Old 02-05-2016, 10:48 AM   #85
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Heading back out to Junkyard today to see what other connectors I can find. My phone decided to die with 50% battery left when I tried to open my Spreadsheet. So I only had the info I remembered, which was the Servo Plugs. Which can be found on 98-02 Accord, 98-02 Odyssey, 01-03 Civic. I grabbed a few sets just in case. The plug for the Blower transistor can be found on the Accords and Odyssey as well.
I grabbed a picture of all the plugs I could find on Google Images. I will incorporate them into the File. I hope to Find more of the plugs with the help of the pictures.
90980-12155:
90980-12155 by Dustin[Smith], on Flickr
90980-12155-2 by Dustin[Smith], on Flickr
90980-12554:
90980-12554 by Dustin[Smith], on Flickr
90980-12248:
90980-12248 by Dustin[Smith], on Flickr
90980-12248-2 by Dustin[Smith], on Flickr
IL-AG5-7P-S3C1:
IL-AG5-7P-S3C1 by Dustin[Smith], on Flickr
90980-11918:
90980-11918 by Dustin[Smith], on Flickr
90980-11909:
90980-11909 by Dustin[Smith], on Flickr
90980-11135: (Only Picture I could find)
90980-11135-diagram by Dustin[Smith], on Flickr
90980-10796:
90980-10796-2 by Dustin[Smith], on Flickr
90980-10796 by Dustin[Smith], on Flickr
*Not my hand^^ But looks like it is in the floor board, so Should help with locating it.
DustinS is offline   Reply With Quote
Old 02-05-2016, 10:51 AM   #86
brentjones518
brentjones518's Avatar
Drives: 2013 White brz Limited.
I just went through the hole process. Costed me about 1000. Not really worth all the time and trouble honestly. I'm a mechanic for living. I actually got a Brz dash harnless and just de pinned what I needed and pinned it into mine. Worked great. Probably only had to cut 5 wires. Did have to swap heater core. May be able to use old one but I didn't want to risk it
brentjones518 is offline   Reply With Quote
Old 02-05-2016, 11:34 AM   #87
DustinS
DustinS's Avatar
You don't need to swap the top of the HVAC box unless you want the full Dual Climate swap, if you don't mind having single temp, you can leave the manual control one alone.
It's also doable for a decent amount cheaper with looking around. I am $150 in and have most of the expensive parts. I will have $250 into the physical parts needed if I buy the rest of the parts from the dealer. (Driver side servo(only need this because of the stupid metal bracket required), Temp Sensor, Hose For Temp Sensor.). Another ~$50 in connectors (Depending on what I find at the Junkyard tonight). $10 in wiring.
I look at it as a fun challenge.
Edit: Contacted the Original Designer (Rudy). He accepted my Facebook Message, but doesn't seem he ever looked at it, definitely hasn't replied yet. I don't think he is interested in this anymore.
Old 02-05-2016, 07:04 PM   #88
supercharged2
Drives: 2013 FRS
DustinS,
I finished my harness back in October. If you need pics or help, just let me know. I haven't installed it yet because I don't have the time. I would highly suggest getting the dash harness. It will save you lots of headaches!
supercharged2 is offline   Reply With Quote
Old 02-05-2016, 07:09 PM   #89
DustinS
DustinS's Avatar
Originally Posted by supercharged2 View Post
DustinS,
I am only finding the Dash Harness for $250 which Doesn't Make it worth it for me. Thank You though!
EDIT: Found the IL-AG5-7P-S3C1 plug:
Untitled by Dustin[Smith], on Flickr
It's the Ignition Ring from the 98-02 Odyssey. It turns the pins 90 degrees, but it will work.
Old 02-06-2016, 10:22 AM   #90
Chaetagnath
Drives: Whiteout FRS
Originally Posted by DustinS View Post
When You Bought the Top Servo in the picture. Did it come with the metal bracket to attach it?
I bought the entire Auto A/C which came with the bracket and servos, then swapped them onto my manual A/C. As far as I can tell, the bracket comes with the servo normally.
Awesome progress so far sourcing parts!
Chaetagnath is offline   Reply With Quote
Old 02-06-2016, 12:16 PM   #91
DustinS
DustinS's Avatar
Found some Lexus Connector lists. They seem to come from the Wiring Service Manual. I could only find them for the RX-300 an RX-330. I could probably find others if I did better searching, but of well. I found some of the connectors needed in the RX-300. Going to run by the junkyard and see if I can grab them.
90980-11918 Is found on A/C Room Temp Sensor and the A/C Solar Sensor, hopefully they are easy to get to.
