Old 10-15-2013, 03:20 PM   #981
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by nelsmar View Post
I just want to make sure I have a clutch that can handle any "future" modifications if i end up getting bored and wanting a bit more power. I can always swap on a new header or upgrade my pulley one more notch. There is still a bit of power left in this unit so I dont want to restrict my self via clutch. But I think in reality im going to get stuck going full face. I wish someone had done some testing on one.
which clutch are you on?
I think that all the ACT kits come with the same pressure plate whether you get a 6 puck or a full face. I am not sure about the Clutchmasters though. I have the ACT 6 puck because like you, I didn't want to not have enough clutch.
Old 10-15-2013, 03:39 PM   #982
jamesm
i went with the full face and fear i shouldn't have. i was afraid of the harshness of the 6 puck having never driven one to know for sure. damnit lol.
Old 10-15-2013, 03:43 PM   #983
nelsmar
Originally Posted by Dezoris View Post
Jeeze I am shocked it still works. Make sure you swap some hard core trans fluid in if you haven't already. Gonna be a hell of a lot more shock!
Good luck.
That stock fluid was out after toyota told me i was good to pull it (they wanted me to "wear in" the transmission). Moment I got a green light Motul went in...
Oooo I am going to have to check on this then. I might just have to push in therapy and man up =x
My flickr - Canibeat
Local magazine scout
Old 10-15-2013, 05:40 PM   #984
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
I tapped 360whp on the dyno today with a 3.125 pulley and e80 fuel. . Plot shows hood open vs hood closed.
Stock exhaust. No snorkel. 3.125 pulley. Fa20club flex fuel and tune. Dw65
Pump 540cc injectors. Berk test pipe.
Great numbers Marin!
Brian@Vortech is offline   Reply With Quote
The Following 2 Users Say Thank You to Brian@Vortech For This Useful Post:
nelsmar (10-17-2013), Rick@Vortech (10-15-2013)
Old 10-17-2013, 01:15 AM   #985
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Very impressive
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following User Says Thank You to AZFA20 For This Useful Post:
Old 10-17-2013, 10:33 PM   #986
nelsmar
Thanks!
Hopwfully in the next few weeks i can cycle down to 91 octane and re dyno for a comparison between the pulleys. after that I'll write up a little review and comparison between setups I've driven and tested Now that I've got the belt and most of the issues panned out I can finally finish up the testing I was doing over a month ago!
P.S. This kit is a blast at this level.
The Following 2 Users Say Thank You to nelsmar For This Useful Post:
pheoxs (10-19-2013), Rick@Vortech (10-18-2013)
Old 10-24-2013, 02:29 AM   #987
Dezoris
Dezoris's Avatar
For those in a colder climate how is your car performing?
Now that we have hit colder temps, the blower sound when cold is somewhat alarming.
The oil cooler also is going to have to be disconnected I can't get oil temps above 165F Even blocked off in 20 minutes of driving.
@Rick@Vortech @Brian@Vortech Can you guys provide the temperature operating range of the SC oil and thoughts about this?
Old 10-24-2013, 09:47 AM   #988
Foobar
SLO NO MO
Foobar's Avatar
Got a video of that sound? We're still in the overnight 40s here in NY so nothing freezing yet. The Vortech hasn't sounded any different to me at these temps. Has it dropped below freezing in Chicago already?
Also, consider putting an engine blanket over the entire engine bay overnight, or if you want to go cheap, just get one of these types of heating pads and cover the Vortech? [ame="http://www.amazon.com/Kats-24150-Watt-Universal-Heater/dp/B000I8TQD6"]Amazon.com: Kat's 24150 150 Watt 4"x 5" Universal Hot Pad Heater: Automotive[/ame] Just kinda wrap it around the blower so it provide enough ambient heat to the oil I guess. Might need some additional thermal layer type material to enclose it.
Old 10-24-2013, 10:35 AM   #989
charged86
charged86's Avatar
Do we seriously need a heat blanket
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 10-24-2013, 11:00 AM   #990
Foobar
SLO NO MO
Foobar's Avatar
I've heard of other folks with Vortech V3's go through winters in sub-freezing temperatures without one, but keep in mind that Vortech themselves have put that stipulation in the warranty documents. Cold-starting the car in sub-25 Fahrenheit temperatures without an engine heater/blanket is enough for them to void your warranty.
Do we seriously need it? To keep things running no, you're probably OK unless you're in seriously arctic conditions. Do you want to avoid the risk? Then I'd get a heated garage or some way to keep at least the Vortech warm enough that its oil doesn't cause issues in the cold.
IMPORTANT COLD WEATHER INFORMATION
In order to achieve the low noise level of Vortech superchargers, Vortech specifies manufacturing procedures that call for minimal internal clearance. These precise tolerances however are not conducive to temperatures below 25° F. Therefore, storing the vehicle in a heated garage and/or employing the use of an engine block heater/aftermarket engine blanket is required when the vehicle is subjected to a "cold startup" in ambient temperatures below 25° F. Failure to comply with this may result in immediate supercharger failure and invalidate the supercharger warranty.
The Following User Says Thank You to Foobar For This Useful Post:
Rick@Vortech (10-24-2013)
Old 10-24-2013, 12:01 PM   #991
Rick@Vortech
Drives: Scion FR-S
If the temperature is below 25F degrees, then we highly suggest a engine heater/blanket to warm it up. @Foobar pretty much got it right on the money.
Rick@Vortech is offline   Reply With Quote
Old 10-24-2013, 12:16 PM   #992
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Any idea if the temperature range changes for the oil fed unit?
Nolan
pheoxs is offline   Reply With Quote
Old 10-24-2013, 02:22 PM   #993
Dezoris
Dezoris's Avatar
So basically the kit has to come off for the winter. Or in my case off forever now.
I am hearing noise already noise when starting in 40 ambient temps. My garage is heated but when I park outside at work all day it's clearly going to lose heat fast.
An engine block heater is not going to warm the SC oil.
This reminds me of why I stayed away from modding cars for so long.
Old 10-24-2013, 02:34 PM   #994
Foobar
SLO NO MO
Foobar's Avatar
Not to nitpick your decision to remove it permanently, but we discussed this very topic back in May and Brian confirmed the temperature < 25 stipulation in his response to you: http://www.ft86club.com/forums/showp...&postcount=339
What else changed that is now bringing you to the decision to remove it forever? I'm not trying to be a **** here, I'm honestly curious if you've encountered other negative issues with the kit.
The block heater is probably enough to keep ambient temperature in the engine bay at a safe enough point, but I guess this all depends on a lot of variables which confirms for me that the verbiage in the Vortech warranty doc is legal "CYA" content.
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 06:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 04:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 07:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 06:06 PM
