Old 02-01-2012, 05:31 AM   #981
ZDan
ZDan's Avatar
Drives: '23 BRZ
FR-S and GC have similar suspension architecture, they don't have "the same suspension". Geometry and spring/damping/swaybar rates are very important!
From a tire width per vehicle weight perspective,
GC ~3450+200lb/(2x225+2x245) = 3.88 lb/mm
FR-S ~2700+200lb/(4x215) = 3.37 lb/mm
15% more tire per weight, slight handling advantage to the FR-S *if on the same make/model tires*, and *assuming* equivalent suspension.
Old 02-01-2012, 06:21 AM   #982
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by serialk11r View Post
Exage is right, if the engine only has a different turbo, then it just means that the gains people were making with easy mods has been partially eaten up at the factory already.
Only time will tell but I feel you guys will be shocked.
SUB-FT86 is offline   Reply With Quote
Old 02-01-2012, 06:23 AM   #983
SUB-FT86
86 Member
Yeah I meant to say architecture.
Old 02-01-2012, 01:18 PM   #984
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by SUB-FT86 View Post
Both the FRS and GC have the same suspension.
Not quite.
It's debatable, but the strut setup of the GC may actually be superior* to the FR-S'. It has two lower links and was originally a BMW development having to do with moving 'virtual steering centers'. It's a complicated relationship that comes down to effective application, but there is a chance that the GC could have more precise or better feeling steering at no penalty.
Also the GC has a more complicated multi-link design in the back, as it doesn't have an upper wishbone, but also separate links. This may be a wash though, as to which is better in the back.
* Yes I said the GC may have a better front suspension than the FR-S. Shock and awe...
Because titanium.
Old 02-01-2012, 02:37 PM   #985
val_lixembeau
Drives: Acura RSX-S
Originally Posted by Sully View Post
Question for all you really weight worrying people: Is your prospective FR-S/BRZ/GT86 going to be your daily drive? Do you need it to be?
If no? Why not just go all out and get yourself a Lotus 7 kit? Or used Elise/Exige? RX-7? Miata?
Don't know about anybody else, but I am looking for a daily driver and strongly considered a Miata, but didn't want a convertible. The power hardtop Miatas in Canada are very expensive.
val_lixembeau is offline   Reply With Quote
Old 02-01-2012, 03:14 PM   #986
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by Exage View Post
Well from what I gathered from the basic knowledge Hyundai put a twin scroll turbocharger and a larger intercooler as the main reasons why it now develops 274hp. I'm therefore under the belief that the engine itself hasn't changed significantly (The 2.0T is still not DI; the V6 is though). This results in that the engine that will not see easy significant gains like the previous.
No no, I'm no superstar hahaha. It's was good, lots of fun things to get the hands dirty and boggle the mind!
Yes you misread my post. Re-read my comment: I figure they'll achieve only slightly better outputs as the previous, so gains aren't going to be as spectacular.
Well if the turbo is different, I will assume the compressor may be a bit bigger too. If they are going to a twin scroll for better spool(shocked at how this is considered 'high tech' to tuning communities new to turbos, check out Toyota turbos circa late 1980s...) and bigger IC, I'll make an assumption that the cold side is going to flow a bit more air as well. But probably not significantly more than the outgoing one. And that is the choke point on the engine when it comes to 'easy' mods.
Here is what me and Exage are getting at:
So if the 210 hp/180 whp motor guys were getting 240 whp (+60 whp, nice gain) after mods, I don't think the new ~270 hp (probably ~230 whp) motor guys will see much more than 250 whp after similar mods (~+20 whp). Unless the turbo is significantly upgraded over the outgoing one.
Because titanium.
Old 02-01-2012, 03:31 PM   #987
SUB-FT86
86 Member
The old turbo was a single scroll that everybody hated on the forum. I actually would never buy a 2.0T GC though. I like N/A so 3.8 was the only option.
Old 02-01-2012, 04:14 PM   #988
Exage
GL 86!
Exage's Avatar
Drives: Maybe FR-S... maybe not
Perhaps I was looking into that Hyundai GEMA engine and it seems like get stuck with fuel delivery on the stock injectors. Over 20psi boost it seemed like they recommended a 550cc or Evo X drop-in (, then a new turbocharger).
I don't really care enough(/lack of info) to find if the injectors have been swapped on the twin scroll (550cc?). If they haven't for some reason, then they know the safe wall at just over 20psi of boost.