90980-10976 is Junction Connector J5. I am assuming this is on the drivers side/passenger side A Pillar at the floor. Hopefully.
90980-11909 is on the Wireless Door Control Sensor (Not actually sure what this is, Window Regulator?)
Old 02-06-2016, 12:44 PM   #92
Chaetagnath
@Chaetagnath Do you remember/know what size wiring he used? I have an idea, but can't hurt to ask.
I think most of the wire was 18 gauge, but I am not sure.
I have run into a slight bump as I cannot for the life of me find the type of relay block he used. I know I have seen them for sale in that type, but I have exhausted my searches (spent the last hour looking for that connector alone). So I will have to make do with what is available.
Do you mean the relay connector? I think it is a Hella relay socket.
Not sure if these are the right size, but try this website:
http://www.partdeal.com/hella-relay-...h84989031.html part H84989031
That one comes with female and male sides, you can probably modify it to fit.
Or
http://terminalsupplyco.com/Store/De...x?CAT=EC070030 Part number HE-87122B Terminals HE-87279 I don't know exactly where to get the pins, but you could probably pirate them from another relay.
Old 02-07-2016, 02:02 AM   #93
DustinS
DustinS's Avatar
Found the HVAC housing parts are only $25 a piece. Do you know which one I would need to order to do true Dual HVAC?
8615065 by Dustin[Smith], on Flickr
Guess I need to find the part number for passenger side servo as well.
Old 02-08-2016, 03:16 PM   #94
DustinS
DustinS's Avatar
@Chaetagnath Do you have your Manual Box By any Chance?
Looks like the Part I need to be able to fit the Passenger Servo is 72120B
My question is if the internals are the same, or if They are different enough That I need to order more of the parts. If you still had it (or if anyone has a manual/Auto they could compare) and see if the parts look somewhat the same as the diagram Below.
Edit: The Top Picture is from Subaru, the Bottom Scion. The bottom half of the Scion diagram Corresponds to the Subaru One. Going to see what I need to order.
Edit: Part # 72145*B on the Subaru Diagram and #16 on Scion Diagram are different between Auto/Manual.
So Subaru Lists two part numbers for the Left Side Heater Shaft. One is for Auto Climate, One is for Manual, yet they don't list which one goes with which. I found a listing for both on Ebay, If they are correct: 72145CA020 is for the Auto Climate Control. So from what I can find: The left Side Case is needed as the servo won't bolt on to the manual case. The right side of the case has a different part number, but the servos bolt up (so who knows exactly there). The Right Side Heater Shaft is also different, and everything else seems to have the same part number between them. So Manual owners should only need The left Side of the casing, and Heater Shaft to do a true Dual Climate, without buying the entire casing. Which in all honesty would be so much easier.
Old 02-08-2016, 08:29 PM   #95
Chaetagnath
I am pretty sure it is the other side you need (72120A, or the part labeled "2" in the other diagram. Plus, you likely need some minor internal parts (#16 and # 13 maybe) My manual A/C is still in the car (only did single temp), but I have the auto A/C still, I will post some photos later.
Old 02-08-2016, 09:46 PM   #96
DustinS
DustinS's Avatar
This is the diagram that makes me think I need #3. I Hope so, cause I already bought it haha. I also bought the #16 that comes with Auto Climate Cars.
Old 02-08-2016, 09:55 PM   #97
Chaetagnath
The front of the car is on the other side of the unit. So, if you are sitting in your car, and the A/C is sitting in front of you you need the piece on the right hand side for true dual. 72143B*B is passenger side servo, sits sort of in the middle of the whole unit. Driver side is far left. You need 72120A.
Old 02-08-2016, 10:00 PM   #98
DustinS
DustinS's Avatar
Well That Sucks. Guess I will see if they can change my order haha. Thanks For the Info!!
Got my Panel and Resistor in the mail. I had to open the panel to diagnose a stuck button. I couldn't see any reason why it was stuck, but cleaned everything and it seems to have fixed it. While I was in there I swapped the LEDs to blue (White for the On Indicators).
Resistor Part Number for anyone Interested:
Wtb:pnp harness for automatic climate control for frs Sangthing Want-To-Buy Requests 5 01-02-2015 04:11 PM
BRZ limited dual climate control Sangthing Interior Parts (Incl. Lighting) 6 09-12-2014 06:01 AM
Ac knobs for BRZ limited / FRS with dual climate dnizzle Cosmetic Modification (Interior/Exterior/Lighting) 3 08-15-2014 10:43 PM
FS - BRZ Dual Climate Control Unit dvsidboy Audio/Visual, Electronics, Infotainment, NAV 4 01-12-2014 08:52 PM
