Old 01-02-2016, 11:34 AM   #9801
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by Sojhinn View Post
For shivs tune it's for everyone. I don't have an aftermarket header but I use it.
so doesnt matter with oem or aftermarket for ESC?
i didnt know and just wanted make sure.
Old 01-02-2016, 11:35 AM   #9802
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
You are correct sir
Installed Mods:
Old 01-02-2016, 12:03 PM   #9803
zc06_kisstherain
Drives: SWP BRZ
You are correct sir
Great!
thank you~!
I will take some time to take pictures of DIY and post.
your DIY was so easy to follow as well
Old 01-02-2016, 12:10 PM   #9804
Sojhinn
Sojhinn's Avatar
Great!
thank you~!
Message me if you run into any issues.
Installed Mods:
Old 01-02-2016, 12:13 PM   #9805
KoolBRZ
KoolBRZ's Avatar
The difference between the different Exhaust tunes
There is a difference. An open exhaust has a much stronger scavenging effect, especially with the ESC running. The charge can be blown right through with enough overlap at the right time, since the Port Injection is active at low speeds. The OEM header will give you more torque down low, because the back pressure won't allow as much blow-through, but it quickly becomes a restriction above 4000 rpms.
Tunes written for open exhaust and catted headers are different in the AVCS tables. OEM header tunes have much more overlap to take advantage of the back-pressure, while those written for open exhausts have much less Exhaust retard, to prevent blow-through. The difference is audible. You can hear when there is more retard, because it gets much louder.
All my tunes have a bit too much retard for an open exhaust. They are loud when you open them up, but quiet down when just cruising. I usually tune for the limit, when power starts to fall off from over-scavenging. This means they will still perform well in more restrictive exhaust setups.
If I say yes, will that make you think I understand?
Old 01-02-2016, 01:13 PM   #9806
zc06_kisstherain
Drives: SWP BRZ
thanks for clarification!
I will upload your map once installed
Old 01-02-2016, 11:34 PM   #9807
zc06_kisstherain
Drives: SWP BRZ
I am almost done installing esc and wondering these are correct fitment. I think i am ok with it but wanted to make sure
I didnt have enough time to finish it today but i will tomorrow morning.
I spent most of my time drilling that intake resonator. also make wires to go through driver to passenger side from center console.
also throttle switch wires barely made to controller!! hope Rob can make wires little longer for future customers.
It's pretty straight forward installation even you don't watch DIY video but it helps a lot.
I will post some DIY pictures and post when i finish it tomorrow.
Old 01-03-2016, 02:42 AM   #9808
KoolBRZ
KoolBRZ's Avatar
Can you bring it just a bit closer to the throttle body? My metal connector sleeve doesn't show at all, and the whole thing is about .25" closer to the throttle body. Just my .02.
Old 01-03-2016, 02:43 AM   #9809
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
I concur. Also rotate the snail about 5-10 degrees clockwise.
Installed Mods:
Old 01-03-2016, 09:57 AM   #9810
zc06_kisstherain
Drives: SWP BRZ
thanks guys. I had test drive after installation this morning and Wow! more power!! this is datalogging i had.
http://www.datazap.me/u/zc06kissther...og=0&data=1-11
and this is just cruzing around~
I will try to make adjustment on throttle body and snail
Old 01-03-2016, 10:23 AM   #9811
justinsstang
Down to 1.6psi by 7k rpm lol, the initial boost is okay for what it is, but not being able to provide any at high RPM is a drag.
justinsstang is offline   Reply With Quote
Old 01-03-2016, 10:42 AM   #9812
justinsstang
Just curious after reading a small amount in this post, how do these battery packs stay charged?
If not by alternator, maybe an aftermarket "beefier" alternator needs to be made to charge the original battery, plus have connections to keep the additional battery pack charged. Logic or nah? Never messed with electric boost, only real blowers so far (which I'll 99.9% likely stay with lol, just interested in the facts).
Old 01-03-2016, 11:31 AM   #9813
KoolBRZ
KoolBRZ's Avatar
Load your snow tunes and get ready to snow-drift!
After 2 years of non-winters, we finally have SNOW! I bought taller, wider tires to get better grip in the rain. Now I'll get to see how they do in the snow. I've always loved sliding in the snow, ever since I first learned to drive. That's the most important reason to get rear-wheel-drive.
Old 01-03-2016, 12:40 PM   #9814
zc06_kisstherain
Drives: SWP BRZ
I made adjustments but snail section looks like little crooked because of its angle.. Should be ok? Little annoying to make it fit perfect. Are those datalog look ok?
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
