#85 |
Drives: AE86, 2x GT86, TE27
I call BS at that claim. I raised my rev limit at it didn't like going past 7400, but once I replaced the front pipe that hesitation disappeared. Now it revs to 8000 quite happily.
#86 |
Drives: Pavement MT GR86
Several guys doing 8k rev limits for autoX.....only thing I noticed via the dyno plots is nothing past 75/7600 made more power. Seemed to really fall on it's face.
I'm guessing that is cam profile and headers but honestly not sure.
GR86 MT premium
#87 | |
I mean headers designed with any kind of engineering input have just started to come out.
GR86 MT premium
#88 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
E85 in a nutshell..
![]() Edit: personally not a fan of E85. Sure its good for easy HP gains, but for long term? I wouldn't risk it on my engine just for a few extra hp.. |
#89 |
You don't need to run e85; water it down to e50 or e30. Most of the guys I know locally running ethanol in their track/drift cars run e30; there just isn't much gain to go further than that, from what I've seen anyway, I'm not a tuner.
#90 |
I does feel to me on mine going to 8k is passing peak power, but I have it there to use as there is two comers at my local track that I'd hit 3rd limiter before the corner, now I don't. Also, I chop into 2nd on the hairpin, taking 2nd to redline then puts me at better power in 3rd. However back straight I don't take 4th to redline, I shift at 7700 or so, maybe sooner (not sure exactly I'm not looking at the tacho.) But my butt dyno says that it's better to shift before 8000 redline into 5th
#91 | |
I would also include intake manifold runner length and chamber size. Always seems to be overlooked when NA performance is discussed. I have a feeling a proper top end tuned header with a proper intake manifold designed for higher revs would make significant improvements beyond 7600rpm. |
#92 |
Anything besides valve springs need to be swapped for reliability at 8k?
GR86 MT premium
#93 | |
Drives: Toyota GT86
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr) |
#94 | |
Drives: 1997 Eagle Talon TSi AWD
It needs to constantly be retuned and check. The blend changes throughout the season. I always stick to 93oct or race fuel |
#95 |
Drives: '13 Whiteout FRS
that's why if you run e85 you run flex fuel for the safety. Also the B series heads vs ours, nobody knows what the head will flow. it's never been bench flowed as far as I know. and if guys are making 600hp without any head work, I'd say it's safe to say that that's not the case. sure it's a great motor, but to make that power you need at least cams. that's already comparing stock to modified. Nobody has done anything on these motors yet so don't say it can't be done. you are basing your info off nothing.
yes vtec has different cam profiles that also effects exhaust, but you can still make decent power with mild cam upgrades. it's obvious that you can't be convinced, so I'll let the market do that when it's ready for it. and as far as what's needed to do cams, there's no point in drop in cams. if you do it, full valve train needs to be done. titanium springs, retainers, valves, and probably replace the buckets too.
Previous:
'01 Accord-daily '93 Rx7-fire breathing track monster 545hp 397tq 2300lb. '06 Mazdaspeed6 one helluva love-hate relationship |
#96 |
I'm only going of what has been shown so far. Na at this point isn't there in terms of parts availability.
You can over come poor head design by cramming more boost at it. Sent from, The Frozen North
#97 |
#98 |
Drives: 323
The problem with this engine is that you only have control of one aspect of the cams, you cant use varying lifts, duration, ramp angles etc like the Honda guys have access too. (At least AFAIK, I come from static heads)
Which means that to maintain downlow you have to compromise. Hopefully by the time I have the coin together for BRZ theres some better gear out and about
| "Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 02:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 06:34 PM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
| Agency Power Intake?? "FT86 website" | ScionFrsFan | Engine, Exhaust, Transmission | 14 | 12-03-2012 06:25 AM |
