Old 06-10-2014, 03:06 PM   #85
Fear
Drives: Ft86
So you're gonna run an fb25 crank for more displacement and 90mm bore to match the 90mm stroke. Custom (probably higher comp) pistons..
What rods are you going to use? Fa20's have larger rod bearing journals than fb25(correct me if im wrong) so would you have a hybrid custom rod, basicly an fa20 rod with fb25 rod bearings?
This would basicly be an hks stroker kit...
Fear is offline   Reply With Quote
Old 06-10-2014, 03:16 PM   #86
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
I'm way interested in the water pump! More info on that?
jebuwh is offline   Reply With Quote
Old 06-10-2014, 03:55 PM   #87
w00t692
Drives: 2008 Civic Si
The gains i've seen from electric water pumps aren't even remotely worth the hassle. Not even 5 whp. Granted it's on a k20, but still.
w00t692 is offline   Reply With Quote
Old 06-10-2014, 04:08 PM   #88
protpibe
protpibe's Avatar
Originally Posted by celek View Post
Here is a HUGE announcement for the project.
I have been working on this for a LONG time. Lots of R&D. Specifically made for the 86 Chassis. Bolt on plug in play.
Did you make this yourself? Or what shop made it?
Old 06-10-2014, 04:13 PM   #89
arghx7
Drives: car
Is the electric water pump going to be running at full speed all the time? From the perspective of power output improvement, to get maximum parasitic loss reduction you really need to tune the pump flow rate. That's a pretty involved process depending on how precise you want to get. The simplest way to do it is to turn the pump speed down on the dyno and see if you even pick up any power.
Otherwise you now have this aftermarket waterpump that you better hope doesn't fail, or your gazillion dollar long haul build will be in jeopardy. It's a pretty risky move.
arghx7 is offline   Reply With Quote
Old 06-10-2014, 04:16 PM   #90
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
water pump should pick up 5-10hp. on LS1's it seems to be about that much and thats only turning 6500rpm. you can run a pump controller to slow it down in traffic and during street driving. one issue we ran into was it moving too much coolant while stuck in traffic or on the highway and causing the car to run cold.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 06-10-2014, 04:47 PM   #91
arghx7
Drives: car
The simplest way to run it is full on all the time (or at least when the engine is firing). If you have a controller maybe turn it down for WOT in an attempt to maximize parasitic loss reduction for better output. The problem then is you can overcool as mentioned above.
If you look at how electric and other types of controllable waterpumps are run on vehicles that come with them from the factory (BMWs for example), you'll see flow rate varying with speed and load and also turning off during a cold start. They can work with the thermostat to control water temperature and also the temperature rise across the engine by varying flow rate.
Old 06-10-2014, 09:33 PM   #92
Turdinator
Señor Member
Turdinator's Avatar
Davies Craig sells a EWP controller but it looks as though most of its control algorithms are based around warm up and once the car is up to temp it is on full the whole time.
http://www.daviescraig.com.au/Electr...0-details.aspx
1974 TA22 Celica
2013 86 GT
Old 06-11-2014, 09:50 AM   #93
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i know how these na civics are. i have a turbo gsr, 45k on it, Just sits around now but going boost really killed the car personality. not to mention its way too fast lol i want to keep the frs na but i seriously need to stop losing to s2ks
IG-Joey_Soul
Old 06-13-2014, 09:45 PM   #94
celek
Resident Gear Head
celek's Avatar
HP is not always the only reason
Cavitation:
Formation of vapour bubbles within a liquid at low-pressure regions that occur in places where the liquid has been accelerated to high velocities, as in the operation of centrifugal pumps, water turbines, and marine propellers.
I plan on exceeding 9000 RPM
celek is offline   Reply With Quote
Old 06-13-2014, 09:47 PM   #95
celek
Resident Gear Head
celek's Avatar
Small problem there trying to work a pump at slower speed/votlage against fluid is not going to work.
I ran this same pump on my Civic for 5 years not a problem
Old 06-13-2014, 09:49 PM   #96
celek
Resident Gear Head
celek's Avatar
Pump should be good for 90k miles rated on advertised hour expectancy
Old 06-13-2014, 09:50 PM   #97
celek
Resident Gear Head
celek's Avatar
I built it the harness and designed the bracket/blockoff plate and pump location.
Old 06-13-2014, 09:51 PM   #98
celek
Resident Gear Head
celek's Avatar
Custom rods and custom pistons to retain a good rod to stroke ratio. (Which the HKS kit can not do and that's probably a $4500 kit
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
