Old 03-16-2014, 06:42 AM   #981
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I guess it just comes down to how crazy you want to get with the car.
Old 03-16-2014, 06:43 AM   #982
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@CSG Mike
Is there anything that's more complicated than motion ratio in terms of suspenion? Or is that as bad as it gets?
Old 03-16-2014, 06:53 AM   #983
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by cdrazic93 View Post
@CSG Mike
Originally Posted by Racecomp Engineering View Post
There's the motion ratio but also things like camber curve, roll centers, bump travel, etc that are different and change differently front and rear. So there's a whole bunch of stuff to look at.
Old 03-16-2014, 07:02 AM   #984
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
See all that seems more docile than motion ratio...although roll center is a doozy...
Old 03-16-2014, 07:18 AM   #985
Captain Snooze
Drives: Red Herring
Watch out for roll centers. Is it not the center which the car rotates about but the point at which the car rotates about at that particular point in time depending on what the car is doing. That is, the roll center can move about, off center line as well. Should be called instantaneous roll point.
A lot of people are moving away from kinematic roll centers anyway and using force based roll centers and force application points (FAPs). The KRC is a good effective first look for most of us though especially in a simplified static condition.
Dimman (03-16-2014)
Old 03-16-2014, 12:49 PM   #986
Oh man, it gets way more complicated than motion ratios! Shocks on their own is a never ending rabbit hole of complicated lack of sleep. Always more to learn. Roll centers/FAPS and geometry are also very difficult concepts to grasp. Lots of things I'm still working on getting my head around.
- Andy
Old 03-16-2014, 01:18 PM   #987
Dimman
Kuruma Otaku
Dimman's Avatar
Virtual centers (roll center is one type) for geometry are a PITA. Take point A and point B, draw an imaginary line until it intersects another imaginary line off of another set of points, in 3 dimensions, and can possibly end up underground or in the middle of the car. And the initial points change as the suspension moves, so a degree of recalculation needs to be done for different suspension positions. And those virtual centers then affect how other points with virtual centers move.
Fun times.
Because titanium.
Old 03-16-2014, 03:38 PM   #988
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
This would be a good sig lol
Good to know I need more math to accurately understand what is happening...yaaaay calculus
The Following User Says Thank You to cdrazic93 For This Useful Post:
solidONE (03-16-2014)
Old 03-16-2014, 04:11 PM   #989
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
How do I dislike this or "No Thanks" this post?
CALLUCUS!!!!!!!
Old 03-16-2014, 05:04 PM   #990
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
Will the Bilstein B14 PSS work well with 215/45-17 Michelin Pilot Super Sports on 14 lb Kosei K4r 17X7 wheels?
What would be a good Sway bar setup for the above parts?
Goals for car are:
-DD with 4-5 track days a year max
-Good ride quality for crap Detroit roads
-Equal steering response to stock or better
-Neutral to slight oversteer handling
I am also open to other coilover options under or around 1500$.
Thanks
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 03-16-2014, 08:33 PM   #991
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
CALLUCUS!!!!!!!
I know I feel the pain too Dx
Old 03-16-2014, 08:36 PM   #992
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Goals for car are:
Around $1,500 you say? RCE Tarmac 0's would be better applicable to the situation IMO, since they are a bit more aggressive than the B14's are, and probably better feel around the track those 4-5 days out of the year.
Racecomp Engineering (03-16-2014)
Old 03-16-2014, 09:16 PM   #993
psyclone07
psyclone07's Avatar
Drives: WRB BRZ
CSG and RCE tag-team suspension Q&A thread! Ask us anything!
I am getting a lot of mixed responses when it comes to a question I have and was wondering if you guys could help out.
I have some RCE tarmac 2 going on once the weather gets nice and will be doing some occasional autocross and possibly track days. The car is more of a weekend driver.
I am looking for a decent lightweight rim for autocross and track days/occasional weekend driving. The RpF1's are great rims but I am leaning toward the TsW nurburgrings (simply aesthetics in this case) in a 18x8 w/ 35mm offset(18.6lbs).Would the 10mm difference in offset be detrimental in comparison to the 45mm. Also the 1 inch increase from 17 as well.
I am also looking for tire suggestions as well if you have any. Probably looking to get some Michelin pilot super sports in 225/40/18. (Another mixed area as some people say drop in the widest tire possible and others disagree.)
I appreciate your time and insight. Thanks in advance.
psyclone07 is offline   Reply With Quote
Old 03-16-2014, 09:33 PM   #994
Goals for car are:
Thanks
Not a bad choice. For track work (and in general) I prefer linear spring rates and I wish the Bilsteins were slightly firmer up front but they have good valving. I'd add a front bar at least.
RCE T0 would be worth considering.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
200hp/tonne (03-17-2014)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
