go_a_way1, MisterSheep
Old 01-10-2016, 12:24 AM   #85
Antuono
Drives: 2014 BRZ
highest i ever got was 27
Antuono is offline   Reply With Quote
Old 01-10-2016, 09:24 AM   #86
Cole
Not a troll
Cole's Avatar
Originally Posted by Stang70Fastback View Post
No, that's totally understandable. He just made it sound like he drives to work back and forth and that's about it. I don't understand how you can own a car like this and NOT put a shit ton of miles on it, lol.
I've owned mine for about 13 months now. I have less than 17000km (about 10500 miles). I don't even really "daily" mine anymore. It's pretty much just a weekend car that I sometimes take on longer drives.
Old 01-10-2016, 12:46 PM   #87
BRZnut
Drives: BRZ DGM Limited
40-43 MPG on long (5-10hrs) trips with cruise control set at 65 or 70.....28 MPG around town (short 5 mile drives to work) in the summer and 27 MPG in the winter.
Old 01-10-2016, 01:08 PM   #88
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Winter blend fuel gives overall lower MPG. If you're letting the car warm up, your MPG calc goes down (wasted fuel without movement).
Check tire pressures and alignment. Check air filter to see if its dirty or clogged. Any exhaust issues? All these can add up to lost MPG. Also bad gas?
SpectreRT is offline   Reply With Quote
Old 01-10-2016, 01:28 PM   #89
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Sorry, but I'm having a VERY hard time believing those numbers. At all.
Stang70Fastback is offline   Reply With Quote
Old 01-10-2016, 03:18 PM   #90
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
~26mpg cruising on the highway means you need better control of your right foot and driving habits. The FR-S should easily get 30mpg average cruising @ 80-85mph...I can get 31mpg cruising @ 85mph on long trips between Texas and Utah in my MT FR-S... it's all about managing the throttle pedal and vehicle inertia/momentum...never slow down or brake unless absolutely needed, and don't use cruise control.
You need to be able to accelerate on downhill sections (while keeping above 30mpg average under acceleration) that lead to uphill sections..trading potential energy for the momentum to get you up the incline. And don't ever drop below 75mph going uphill...you loose that much rpm and it wastes a lot of fuel to get back to 80mph. I use the instantaneous mpg display as engine load indicator - you fine tune the pedal pressure to keep it reading as high as possible at all times.
Keeping between 80-95mph while cruising is the goal; ideally you don't want drop below 80 at any time when climbing - trading built up speed for the push to get you up the incline (you will need to sacrifice 10-15mph), maximize speed going downhill to buildup the necessary potential energy for the following uphill section, and stick to 85 when things are relatively level. Helps to have 80mph speed limit. It's a fun game to time it just right to have your speed drop bottom out at 80mph right when making apogee...and keeping the instantaneous mpg reading as high as possible under all conditions.
And I average 20-21mpg daily driving. All the mpg figures used are calculated based off distance and gallons used at the fuel pump...not what the car reads.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 01-10-2016, 04:48 PM   #91
Antuono
Drives: 2014 BRZ
Yeah i call BS i drive 4 hours once a month all highway and i only see 28mph.
i have yet to see even 30 mpg like the sticker said.
Old 01-10-2016, 05:09 PM   #92
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
You will also lose the MPG if you are running stickier or large tires.
Muaddib is offline   Reply With Quote
Old 01-11-2016, 12:04 AM   #93
Stang70Fastback
A.K.A. Starlord
Sorry, but what you just described is how to be a really, REALLY annoying asshole on the highway. I absolutely HATE people who drive like that. You should maintain a constant speed on the highway, ideally by using cruise control. Otherwise you're just that **** that passes me going downhill, only for me to have to pass them again for the umpteenth time on the next incline. I don't give two hoots about your need to get that extra 1 or 2 MPG. The world doesn't revolve around you, so maintain a constant speed instead of becoming an annoying obstacle for all of the other drivers on the road.
Sorry if that comes across as harsh, but people who can't maintain a constant speed on the highway are some of the most infuriating drivers on the road.
Also, I don't know why you think you have to avoid cruise control to get good mileage. I set my cruise control to 78 MPH and I average 33 MPG.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Bonburner (01-11-2016)
Old 01-11-2016, 12:23 AM   #94
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Is it really so bad to not use cruise control? I'm asking because I've never used it. I dont feel comfortable unless I'm alert and in control the whole drive. Even for five hour long drives, I've never used cruise control.
I do keep a pretty consistent speed using my foot though. Although highway traffic around here isnt real consistent anyway, I feel like cruise control would be useless.
PandaSPUR is offline   Reply With Quote
Old 01-11-2016, 12:39 AM   #95
Ultramaroon
not playing cards
Ultramaroon's Avatar
It's not bad at all. Your choice. You've already emphasized the most important aspect of your drive, that you remain alert and in control the whole time.
Dadhawk (01-11-2016), Stang70Fastback (01-11-2016)
Old 01-11-2016, 02:43 AM   #96
Stang70Fastback
A.K.A. Starlord
You definitely don't NEED to use it. It just helps maintain a constant speed. However it isn't hard to do that yourself. Just makes it easier. My favorite game to entertain myself in light traffic is the "try not to have to cancel the cruise control" game, lol.
Ultramaroon (01-11-2016)
Old 01-11-2016, 02:47 AM   #97
Ultramaroon
not playing cards
I use cruise driving through neighborhoods. Keeps me honest. :/
Old 01-11-2016, 02:56 AM   #98
Antuono
Drives: 2014 BRZ
But what happens when your blowing through stop signs? And running over kids?
