#981 |
Drives: '23 BRZ
FR-S and GC have similar suspension architecture, they don't have "the same suspension". Geometry and spring/damping/swaybar rates are very important!
From a tire width per vehicle weight perspective, GC ~3450+200lb/(2x225+2x245) = 3.88 lb/mm FR-S ~2700+200lb/(4x215) = 3.37 lb/mm 15% more tire per weight, slight handling advantage to the FR-S *if on the same make/model tires*, and *assuming* equivalent suspension. |
#982 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
#983 | |
86 Member
#984 |
Kuruma Otaku
Not quite.
It's debatable, but the strut setup of the GC may actually be superior* to the FR-S'. It has two lower links and was originally a BMW development having to do with moving 'virtual steering centers'. It's a complicated relationship that comes down to effective application, but there is a chance that the GC could have more precise or better feeling steering at no penalty. Also the GC has a more complicated multi-link design in the back, as it doesn't have an upper wishbone, but also separate links. This may be a wash though, as to which is better in the back. * Yes I said the GC may have a better front suspension than the FR-S. Shock and awe...
Because titanium. |
#985 |
Drives: Acura RSX-S
Don't know about anybody else, but I am looking for a daily driver and strongly considered a Miata, but didn't want a convertible. The power hardtop Miatas in Canada are very expensive.
#986 | |
Kuruma Otaku
Here is what me and Exage are getting at: So if the 210 hp/180 whp motor guys were getting 240 whp (+60 whp, nice gain) after mods, I don't think the new ~270 hp (probably ~230 whp) motor guys will see much more than 250 whp after similar mods (~+20 whp). Unless the turbo is significantly upgraded over the outgoing one.
Because titanium. |
#987 | |
86 Member
#988 | |
GL 86!
Drives: Maybe FR-S... maybe not
I don't really care enough(/lack of info) to find if the injectors have been swapped on the twin scroll (550cc?). If they haven't for some reason, then they know the safe wall at just over 20psi of boost. |
#989 |
Kuruma Otaku
550cc would put its fueling/max power capability (pending pump) at 2/3 of a 2JZ. So ~280 crank would be probably pushing it for the fuel system. And even less if the turbo falls way out of its efficiency range to get there.
GenCoupe problem for me isn't really either engine, its that the chassis tries to span two different classes. 3.8 GenCoupes are clearly trying to be a cheap G37 competitor, but having a chassis that fits that bigger, comfier car and bigger V6 hurts the potential of the 2.0T. If they had decided to separate the luxo-GT from the more sports-tuner (smaller, lighter, de-contented), they would have had a winner, with no questions in the 2.0T. So Toyota and Subaru want to seize that niche. If a turbo FA16 comes a year or two later, Hyundai will not be able to compete, I think. But if the GenCoupe was a bit smaller and maybe 200 lbs lighter, I don't think the FT86 would have even got the production go-ahead. This is where Hyundai should have grown some balls and tried to lead a market, rather than follow Infiniti's G37 market.
Because titanium. |
#990 |
86 Member
I agree with you Dimman. But I still like the GC.
#991 | ||
Drives: '23 BRZ
Details like this aren't anything like as important as the *execution*. Geometry, damping rates, bushing stiffnesses, on and on. Quote:
All that said, I'm sure that Hyundai is further up the curve now, and that Toyota/Subaru will also have a well-developed setup. |
#992 | |
Kuruma Otaku
![]() From what I've heard (but no personal experience), the GenCoupe has a ways to go with the execution. Thing I remember off the top of my head is something about inadequate travel before smacking bump stops during any kind of 'sporty' driving. I have still some mixed feelings about Hyundai, left over bias from their Pony days measured against their current improvement. But stuff like the GenCoupe's suspension confuses me, and makes me still view them negatively from a performance point of view. The fact is they did put a more complicated (and probably more expensive than necessary) suspension into the car. This could be seen as good. But the fact that I have read nothing about exemplary handling with regards to the car says, to me at least, that they ultimately failed, or have an incomplete understanding of what they are doing. They had a clean sheet during the design process and came up with a 'meh' car that cosmetically and on-paper was more geared to mimicking a G37, than being an actual driving car. So Hyundai over-complicated and under-delivered. At least from the sports side of things. In the FR-S/BRZ's case, the suspension and braking components are basically from the Legacy/Impreza parts bin trans/diff from existing TMC products, yet the application has made everyone who tested it in a sporting setting get all silly in love with it. TMC/FHI simplified and over-delivered. That to me is why the FT86 > the GenCoupe.
Because titanium. |
#993 | |
Drives: honda civic si 08
#994 |
86 Member
This is actually their first attempt at a sports coupe. You can't count that FWD junk tiburon. But in the GC size class it is not a bad car like you're making it out to be. Yeah it wasn't intended to be a small lightweight coupe and maybe that's what you and others wanted it to be. In other words Hyundai didn't fail because of pedigree. They just failed to go the lightweight, RWD route. I have driven other medium sized RWD sports coupes and the GC excels amongst them.
| FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc | JDMinc | FR-S / BRZ vs.... | 559 | 05-15-2014 07:50 PM |
| FR-S/Subie Coupe fantasy | Maxim | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 06-10-2011 01:25 PM |
| new Kia coupe | Ground N Pound | Other Vehicles & General Automotive Discussions | 22 | 12-29-2009 02:04 PM |
