Old 03-24-2015, 10:47 AM   #85
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by bfrank1972 View Post
I'm surprised you say the brz shifter is rubbery, mine has a nice mechanical feel to it. Similar to the s2000, but not quite as nice (but close enough). Was the brz new or broken in? Mine transmission took several thousand miles to break in, once it did it felt much much better. Clutch does take some getting used to. Get the brz engine tuned and it will be even more responsive. Get some stick tires and performance alignment and you'll be surprised how the thing goes around corners.
Brand new. I can definitely get used to it but after all the rave reviews I read I was hoping it'd be a little better. I'd probably buy a slightly taller shift knob.
List of mods planned (irresponsibility ftw, planning to blow money I don't have before I even blow money on the car!) is looking something like (in order of priority):
0. 3M crystalline film
1. Tune, no brainer.
2. Aftermarket axleback.
3. EarthX battery, catch can, Forester oil cooler
4. Camber plates (because fiddling is fun)
5. Front brakes, maybe pulleys (alleviates some of the front weight bias to the tune of $30 a pound, hopefully stainless steel lines will fix the spongy pedal)
6. Lighter rims for when the tires go
I'd have to get used to the car before deciding if I want a lighter flywheel, but I think I probably will for the high rpm response. This list is what, 4 grand ish? Not too bad, hopefully it makes the car reasonably lively.
Old 03-24-2015, 11:36 AM   #86
DarkSunrise
DarkSunrise's Avatar
I know what you mean about the shifter feeling rubbery. If your expectation is Honda shift quality (e.g., S2000 or RSX), you will be disappointed.
It's definitely not bad and gets better over time, but a step below the best IMO.
2022 BRZ Build
2013 FR-S Build
Old 03-24-2015, 12:12 PM   #87
bfrank1972
Drives: 2013 FR-S Argento
It could very well be the stock knob - I swapped to a billet steel knob. Other than cold in the winter/hot in the summer it communicates to your hand much better. Even new I wouldn't call my shifter rubbery at all, more like stiff to the point where it didn't just 'slide and click' into gear very smoothly at first. Now it's great, but I've also learned that shifter feel is a personal (maybe religious?) preference thing. I liked the shifter in my E36 M3 too, very slick and 'buttery', but a lot of people would say it wasn't 'positive' enough (definitely different than my FR-S).
bfrank1972 is offline   Reply With Quote
Car Died in front of Work Tt3Sheppard Issues | Warranty | Recalls / TSB 45 01-30-2018 06:48 AM
Car died/semi-revived need help InvalidJohnny5 Issues | Warranty | Recalls / TSB 13 12-16-2014 03:08 AM
Died out at light Legacy Issues | Warranty | Recalls / TSB 12 05-29-2013 12:27 AM
I just died inside. DIG1992 BRZ Photos, Videos, Wallpapers, Gallery Forum 62 07-02-2012 08:51 PM
My DD died today any suggestions? LeavingNormal Other Vehicles & General Automotive Discussions 14 05-27-2012 09:18 PM
