#85 |
Hotlink Terrorist
Drives: 2015 WRB BRZ Spec S
You mean the people that stick the engine so far out the back of the car it looks like a hemorrhoid and steers itself as the anchor swings the tail like a skank on ladies night? Understeer that turns into violent snap oversteer, yeah; give me some of that! I really don't care about their philosophy of car design.
#86 | |
Because compromise ®
Drives: Red Herring
Sure, I appreciate that but it would seem that some people do like it.
#87 |
Hotlink Terrorist
So's the 944 Mr. U-boat commander.
![]() ![]() And, I must say, the 944 must appeal to me since I love the FC and Mazda admits they totally ripped off the look of that Porsche. GM put a flat four in the back of a car once. And? |
#88 |
Drives: Red Herring
The 928 has rear steer, I do not know about the 944.
#89 |
Calm down. My car is aligned. The way the car is designed, it will toe the outside wheel out and the inside wheel in when it leans over. It doesn't mean you can parallel park the car sideways. I'm only mentioning it because I'm not used to my car leaning in the corners. I'm changing to the stiffer FR-S springs this weekend anyway.
#90 |
AutoX-10/10ths every run
[ame]http://youtu.be/CMNry4PE93Y[/ame]
| The Following 2 Users Say Thank You to whataboutbob For This Useful Post: | JB86'd (12-17-2014), themadscientist (12-16-2014) |
#91 | |
Hotlink Terrorist
You described what my GT-R used to do at low speeds I mixed up my acronyms earlier. Atessa is the AWD gear, Hicas is what I meant to say. At high speeds, Hicas turns the rear wheels WITH the front wheels, not against. Most people install a locked rack to eliminate the rear steer altogether which is what my car has. You are building a suicide machine.
#92 | |
#93 |
Drives: 2014 Pearl White BRZ
My BRZ has a reactive organic steering and control compensation device. It's called the driver.
#94 |
not playing cards
#95 | |
not playing cards
#96 | |
Drives: 370z
#97 | |
Drives: 370z
So the brz with less spring rates has less weight shift on the rear and will be more neutral understeer... |
#98 | |
Drives: Supra, 2014 BRZ
| Well this sucks. | Dave-ROR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 11-16-2014 10:18 PM |
| Getting OLD kinda sucks... | blackhawkdown | Off-Topic Lounge [WARNING: NO POLITICS] | 44 | 06-13-2014 10:41 AM |
| Elitism..sucks | RedLeader | Other Vehicles & General Automotive Discussions | 60 | 01-29-2014 04:09 PM |
| NY sucks | Hardrock4445 | Off-Topic Lounge [WARNING: NO POLITICS] | 35 | 01-18-2013 09:28 AM |
