#85 |
Pegasus White
Drives: 86
How do I achieve this!?
Driving: Pegasus White Manual GTS 86.
#86 |
Subaru Certified Sales
Drives: '13 BRZ Premium, '05 WRX STi
Properly configured setup. Know your goal and build toward it. Ask an expert if you don't know how to reach your destination for assistance.
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85 [Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s [Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans "The only thing that I trust in this world is cars!" - Don 'The Goods' Ready |
#87 |
Junior
Drives: a car
Know your goal...like its going to stay in one place
lol
| The Following User Says Thank You to cdrazic93 For This Useful Post: | mrk1 (02-19-2014) |
#88 |
Maybe goal can be swapped for expectations?
| The Following User Says Thank You to Boss Paco For This Useful Post: | cdrazic93 (02-18-2014) |
#89 | |
Drives: DGM BRZ Limited
Likewise, the T30 wheel used in the GT30 is well suited for the gtx67r compressor, or even the GTX3071r compressor. But the turbine is overwhelmed by the flow of the 76mm compressor in standard 6 blade or the 11 blade form. The turbine is simply too small imho, and you'd be better suited to the T350 turbine for the 76mm wheel. The GTX3576r is a great turbo, with near perfect balance. Managing the backpressure on these setups will help keep temps down, and the NA profile of cams will like the free-flowing exhaust wheels. It's my expectation and opinion that the GTX3576 with a .82 exhaust housing will be an absolute riot to drive and perform excellently. 600whp potential with great response. If you are looking for the absolutely most responsive turbo for 300-330whp, I would probably suggest the disco potato. I haven't tried the GTX2860rs or the GTX2863r personally, but have seen some miatas with these fitted making ridiculous power for low boost and just nasty responsive. |
#90 |
NASA SpecE30 Racer
Well the GT2871R in my Full Blown base kit got me a flat 250+ ft-lbs from 4100 RPM to 6500 RPM:
![]() You won't find any of the superchargers producing a curve like that. This was achieved with around 12 psi of boost. A slightly larger turbo could probably hold the torque higher into the upper RPM range as well.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following 3 Users Say Thank You to King Tut For This Useful Post: |
#91 | |
Drives: AE86, 2x GT86, TE27
I had a gt2860rs on my s15 and it was an epic street car. I swapped it out for a gt3076r and didn't like it at all. It's why I've chosen a gtx2863r for mine. The advice I was given was similar to the above, and that I should go to a gtx3067r if I wanted a bit more. The problem is that responsive is so subjective. I glazed over a post saying that 14psi at 4500rpm is responsive; and for them that may be, but that certainly isn't what I'd call responsive. Personally, I think there is a difference in what the term street car really means. To me, it's driving around the streets. To others, it's highway pulls. |
#92 |
I'll also add that this motor isn't snake oil. It is just a very efficient modern engine.
Sure, you might put a 600hp turbo on it, run it at 350hp, and think that it's responsive, and for you it might be. But you're kidding yourself if you think you have anything over a well chosen 400hp rated turbo making the same 350hp. The only thing the first example has is scope for later power needs. I would encourage anyone that is seriously thinking of choosing a turbo to learn how to size one correctly using maps, and not take opinions from those running over sized turbos, who IMO are either giving biased opinions to justify their own purchase, or only interested in highway pulls. |
#93 | |
King of Kiwi Palace
Drives: Faster than you
Drivability on the low end has NOTHING to do with the size of the turbo and you are severely mistaken. Its like you're trying to re-enforce the idea that smaller turbos are better when it's already been debunked on this car. Better meaning more efficient power, cooling, driveline strain, driveability at low speeds, list goes on.
#94 | |
you simply cannot make the same amount of horsepower on a 'properly sized' 28xx turbo that you can with a 30r or 35r on pump gas reliably. i know this, from experience. and yes, this engine is remarkable in the way it is able to spool these 'huge' turbos. there is almost no perceptible difference in 'lag' between my 2867r and a 3076r. the 3582r doesn't add much on top of that. and xx psi @ xxxx rpm does not effectively quantify how responsive a turbo feels. the t3/t4 hybrids build more boost at lower rpm than the gtx's (maybe, depends which ones you're comparing), yet feel far less responsive. speak from experience. if you were, you wouldn't be saying the things that you are. |
#95 |
Drives: Sterling BRZ Ltd
I've done lots of research and not on forums, info straight from Garrett/Precision. I can read/plot maps just fine. In the end I still went with what in my opinion felt right. Because at the end of the day it's all personal opinion.
At the end of the day I purchased a turbo that is larger then I would have originally thought but that's the fun part. Learning, trying new things, take my head out of formulas and paper work, and just drive the thing. (Now if it would stop snowing) No one has some great wealth of knowledge of what these motors will do so we are all just going on hunchs and guess's regardless of what the math says. Don't get me wrong I do my math homework but it's not the end all be all of decisions, the drive is.
#96 | |
King of Kiwi Palace
I urge people in this thread please do research, I mean actual research, not regurgitated forum posts. Dont claim things you dont know about and please for the love of god dont over exaggerate or mistake low end power for low end city driving response, they are two different things. Oh and dont apply what you know about low compression turbo motors to this one.
| The Following User Says Thank You to Ironsquid For This Useful Post: | diss7 (02-19-2014) |
#97 |
If you aren't running a 6466, you're a *****.
| The Following User Says Thank You to Boss Paco For This Useful Post: | Ironsquid (02-19-2014) |
#98 |
Drives: 2013 BRZ Premium
| The Following User Says Thank You to spdbydesignchris For This Useful Post: | Sportsguy83 (02-19-2014) |
| !!!Limited time only sale on Greddy Turbo Kits with Free Boost Gauge!!! | vividracing | Forced Induction | 0 | 01-24-2014 01:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 06:34 PM |
| Turbo Kits: Rational boost threshold yet? | Ryephile | Forced Induction | 88 | 01-22-2013 12:05 AM |
| Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-19-2010 02:53 PM |
