator support panel. Sounds great
Gums is offline   Reply With Quote
Old 04-28-2016, 07:56 AM   #9988
WNDSRFR
Drives: FR-S,GTI
Yes
But Edison wouldn't have HEARD the wailing though. Would he?
Old 04-30-2016, 02:34 PM   #9989
danielwarren1
Drives: 2015 frs
Just installed the kit. I really can't tell the difference in cabin volume without the sound tube, so it's a non-issue if anyone was wondering. I still get the same level of sound feedback.
danielwarren1 is offline   Reply With Quote
Old 04-30-2016, 03:44 PM   #9990
godzuki
godzuki's Avatar
Drives: frs
Latest OFT tune for ESC AT 91 OCT?
Downloaded all the latest maps from OFT website (current as of 03/16) and have the following options for 91 Octane:
Stage 1
Stage 2 EL
Stage 2 UEL
Am I right in going with Stage 1?
Thought there was a map optimized for ESC at one time?
godzuki is offline   Reply With Quote
Old 04-30-2016, 05:27 PM   #9991
Sunrise161
Drives: 2015 FR-S RS 1.0
Stage 1
Stage 2 EL
Stage 2 UEL
Look up KoolBRZ on this or the users thread, he has a tune for the AT.
Sunrise161 is offline   Reply With Quote
Old 04-30-2016, 10:25 PM   #9992
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Stage 1
Stage 2 EL
Stage 2 UEL
Contact shiv he can send you the tune.
Installed Mods:
Old 05-01-2016, 01:47 AM   #9993
KoolBRZ
KoolBRZ's Avatar
What, what, my ears are burning!
The tune is dependent on exhaust back-pressure. I am currently working with an exhaust that has no cats, and only one resonator. The axle-back exhaust does supply some back-pressure though. The tunes Shiv posted before work fine for MT's, but low-end torque is sadly lacking for AT's with modified exhausts. If you have a completely stock exhaust though, you will have more low-end torque. Back-pressure = low-end torque, but limits high-end horsepower. It's all because the ESC pressurizes the Intake. When there is valve overlap, the ESC can simply blow the fuel straight through. Since the exhaust back-pressure is fixed, while intake, timing and fuel are variable, the tune then has to be adjusted to the exhaust.
That said, what is your CAL ID, and what are you running for exhaust?
If I say yes, will that make you think I understand?
Old 05-01-2016, 03:47 AM   #9994
godzuki
godzuki's Avatar
Drives: frs
Just an ESC, stock everything else including exhaust, 91 Oct. A00D CAL. thx
Old 05-01-2016, 04:27 AM   #9995
Sunrise161
Kool,
Was your Shredder tune good for stock manifold, TRD exhaust? If you're putting one together for godzuki, mine is D00D.
Old 05-01-2016, 03:09 PM   #9996
KoolBRZ
KoolBRZ's Avatar
At last, an A00D, the same as mine!
Kool,
The Shredder tune blew through too much fuel. Normally I'm not one to worry about wasting fuel, but the O2 sensor senses the wasted fuel and removes all the horsepower to compensate. At least that's what it feels like. The newest tune I'm working on has very little overlap at .40 load, so the ESC won't blow through so much fuel as to throw off the mixture. It doesn't work so bad with the ESC turned off even, since the late opening Intake at .40 helps to suck the charge into the cylinder. I'm trying out the most extreme example today. If it works out, I'll post tunes for A00D and D00D.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
