#85 |
Drives: WRB BRZ
When i purchased my BRZ it cams with nameless overpipe and axleback. I switched back to the stock muffler simply because it was too loud and I now feel the torque dip.
Can i safely assume that I will still be running the E85 stock brz tune? The overpipe is the only engine related mod that I have. If I choose to drop in a filter, will that still allow me to run the stock E85 map or will that put me to the STG 2 map? |
#86 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
#87 |
Drives: GT86
Stage 1 E85 map doesn't even exist. Stage 2 E85 also works on a stock car, unlike a stage2 gasoline there is no risk for knock on E85 and it will dial back automatically for the amount of oxygen that flows through the complete system (=AFR).
#88 |
Drives: FR-S 10 #103 AT
I bit the bullet and went home the long way today so I could fill up with E85. I was on fumes when I pulled into the station. With the windows up, I started smelling something different within a couple of miles.
I haven't had the chance to get spirited with it yet, but my cruising trims look excellent. I am worried about the smell though. Do I have an exhaust leak coming into the cabin?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#89 | |
Drives: 2013 BRZ Limited WRB
So I filled with E85 did all the stopped, loved it and filled again with a big grin on my face.
But now with the temperature getting colder here, I'm having troubles starting the car, since it takes as much as 8 cranks.... Anything that can be edited inthe tables to I dunno send more fuel or increase ignition ? Thanks
#90 | |
Drives: GT86
#91 |
This morning it was mid fifties. First time with E85 and the first time I needed to crank it twice. Not an auspicious sign for cold weather usage.
#92 |
Drives: 2013 Asphalt 6spd
It's less noticeable if you park in the sun. I park under a car cover, and leave for work at 1pm, even if it is ~80 out when I go to leave, if it dropped down to ~60 the night before I have to crank multiple times. Just tried 1 gallon of 93 yesterday, it started up better this morning. But either the ecu is learning the new blend, or I forgot how rough the engine feels when not running 100% E85.
#93 | |
#94 | |
My Other Ride's a Jeep
[ame="https://www.youtube.com/watch?v=mws6n7lW-8U"]Another cold start. Actual temp: 17° - YouTube[/ame] The actual temp on this was 17. Let me see if I can find some of my old tables. |
#95 | |
Filmed my cold start this morning (I know, I know, the real problem here is vertical filming). It actually wasn't that bad this morning, but listen a 00:26 and tell me how good that sounds **cries**
filmed my cold start this morning (I know, I know, the real problem here is vertical filming). It actually wasn't that bad this morning, but listen a 00:26 and tell me how good that sounds **cries** it was 51 degrees here which is considered still pretty hot .. [ame]http://youtu.be/qLLwu371iqc[/ame]
#96 | |
#97 | |
#98 |
Drives: BR86
Sounds like a mini backfire which I too have experienced in real cold temps with E85 only in tank. Mix to make E70 in those temps & you will be fine & dandy
| Stock FR-S Tune Just Done | Zach3794 | Engine, Exhaust, Transmission | 67 | 11-05-2017 02:01 PM |
| stock BR-Z, much detonation during shifts: tune? | elefunkd | Engine, Exhaust, Transmission | 69 | 07-26-2013 04:20 PM |
| Anyone have a stock tune from Visconti? | Bleevin | CANADA | 3 | 07-03-2013 01:01 AM |
| My Initial (all stock) BRZedit tune | mad_sb | Engine, Exhaust, Transmission | 6 | 02-16-2013 12:20 PM |
| Save stock tune with ecutek? | gdrider77 | Engine, Exhaust, Transmission | 7 | 01-06-2013 12:50 AM |
