Old 09-29-2017, 12:30 AM   #85
frscory
frscory's Avatar
Drives: 2013 scion frs firestorm red
Can anyone tell me where to find this line on a left hand drive car? The picture shows it under the brake booster but I cant find it or anything that looks similar to it. thanks
frscory is offline   Reply With Quote
Old 10-12-2017, 02:56 AM   #86
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Are you talking about the L shape line? Or which line? Should be sound generator tube
Decimus is offline   Reply With Quote
Old 10-15-2017, 12:48 PM   #87
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Did everyone change out their MAP sensor after installing this kit? 3 bar?
Old 10-15-2017, 03:03 PM   #88
Only if you're tuned for it and/or are going to swap it on the dyno, or immediately before/after flashing your tune.
Old 11-14-2017, 12:55 PM   #89
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
So aftermarket MAP sensor is not needed for this t518z application unless we're trying to go over 14.7psi of boost? If we want a tune for hi&low boost, is that when we need an aftermarket MAP? Stock MAP is a 2bar (or some say 1.6bar)?
Old 11-14-2017, 01:13 PM   #90
stock is 1.3bar.
It depends on how your setup is tuned.
Old 11-14-2017, 10:29 PM   #91
Lust
Drives: 2017 Subaru BRZ
I've been considering getting this kit recently. Anyone able to chime in on how it compares to other top turbo/SC solutions available like JDL, Full Race, Edelbrock, JR, etc?
Lust is offline   Reply With Quote
Old 11-15-2017, 01:28 AM   #92
BRX
BRX's Avatar
Drives: Toyota GT86
If you're not planning to go more than 300whp, this is the perfect kit for you. My only complaint about this kit is the turbo stops making power up top even at 14 psi.
If you want room for more power later get the T620z for about +400whp with E85.
If you want an all around kit and the potential to go all the way to 500hp later, this is not a kit for you. I'd go with JDL and a GTX3076R.
Sent from my Pixel XL using Tapatalk
BRX is offline   Reply With Quote
The Following User Says Thank You to BRX For This Useful Post:
Lust (11-15-2017)
Old 11-15-2017, 09:15 AM   #93
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Exactly what BRX said. I ran the T620z on 10lbs of boost for a good 18k miles on a stock engine with no issues (293 WHP automatic trans). I decided to turn up the boost to 18lbs since I'm on a built block now.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 11-17-2017, 02:03 AM   #94
Lust
How’s the response on it? Do you know how it would compare to the 518?
Old 03-03-2018, 04:05 PM   #95
Raven86Project
JDM Spirit of the '90s
Raven86Project's Avatar
Drives: 2015 FR-S Turbo
For those of you who paid to get this kit installed, how much was it? I was quoted $2500. Does it make sense to you? Thanks!
IG: raven86project
Build Thread HERE
Raven86Project is offline   Reply With Quote
Old 03-04-2018, 02:04 AM   #96
BRX
BRX's Avatar
Drives: Toyota GT86
I got it installed for about $800. $2500 is asking way too much even if it includes a tune.
Sent from my Pixel 2 XL using Tapatalk
Raven86Project (03-04-2018)
Old 03-04-2018, 02:42 AM   #97
Lust
I was quoted 1k but I had a few other things other than just the T518z kit.
The Following User Says Thank You to Lust For This Useful Post:
Old 03-08-2018, 10:41 AM   #98
djezlee
Drives: 2017 BRZ Limited
How do you guys like this kit when considering the heat it brings? I want to buy this ASAP, but I will have big time buyers remorse if it cant support my commutes. I drive on the German Autobahn (avg 95-120 mph for 2 hours at a time/ 4 times a month). I already had oil temp problems on a stock engine in the winter. So I just purchased the JR dual radiator/oil cooler. Do you guys think I will have heat problems with this kit?
djezlee is offline   Reply With Quote
Greddy / Trust Turbo Kit (Video and Pictures) BPAuto Forced Induction 62 03-18-2016 06:04 AM
BRZ GReddy t518z NOTORIOUS.BRZ BRZ Photos, Videos, Wallpapers, Gallery Forum 26 04-15-2014 02:15 PM
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) NOTORIOUS.BRZ Engine, Exhaust, Transmission 21 09-24-2013 06:09 PM
GReddy Tuner T518Z Turbo Kit Fitted / Photos/ DYNO/ Video ! NOTORIOUS.BRZ Forced Induction 17 07-29-2013 04:42 PM