Exage is offline   Reply With Quote
Old 02-01-2012, 05:32 PM   #989
Dimman
Kuruma Otaku
Dimman's Avatar
550cc would put its fueling/max power capability (pending pump) at 2/3 of a 2JZ. So ~280 crank would be probably pushing it for the fuel system. And even less if the turbo falls way out of its efficiency range to get there.
GenCoupe problem for me isn't really either engine, its that the chassis tries to span two different classes. 3.8 GenCoupes are clearly trying to be a cheap G37 competitor, but having a chassis that fits that bigger, comfier car and bigger V6 hurts the potential of the 2.0T. If they had decided to separate the luxo-GT from the more sports-tuner (smaller, lighter, de-contented), they would have had a winner, with no questions in the 2.0T.
So Toyota and Subaru want to seize that niche. If a turbo FA16 comes a year or two later, Hyundai will not be able to compete, I think.
But if the GenCoupe was a bit smaller and maybe 200 lbs lighter, I don't think the FT86 would have even got the production go-ahead. This is where Hyundai should have grown some balls and tried to lead a market, rather than follow Infiniti's G37 market.
Because titanium.
Old 02-01-2012, 06:07 PM   #990
SUB-FT86
86 Member
I agree with you Dimman. But I still like the GC.
Old 02-01-2012, 06:23 PM   #991
ZDan
ZDan's Avatar
Drives: '23 BRZ
Not quite.
Audi and others have done this as well. It's a way to reduce scrub radius with strut suspensions.
Details like this aren't anything like as important as the *execution*. Geometry, damping rates, bushing stiffnesses, on and on.
Back or front, more joints and more complicated mechanisms do not necessarily equate to "better". Best for performance is still simple upper and lower control arms with toe links (steering tie rods up front). But again, execution and details are hugely important (double-wishbones all around not fully sorted/tuned isn't going to be superior to struts/multilink).
All that said, I'm sure that Hyundai is further up the curve now, and that Toyota/Subaru will also have a well-developed setup.
Old 02-01-2012, 07:58 PM   #992
Dimman
Kuruma Otaku
Dimman's Avatar
Which is why I used words like 'debatable' 'may' 'effective application' and 'could'.
From what I've heard (but no personal experience), the GenCoupe has a ways to go with the execution. Thing I remember off the top of my head is something about inadequate travel before smacking bump stops during any kind of 'sporty' driving.
I have still some mixed feelings about Hyundai, left over bias from their Pony days measured against their current improvement.
But stuff like the GenCoupe's suspension confuses me, and makes me still view them negatively from a performance point of view.
The fact is they did put a more complicated (and probably more expensive than necessary) suspension into the car. This could be seen as good. But the fact that I have read nothing about exemplary handling with regards to the car says, to me at least, that they ultimately failed, or have an incomplete understanding of what they are doing. They had a clean sheet during the design process and came up with a 'meh' car that cosmetically and on-paper was more geared to mimicking a G37, than being an actual driving car.
So Hyundai over-complicated and under-delivered. At least from the sports side of things.
In the FR-S/BRZ's case, the suspension and braking components are basically from the Legacy/Impreza parts bin trans/diff from existing TMC products, yet the application has made everyone who tested it in a sporting setting get all silly in love with it.
TMC/FHI simplified and over-delivered.
That to me is why the FT86 > the GenCoupe.
Because titanium.
Old 02-01-2012, 08:10 PM   #993
catharsis
Drives: honda civic si 08
I understand why the gen coupe is not good. Hyundai has no racing pedigree, they have no understand how to properly set up a car. This is really their only second attempt? I believe at a sports car, so it is what it is.
catharsis is offline   Reply With Quote
Old 02-01-2012, 08:58 PM   #994
SUB-FT86
86 Member
This is actually their first attempt at a sports coupe. You can't count that FWD junk tiburon. But in the GC size class it is not a bad car like you're making it out to be. Yeah it wasn't intended to be a small lightweight coupe and maybe that's what you and others wanted it to be. In other words Hyundai didn't fail because of pedigree. They just failed to go the lightweight, RWD route. I have driven other medium sized RWD sports coupes and the GC excels amongst them.
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 07:50 PM
FR-S/Subie Coupe fantasy Maxim Scion FR-S / Toyota 86 GT86 General Forum 23 06-10-2011 01:25 PM
new Kia coupe Ground N Pound Other Vehicles & General Automotive Discussions 22 12-29-2009 02:04 PM
