#85 |
Plugs are supposed to be changed at 75,000 miles if I remember correctly. Save your money and enjoy the trip. $450 will get you a lot of In-N-Out burgers and gasoline and hotels.
| The Following User Says Thank You to White64Goat For This Useful Post: | chanomatik (02-10-2015) |
#86 |
Drives: 2014 Scion FR-S Monogram Series
Practice makes perfect.... I have a guy at work here that'll have both heads off in under an hour. I'm not too worried about the plugs.... not to mention the number of miles I put on the car I wont be doing plugs until 2025 anyway LOL
#87 |
Book time on the plugs.... 3.5 hours. And the procedure is a bit of a bitch outside of the shop environment.
#88 |
60k service at my dealer includes doing the plugs and it's $675. If it needs any replacement coils it's extra for the parts if the car is over 60k so I plan to get it done at ~59 so stuff will still be under warranty. Should be spring '16 or so until I need to worry about it though.
| The Following User Says Thank You to gravitylover For This Useful Post: | chanomatik (02-10-2015) |
#89 |
I Love custom Turbo kits
Drives: Limited BRZ
It can be done without raising the motor up and everything the shop manual states. It just requires patience, but can be done.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | chanomatik (02-10-2015) |
#90 |
Drives: Toyota GT86
You can change the plugs without lifting engine etc.... Couple of race teams here in the UK have drilled strategic holes ( not chssis damaging ) which allows removal with a long extension bar.
| Subaru or Toyota drain plug? | yayforaddison | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 05-06-2020 11:59 PM |
| Exhaust tip removal | Draco-REX | Cosmetic Modification (Interior/Exterior/Lighting) | 97 | 05-27-2017 06:50 PM |
| Scratch Removal? | feldy | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 05-15-2014 11:12 PM |
| Spark plug type and heat | ft86-UAE | Engine, Exhaust, Transmission | 4 | 06-10-2012 11:21 AM |
| What do you wish was changed about the brz/frs? | GirlyScions | BRZ First-Gen (2012+) — General Topics | 16 | 06-04-2012 04:26 AM |
