Old 09-06-2014, 05:46 PM   #85
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by Yui-Chan View Post
I wouldn't go as far to say the Cayman is more reliable. Not even close. It depends what year too. I've heard of Cayman engines blowing up, spinning rods and messing up their sleeves and faulty loose piston rings (from only mild track driving and even on the street), 1000x more than a BRZ/FRS has lol.
The only Cayman S you can buy for around $30-40k would be an old, high mileage, '06-'08 model...which are the most problematic and very prone to major engine failures at the track due to oil starvation (lack of oil pump power and lateral load makes the oil stuck in the heads) and spun rods, di and rear/front seal problems, engine sucking up and burning oil from intake, and so on.
'09-'13 have resolved most of these issues, but these will run at least $45k to $60k used. The early '09 still had problems iirc.
'14...forget about it lol. Pretty much the same price as a 911.
Yes, I heard some oil starvation issues too but I am not sure if those are pretty common, on internet people tend to make the things big deal too
Also, I am not sure where you find those prices for used Cayman S but quick search on Autotrader gave me these
http://goo.gl/vgNqVY
http://goo.gl/GnQ5g3
glamcem is offline
Old 09-06-2014, 05:52 PM   #86
Yui-Chan
Drives: Toyota
I used the official Porsche website's locator, set to no particular zipcode, and got the prices for the whole country.
Yes, the ones on local CL are much cheaper though.
Yui-Chan is offline
Old 09-06-2014, 05:55 PM   #87
Yui-Chan
Drives: Toyota
So...since the S clearly destroys a JR/SC 86 by a huge margin, what about the base non-S Cayman? haha.
The base Caymans can be had for much much cheaper...older models in the low $20k range (pretty much the same price as a used low mileage 86) and the 1.5gen can be had in the $30k range.
Yui-Chan is offline
Old 09-06-2014, 06:06 PM   #88
glamcem
glamcem's Avatar
I have to say though, that track was the only place I've seen the Cayman has the advantage.. since it's a really long straightaway I have no problem passing Caymans and/or 911s (even some GT3s) at the other tracks where a lightweight car can shine
glamcem is offline
The Following User Says Thank You to glamcem For This Useful Post:
Yui-Chan (09-06-2014)
Old 09-06-2014, 06:20 PM   #89
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
'14...forget about it lol. Those are $65-75k+ used.
Stories of Porsche engine failures are GREATLY exaggerated by the Internet.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline
The Following 2 Users Say Thank You to zdr93523 For This Useful Post:
glamcem (09-06-2014), Yui-Chan (09-06-2014)
Old 09-06-2014, 06:22 PM   #90
Yui-Chan
Drives: Toyota
Originally Posted by zdr93523 View Post
Cayman S $35-$50K is barely > JR BRZ (280whp) $42K w/mods is barely > NA BRZ (200whp) $34K w/mods
That's a good way to look at it when comparing a stock Cayman to a modified SC'ed 86...the total cost.
Imo, the bare minimum and essentials (brakes, susp, power, tires) needed to make a JR 86 comparable (or at least a tad closer lol) to a Cayman would be just an extra $12k ....$20k for a used 86 and an additional $12k for mods = $32k ...which is far from your $42k estimate.
So I think it would be more fair to compare, or shop, for a Cayman around that $32k price... if you wanted to get, or were considering getting, a Cayman instead of a JR 86.
JR86 essential and cheapest mods to go up against a Cayman:
JRSC (Cayman power) = $5k
Oil cooler = $700
Wheels & tires (Cayman grip) = RPF1 & RS3 or ZII = $1.8k
AP Racing Sprint (closer to Cayman brakes) = $2k
Coilovers (closer to Cayman suspension) = $2.5k
Total = $12k
Yui-Chan is offline
The Following 4 Users Say Thank You to Yui-Chan For This Useful Post:
*LongFella (09-07-2014), glamcem (09-06-2014), yellowfrs (09-08-2014), zdr93523 (09-06-2014)
Old 09-06-2014, 08:10 PM   #91
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Oil cooler = $700
Total = $12k
That is about what I would suggest to compete against a Cayman S (with one of the available CARB supercharger options out there). Though the one benefit you can do is run FlexFuel/E85 and pick up an additional 30-50 horsepower (over 91 octane) depending on the Supercharger and boost you are running.
