Old 05-14-2015, 12:57 PM   #85
Porcupint
Drives: 13 GBS BRZ
Originally Posted by wootwoot View Post
Has anyone tried disconnecting their battery for a few mins? Seems like a good idea to try anyway...
My battery was disconnected for a while multiple times since the modifications. No difference.
Porcupint is offline   Reply With Quote
Old 05-14-2015, 04:33 PM   #86
350matt
Drives: toyota mr2/ Toyota GT86
I can vouch for the effect of resetting the VSC with a lowered car
mine is on KW V3 coilovers and about 30mm lower at the front and 25mm lower at the back and since using a copy of Techstream and an ebay cable to reset the VSC in its new ride height
previously the stability control was a bit keen to kick in once lowered
now its been reset the point of stabilty control intervention is much higher and the car is more pleasent to drive
350matt is offline   Reply With Quote
Old 05-14-2015, 04:39 PM   #87
8R6
8R6's Avatar
Drives: FRS
im on ST coils, lowered about 2" front and rear. -2 deg camber front, -2.7 deg rear. 245/40/17.
before, i was on Hotchkis springs lowered 1" front and rear. -1.5 deg front, -1.7 deg rear. 245/40/17.
both setups had the exact same "limit" of VSC kickin in as when the car was bone stock.
8R6 is offline   Reply With Quote
Old 05-18-2015, 01:31 AM   #88
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
I am not sure if I mentioned this before, but I got my suspension installed, corner balanced and aligned. I ran the car on stock tires and it was awesome. Decided to upgrade to lightweight wheels and MPSS and it was actually the tire/wheel change that, some how, made the VSC way more sensitive. Same suspension and alignment, but as soon as I swapped tires and wheels it started acting up....
I went to the alignment shop today and they had no idea what could be causing it. They said they would put the car on the rack and re check my alignment if I wanted. Still hoping the VSC re set will fix it. Will be doing it over the weekend .
Strange. I ended up with the same problem, but with the opposite sequence of events.
I got my 255/35/18 Direzza ZII's on 18x9.5 +40 wheels with stock suspension, no VSC/TC issues.
As soon as I lowered my car on Tein MonoSport with proper alignment settings, then I experienced VSC/TC issues.
sittinSideways is offline   Reply With Quote
Old 05-18-2015, 11:24 AM   #89
J.Villain
J.Villain's Avatar
Drives: 2015 FR-S
Has any one experiencing this tried putting the stock wheels back on to see if it goes away again?
J.Villain is offline   Reply With Quote
Old 06-23-2015, 03:09 PM   #90
wootwoot
Drives: FRS
Just an update on my end: my tire shop inflated my MPSS to 39psi when they put them on. I dropped the pressure to 34psi and the car feels WAY better. I think I'll drop it to 33 or 32 and call it good.
wootwoot is offline   Reply With Quote
Old 08-05-2015, 11:45 AM   #91
DriftinFRS
Drives: 2014 Scion Frs Whiteout
Any fix for this I am experiencing this also, I am lowered on pbms, I also have drift knuckles and outer and inner tie rods for angle, I believe this is what threw it off. Car has been aligned still kicks in uneccesarily.
DriftinFRS is offline   Reply With Quote
Old 02-16-2017, 07:56 PM   #92
hpde_addict
Drives: '18 Camaro V6 1LE
I'm having the same issue. Tein MonoSport coilovers, -3 front camber, -2.4 rear camber, 0 toe, 4" from ground to bottom of jack rails, 225/45R17 R-S3's. The stability control was going off frequently at Thunderhill East, even when I wasn't pushing the car. After the 5s press, the car felt normal.
hpde_addict is offline   Reply With Quote
Old 11-05-2017, 05:56 PM   #93
brzsubie
Drives: '16 BRZ
Sorry to revive a semi-old thread. Did anyone try using techstream to reset VSC? Looking at the TRD spring install steps it's very clearly outlined as the last step http://www.billswebspace.com/PTR07-18130inst.pdf.
brzsubie is offline   Reply With Quote
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Vehicle Stability Control twostroke BRZ First-Gen (2012+) — General Topics 15 07-13-2014 11:10 AM
Stability Control? ashtray BRZ First-Gen (2012+) — General Topics 27 01-24-2013 05:32 PM
TPMS, LSD and Stability Control FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 11-05-2012 04:12 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
