#85 |
Famous Potatoes
Drives: '15 ultramarine
| The Following User Says Thank You to Sapphireho For This Useful Post: | gravitylover (02-10-2019) |
#86 |
not playing cards
#87 |
Famous Potatoes
| The Following User Says Thank You to Sapphireho For This Useful Post: | Ultramaroon (02-10-2019) |
#88 |
You feel pretty comfortable crawling around under there? You're convincing me...
#89 | |
not playing cards
| The Following User Says Thank You to Ultramaroon For This Useful Post: | gravitylover (02-11-2019) |
#90 |
Famous Potatoes
Better pic.
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | gravitylover (02-11-2019), Ultramaroon (02-10-2019) |
#91 | |
Dismember
Drives: 2013 Red Scion FR-S
That quick jack thingy is better than actual jacks, yes, but I'd have to get one version for the truck and another version for the cars. The truck has a 149" wheelbase and the FRS has 101". Plus what if I eventually get a 2500 or 3500 truck? That crew cab with the diesel is over 7000lbs and a dualie can go over 8000 if I option it up.
#92 | |
Famous Potatoes
Their biggest one has 7000 lb. capacity. Mine is 5000, which is plenty for everything I own. |
#93 |
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (02-11-2019) |
#94 | |
Famous Potatoes
Still trying to figure out where the jack points are? |
| The Following User Says Thank You to Sapphireho For This Useful Post: | Ultramaroon (02-15-2019) |
#95 |
My concern with the QuickJack has always been the inability to slide under the side of the car. So say you want to unbolt the exhaust at the mid section of the car. You would have to craw unter from the front or rear. Then again it looks like it's high enough that you could quickly roll under there with a creeper.
| The Following User Says Thank You to ermax For This Useful Post: | Tcoat (02-11-2019) |
#96 | |
#97 | |
Famous Potatoes
Plenty high enough, and solid as a rock. I always put a couple jack stands here and there in case of catastrophic failure, which is super unlikely. here is a video where they lifted over 20,000 lbs with the 5000 lb unit. [ame]https://www.youtube.com/watch?v=YVZ-CcF0_MY[/ame] |
| The Following User Says Thank You to Sapphireho For This Useful Post: | EAGLE5 (02-11-2019) |
#98 |
Dismember
Your rock hard abs?
| The Following User Says Thank You to EAGLE5 For This Useful Post: | Ultramaroon (02-11-2019) |