Cheers,
William Knose
DeliciousTuning is offline
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Old 09-06-2014, 08:21 PM   #92
zdr93523
zdr93523's Avatar
Oil cooler = $700
Total = $12k
I was adding 12k to a new BRZ. Either way... Just buy a Cayman S and GT3 control arms ($2k) and you'll destroy the BRZ.
www.makesmodels.com
www.camautomag.com
zdr93523 is offline
The Following User Says Thank You to zdr93523 For This Useful Post:
Yui-Chan (09-07-2014)
Old 09-06-2014, 09:22 PM   #93
glamcem
glamcem's Avatar
Oil cooler = $700
Total = $12k
I was actually in your shoes before I purchased my BRZ back in March, I actually knew all the parts that I needed in order to compete with a Cayman S, so I ordered all the parts within the same week of my purchase I installed my Kraftwerks kit when I had about 800 miles on the clock .. since the logic tells me 275-280 whp coupe that weighs about 2700 lbs should be able to keep up with a Cayman S since they have similar power Cayman being heavier (about 300-400 lbs more) but in real life things are a bit different.. NA power and delivery is quite different and parasitic loss in inevitable so I am pretty sure I am not making the power consistently like a Cayman or similar NA engine, even with the best SC option (I mean Rotrex kits in general) which feels like a high revving 6 cylinder engine..
with that said, BRZ even with the FI is still a bargain compared to a new Cayman ( I think to be fair we have to compare apples to the apples)
glamcem is offline
Old 09-06-2014, 09:41 PM   #94
zdr93523
zdr93523's Avatar
Agree with all.
We had a 2012 stage 2+++ WRX hatch that was seriously fast and the BRZ. We were going to sell the BRZ when I bought the Cayman but kept the BRZ because we like it so much and sold the WRX instead. They both make me smile and they're both fun and different to drive.
www.makesmodels.com
www.camautomag.com
zdr93523 is offline
Old 09-06-2014, 09:47 PM   #95
juliog
juliog's Avatar
Drives: 86
You'd need to spend way more than $2.5k in suspension parts to get close to a Cayman S in terms of performance, not to mention ride quality..
juliog is offline
Old 09-07-2014, 10:51 PM   #96
zdr93523
zdr93523's Avatar
This is true and you'll never touch it in ride quality if the Cayman has PASM.
www.makesmodels.com
www.camautomag.com
zdr93523 is offline
Old 09-07-2014, 11:22 PM   #97
I beg to differ... far more of them are handled quietly and without internet fuss than you think.
CSG Mike is offline
Old 09-07-2014, 11:25 PM   #98
Oil cooler = $700
Total = $12k
I think what you really need is a demonstration of what the car is actually capable of.
Come to the next 86CUP event, and I'll personally cover your entry fee. It's August 20th at Auto Club Speedway.
CSG Mike is offline
juliog (09-08-2014), Yui-Chan (09-08-2014)
ModBargains.com | Vortech Supercharger System for FRS/BRZ - 50-State CARB LEGAL!! ModBargains.com Forced Induction 59 01-20-2017 01:22 PM
CARB legal headers? mike_ekim1024 Engine, Exhaust, Transmission 23 05-31-2016 12:14 AM
Any CARB legal turbos on the way yet? Black Knight Forced Induction 3 07-15-2014 07:16 PM
CARB Legal Innovate Motorsports Supercharger Systems now available! Innovate Motorsports Forced Induction 33 12-27-2013 02:39 PM
Carb legal intakes EN2_Squirrel Engine, Exhaust, Transmission 2 04-18-2013 05:59 PM
