#85 |
Drives: FR-S Whiteout
Yes I have data of the setup I test. no data beside feel of the Flex Z
Intent > Content
cowardice is the mother of cruelty. |
#86 | |
If you have sufficient rebound damping, but insufficient compression damping, the end result would be that you downjack the wheels, until you're riding the bump stop or run out of compression stroke, resulting in just a bumpy rear that bounces along. Every bounce would result in the damper compressing more than it decompresses, quickly resulting in running out of stroke. Lack of compression damping would not result in wallowing. |
#87 | |
Now, if it was jacking down with -5, then it would have been even worse at -1. Since the single adjustable Flex-z is a rebound adjustment and not compression, it only increases compression by a very small amount compared to rebound. In other words, the increased compression damping prevented it from riding on the bumpstop mid corner.
Intent > Content
#88 | |
Your conclusion, while valiant, is incorrect. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | swarb (11-23-2015) |
#89 | |
It's not like I'm the only person with access to these dampers. I invite anyone to test the setting yourselves. "while valiant, is incorrect" lmao... what a db...
Intent > Content
#91 | |
BTW The Flex Z I tested was riding on 255/40/17 595RSRR tires, so it as a lot of grip.
Intent > Content
#92 | |
![]() I'm not sure why you're trying to do "performance driving" with the Flex-Z. I've said it before and I'll reiterate here: these are not really meant for someone that's looking for extreme cornering performance, nor are they made to be paired with fat, sticky tires. The Flex Z is a great value for someone who wants to lower their car, clear wider wheels, and do some casual driving, not "hardcore canyoning" or tracking. |
#93 | |
So what are the Mike Kang settings, Mike Kang?
Intent > Content
| The Following User Says Thank You to solidONE For This Useful Post: | mulekr1 (09-21-2016) |
#94 | |
The Fail Boat
Drives: CWP S.B.
Either you guys man up & get a US sepc Tein A here (like you did with the Z) or stop promoting Tein Z in a Tein A thread... ![]() Thank you? |
#95 | |
#96 |
"bashing a product" says the person who does the most bashing on these forums.... Where did I bash.. stop trolling. I know you don't have better things to do, but just stop.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 11-24-2015 at 02:09 AM. |
#98 | |
Drives: GT86
Not sure. If wallowing is the suspension riding the bumpstop, then perhaps so, as the HBS won't have the return jolt of the compressed rubber bumpstop releasing its energy. But if your cornering very hard on high grip, the HBS can't compensate for lack of roll stiffness (too low spring rate or sway bar stiffness) that compromises the bump travel. How much bumpstop-free bump travel is there on the Z front/rear? If it is anything like the A where there is a full 1" more travel at the rear, I would expect problems in front first.... |
| Tein Flex A and Z!!! | breadcrumbz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 05-24-2016 04:44 PM |
| Tein Flex Z | Bigmaxy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 01-27-2015 04:22 AM |
| WTB - Tein Street Flex and some LCA's | Sugi | Want-To-Buy Requests | 1 | 01-25-2015 04:12 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 02:10 PM |
| FS: Tein Flex Coilover | Jade 86 | Brakes, Suspension, Chassis | 43 | 06-15-2013 10:35 PM |
